查看: 1447|回復(fù): 0
單片機(jī)靜態(tài)顯示
ID:937858 發(fā)表于 2021-6-15 22:49 | 只看該作者 回帖獎勵(lì) |倒序?yàn)g覽 |閱讀模式
單片機(jī)靜態(tài)顯示數(shù)字程序
#include<reg52.h>
sbit wela=P2^0;
sbit dula=P2^1;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,     //不帶小數(shù)點(diǎn)的編碼
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0xbf,0x86,      //帶小數(shù)點(diǎn)的編碼
0xdb,0xcf,0xe6,0xed,
0xfd,0x87,0xff,0xef};
void display();
void delay(uint z)     //延時(shí)子函數(shù)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
                 display();
void display() //顯示子函數(shù)
        dula=1;
                P1=table[0];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xfe;
                wela=0;
                delay(2);
               dula=1;
                P1=table[1];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xfd;
                wela=0;
                delay(2);
        dula=1;
                P1=table[2];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xfb;
                wela=0;
                delay(2);
        dula=1;
                P1=table[3];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xf7;
                wela=0;
                delay(2);
            dula=1;
                P1=table[4];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xef;
                wela=0;
                delay(2);
               dula=1;
                P1=table[5];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xdf;
                wela=0;
                delay(2);
        dula=1;
                P1=table[6];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0xbf;
                wela=0;
                delay(2);
        dula=1;
                P1=table[7];
                dula=0;
                P1=0xff;
                wela=1;
                P1=0x7f;
                wela=0;
                delay(2);
數(shù)碼管靜態(tài)顯示測試.zip
1.17 KB, 下載次數(shù): 2, 下載積分: 黑幣 -5
