查看: 1293|回復(fù): 1
10A Current Mode Non-Synchronous PWM Boost Converter
General Description
The SL4006 is a current mode boost DC-DC converter. It is PWM circuitry with built-in 15mΩ
power MOSFET make this regulator highly power efficient. The non-inverting input of error amplifier
connects to a 1.2V precision reference voltage. Current mode control and external compensation
network make is easy and flexible to stabilize the system.
The SL4006 is available in the SOP-8L(EP) package to fit in space-saving PCB for the
application fields.
Features
 Supply Voltage Operating Range: 2.7V to 12V
 Adjustable Output up to 13V
 Internal Fixed PWM frequency: 400KHz
 Precision Feedback Reference Voltage: 1.2V (±2%)
 Internal 15mΩ, 10A, 14V Power MOSFET
 Shutdown Current: 1μA (Max.)
 Over Temperature Protection
 Internal Soft Start Function
 Adjustable Over Current Protection: 2A ~ 10A
 Package: SOP-8L(EP)
Applications
 Chargers
 LCD Displays
 Digital Cameras
 Handheld Devices
 Portable Products
 Power Bank
Typical Application Circuit
ID:899448 發(fā)表于 2021-6-22 10:49 | 只看該作者
可免費(fèi)提供樣品測(cè)試
歡迎咨詢!。
