做了一個測方波用的頻率計最高頻率實測可以超過20MHZ,
因為是實在沒有頻率夠高的信號啦
內(nèi)置4個檔位,做2、8、16、256分頻
自動找檔功能,LCD1602顯示,有開機(jī)loading顯示。
在高頻段誤差小于千分之一,
低頻段誤差較大,例如49HZ,測得48或者50HZ
是因為做了2分頻,可略作修改,或多做一檔不進(jìn)行分頻。
兩塊數(shù)字芯片都是非�;A(chǔ)的,分別是74LS161(16進(jìn)制計數(shù)器)和CD4051(單刀八擲數(shù)字開關(guān))
750K測得0.751M
2021-6-21 00:41 上傳
開機(jī)loading顯示
2021-6-21 00:41 上傳
- #include "reg51.h"
- #include "stdio.h"
- #include "string.h"
- //sprintf(strHex, "%0x", num); 十進(jìn)制
- //sprintf(strHex, "%d", num); 十六進(jìn)制
- #include "1602.h"
- #include "type.h"
- #define uint unsigned int
- #define uchar unsigned char
- sbit LSA=P1^3;
- sbit LSB=P1^4;
- sbit LSC=P1^5;
- void Timer_Init();
- void delayms(uint yanshi);
- uint number_date=0;
- float fre_date=0;
- uchar str[16];
- uchar str2[16];
- uchar str3[16];
- uint flag_4051=3;
- uchar count=0;
- uchar t=1;
- void main()
- lcd1602init();
- Timer_Init();
- display_string(1,"START FRE Meter!");
- delayms(200);
- display_string(2,"Loading......");
- delayms(1000);
- display_string(1," ");
- display_string(2," ");
- // LSA=0;LSB=1;LSC=0;
- while(1)
- switch(flag_4051)
- case 1:
- LSA=LSB=LSC=0;
- delayms(1000);
- fre_date=number_date;
- fre_date=fre_date*2;
- if(fre_date>60000)
- flag_4051=2;
- P2=0x00;
- if(number_date<5000)
- sprintf(str2,"%0.1f",fre_date);
- strcat(str2,"HZ ");
- else
- sprintf(str2,"%0.3f",fre_date/1000);
- strcat(str2,"KHZ");
- strcpy(str,"START MODE ONE!!");
- break;
- case 2: LSA=0;LSB=1;LSC=0;
- delayms(1000);
- fre_date=fre_date*8;
- if(fre_date<60000) flag_4051=1;
- if(fre_date>200000) flag_4051=3;
- strcat(str2,"KHZ ");
- strcpy(str,"START MODE TWO!!");
- break;
- case 3: LSA=1;LSB=1;LSC=0;
- delayms(1000);
- fre_date=fre_date*16;
- if(fre_date<200000) flag_4051=2;
- if(fre_date>750000) flag_4051=4;
- strcpy(str,"START MODE THREE");
- break;
- case 4: LSA=1;LSB=1;LSC=1;
- delayms(1000);
- fre_date=fre_date*256;
- if(fre_date<750000) flag_4051=3;
- sprintf(str2,"%0.3f",fre_date/1000000);
- strcat(str2,"MHZ ");
- strcpy(str,"START MODE FOUR!");
- break;
- display_string(1, str);
- strcpy(str3,"Fre=");
- strcat(str3,str2);
- display_string(2, str3);
- void Timer_Init()
- TMOD=0X15;
- TR0=1;
- TR1=1;
- EA = 1;
- ET1 = 1; //允許T1定時中斷
- ET0 = 1; //允許T0計數(shù)中斷
- void Timer1() interrupt 3 //測量時間
- uchar i;
- TL1=0XF0;
- TH1=0XD8; //給定時器賦初值,定時10ms
- i++;
- if(i>99)
- number_date=(TH0*256+TL0);//+t*65535;
- TL0=0;
- TH0=0;
- t=0;
- i=0;
- void Timer0() interrupt 1
- t++;
- TL0=0;
- TH0=0;
- uint i,j;
- for(i=yanshi;i>0;i--)
- for(j=125;j>0;j--);
2021-6-21 01:12 上傳
提供一種頻率計的設(shè)計思路,電路和程序的優(yōu)化空間很大,大家可以自行發(fā)揮,僅供參考,切勿照搬
全部資料51hei下載地址:
20M Frequency meter.zip
(106.4 KB, 下載次數(shù): 67)
2021-6-21 00:44 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
