查看: 1550|回復(fù): 0
超聲波測(cè)距簡(jiǎn)單實(shí)現(xiàn)
ID:700899 發(fā)表于 2021-6-17 11:43 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include"reg52.h"
#include <intrins.h>
#define uint unsigned int  //偷懶
sbit RS = P1^0;
sbit RW = P1^1;   //
sbit EN = P2^5;
sbit trig=P2^1;   //超聲波觸發(fā)引腳
sbit echo=P2^0;   //超聲波接收引腳
bit flag1;
uchar count;
long int distance;
unsigned char code table[]={"0123456789"};
void delay(uint n)  //延時(shí)函數(shù)
        uint x,y;
                for(x=n;x>0;x--)
                        for(y=110;y>0;y--);
void T0_init()    //T0中斷初始化
        TMOD=0x01;    //定義計(jì)時(shí)器0工作方式為1
        TL0=0x66;     //裝入初始值
        TH0=0xfc;
        ET0=1;   //開(kāi)定時(shí)器0中斷
        EA=1;    //開(kāi)總中斷
int delay_ms(unsigned char xms)
    unsigned char x,y;
    for(x=xms;x>0;x--)
        for(y=110;y>0;y--);
    return 0;
int write_com(unsigned char com)//寫(xiě)命令的函數(shù)體
    RS = 0;   //寫(xiě)指令
    RW = 0;
    P0 = com;
    delay_ms(5);
    EN = 1;
    delay_ms(5);
    EN = 0;
    return 0;
int write_date(unsigned char date)//寫(xiě)數(shù)據(jù)的函數(shù)體
    RS = 1;  //寫(xiě)數(shù)據(jù)
    RW = 0;
    P0 = date;
    delay_ms(5);
    EN = 1;
    delay_ms(5);
    EN = 0;
    return 0;
int init()//初始化函數(shù)體
    EN = 0;
    write_com(0X38);//設(shè)置16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
    write_com(0X0C);//設(shè)置開(kāi)顯示,不顯示光標(biāo)
    write_com(0X06);//寫(xiě)一個(gè)字符時(shí),光標(biāo)自動(dòng)+1
    write_com(0X01);//顯示清零
    return 0;
void dis()   //顯示固定字符
        write_com(0x80+0x40);   //設(shè)定輸入位置
        write_date('d');         //輸入用'',不可以用""
        write_date('i');
        write_date('s');
        write_date('t');
        write_date('a');
        write_date('n');
        write_date('c');
        write_date('e');
        write_date(':');
        write_com(0x80+0x4c);    //設(shè)定輸入位置
        write_date('.');
        write_com(0x80+0x4e);    //設(shè)定輸入位置
        write_date('c');
        write_date('m');
void trigger()   //超聲波模塊觸發(fā)函數(shù)
        trig=1;      //打開(kāi)超聲波觸發(fā)端口
        delay(1);
        trig=0;      //關(guān)閉超聲波觸發(fā)端口
void measure_init()  //測(cè)量函數(shù)初始化
        trig=0;   //觸發(fā)端口低電平
        echo=0;   //接收端口低電平
        count=0;
void measure()    //測(cè)距函數(shù)
        uchar a;
        uint b,c;
        TR0=1;   //打開(kāi)定時(shí)器
        while(echo)   //當(dāng)超聲波接收打開(kāi)時(shí)計(jì)時(shí)
        TR0=0;   //關(guān)閉定時(shí)器
        a=TL0;   //a,b分別賦予中斷函數(shù)高八位和第八位計(jì)時(shí)后的數(shù)值
        b=TH0;
        c=(b<<8)+a;  //高八位左移八位之后與低八位做加法運(yùn)算
        c=c-0xfc66;  //減去初始值高八位和低八位
        distance=c+1000*count;  //總的時(shí)間,單位是μs
        TL0=0x66;    //重新裝入初始值
        TH0=0xfc;
        delay_ms(30);
        distance=3453*distance/20000; //計(jì)算距離,單位是cm
距離計(jì)算原理:所求t μs,distance=t*0.34(聲速340m/s=0.34cm/μs)/2
void echodisplay(uint x)   //顯示距離函數(shù)
        uchar q,b,s,g;
        q=x/1000;            //將測(cè)量函數(shù)測(cè)得的distance分為個(gè)位,十位,百位,千位
        b=(x/100)%10;
        s=(x/10)%10;
        g=x%10;
        write_com(0x80+0x49);    //設(shè)定輸出位置
        write_date(table[q]);     //寫(xiě)入數(shù)據(jù)
        write_date(table[b]);
        write_date(table[s]);
        write_com(0x80+0x4d);    //設(shè)定輸入位置
        write_date(table[g]);     //寫(xiě)入數(shù)據(jù)
void main()    //主函數(shù)
        init();    //初始化LCD
        T0_init();     //初始化T0計(jì)時(shí)器
        measure_init();//初始化超聲波測(cè)量模塊
        while(1)       //循環(huán)
                dis();     //顯示固定字符
                trigger(); //觸發(fā)超聲波測(cè)距
                while(echo==0)//當(dāng)接收端沒(méi)有打開(kāi)的時(shí)候在這里循環(huán)
                measure();//測(cè)量距離distance
                echodisplay(distance);//顯示距離distance
                measure_init();//再次初始化測(cè)距模塊
                delay_ms(500);//測(cè)量間隔500ms
void T_0() interrupt 1   //計(jì)時(shí)器中斷函數(shù)T0
        TF0=0;      //計(jì)時(shí)器溢出中斷  標(biāo)志位
        TL0=0x66;   //填入初始數(shù)據(jù)
        TH0=0xfc;
        count++;    //產(chǎn)生一次中斷就加一
  if(count==18)  //當(dāng)計(jì)數(shù)到達(dá)18的時(shí)候,約1s
                TR0=0;      //關(guān)閉計(jì)時(shí)器中斷0
                TL0=0x66;   //重新裝入初始值
                TH0=0xfc;
                count=0;    //把count清零
