查看: 2844|回復: 0
STM32編碼器測距程序
ID:944437 發(fā)表于 2021-6-27 23:41 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/*- TIM5編碼器模式配置 -*/
        //TIM_DeInit(TIM5);
        TIM_TimeBaseStructure.TIM_Period = 65535;//計次數;
        TIM_TimeBaseStructure.TIM_Prescaler = 0;//
        TIM_TimeBaseStructure.TIM_ClockDivision =TIM_CKD_DIV1 ;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM5, &TIM_TimeBaseStructure);
        TIM_EncoderInterfaceConfig(TIM5, TIM_EncoderMode_TI12, TIM_ICPolarity_BothEdge ,TIM_ICPolarity_BothEdge);        //配置編碼器模式觸發(fā)源和極性
        TIM_ICInitStructure.TIM_Channel = TIM_Channel_1; //CC1S=01         選擇輸入端 IC1映射到TI2上
         TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_BothEdge;        //上升沿捕獲
         TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI; //映射到TI2上
         TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;         //配置輸入分頻,不分頻?
         TIM_ICInitStructure.TIM_ICFilter = 0x01;//IC1F=0000 配置輸入濾波器 不濾
        TIM_ICInit(TIM5, &TIM_ICInitStructure);
        NVIC_InitStructure.NVIC_IRQChannel = TIM5_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;//搶占優(yōu)先級2
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;                //子優(yōu)先級3
        NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
        NVIC_Init(&NVIC_InitStructure);        //根據指定的參數初始化VIC寄存器
        TIM_ClearFlag(TIM5, TIM_FLAG_Update);
      TIM_ITConfig(TIM5, TIM_IT_Update, ENABLE);
        TIM_SetCounter(TIM5,0);
        TIM_Cmd(TIM5, ENABLE);   //啟動TIM5定時器
函數功能:單位時間讀取編碼器計數,此函數在定時器中斷里面用我的是定時器6每隔5ms讀取一次
入口參數:定時器
返回  值:計數值
int x=0;
int Read_Encoder(u8 TIMX)
    int Encoder_TIM;
   switch(TIMX)
                 case 3:  Encoder_TIM= (short)TIM3 -> CNT;  TIM3 -> CNT=0;break;//
                 case 4:  Encoder_TIM= (short)TIM4 -> CNT;  TIM4 -> CNT=0;break;
                 case 5:  Encoder_TIM= (short)TIM5 -> CNT;  TIM5 -> CNT=0;break;
                 default:  Encoder_TIM=0;
                return Encoder_TIM;
初始化編碼選擇編碼模式
TIM_EncoderInterfaceConfig(TIM5, TIM_EncoderMode_TI12, TIM_ICPolarity_BothEdge ,TIM_ICPolarity_BothEdge);主函數,距離可通過串口打印出來
int main(void)
        uart_init(115200);        //USART1_TX   PA9   USART1_RX          PA10
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);         //設置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應優(yōu)先級
        delay_init();
        MOTOR_Init();        //PC0,1 2 3
        TIM6_Mode_Config_Init();                                                         //使能定時器6 5ms中斷一次
    TIM4_Encoder_Init();        //使能TIM4對應的編碼器                                        //PB6 PB7
        TIM5_Encoder_Init();        //使能TIM5對應的編碼器                                    //PA0 PA1
void TIM6_IRQHandler(void)        //定是時間不能太長否則計數器溢出了就會測量錯誤
        if (TIM_GetITStatus(TIM6, TIM_IT_Update) != RESET)
                danweilenth( Read_Encoder(4),Read_Encoder(5));        //每隔5ms中斷一次 讀取對應CNT的值,并計算路程
                printf("Encoder.M1Lneth=%f\r\n",Encoder.M1Lneth);//打印出電機1的路程
                printf("Encoder.M2Lneth=%f\r\n",Encoder.M2Lneth);//打印出電機2的路程
        TIM_ClearITPendingBit(TIM6, TIM_IT_Update);
相關代碼下面有下載可自行下: 兩個編碼器測距代碼.7z (191.89 KB, 下載次數: 25)
收藏收藏1 分享淘帖 頂1 踩
Powered by 單片機教程網
