單片機源程序如下:
#include <reg52.h>
#include <lcd.h>//液晶顯示配置文件
#include <stdio.h>
sbit mot_clock = P0^1;
sbit mot_dir =P0^0;
sbit clock = P0^3;
sbit dir =P0^2;
sbit kaiguan =P1^1;
sbit zuozhuan =P1^0;
sbit youzhuan =P1^2;
sbit zuok =P1^3;//左轉(zhuǎn)開始信號
sbit zuos =P1^4;//左轉(zhuǎn)停止信號
sbit youk =P1^5;//右轉(zhuǎn)開始信號
sbit yous =P1^6;//右轉(zhuǎn)停止信號
sbit zheng =P3^4;
sbit Tr=P3^0;
sbit Ec=P3^1;
sbit tui=P0^7;
typedef unsigned char uchar;
typedef unsigned int uint;
unsigned int RunSpeed=50; //速度
bit dir_flag;
uint d=0;
unsigned char a[2]=0;
unsigned int s,j,s1;
float csbc=0.03315;
void delay_ms(unsigned int Delay) //1ms延時程序
unsigned int i;
for(;Delay>0;Delay--)
for(i=0;i<124;i++);
void Delay10us()
uchar i;
i=10;
while(--i);
void Delay(unsigned int z)//毫秒級延時
unsigned int x,y;
for(x = z; x > 0; x--)
for(y = 114; y > 0 ; y--);
//定時器0中斷程序:正轉(zhuǎn)
/*void t_0(void) interrupt 1
Ec=0;
void zhengzhuan()
dir_flag=1;
mot_clock=0;
mot_dir=0;
clock=0;
dir=0;
delay_ms(100);
mot_clock=1;
mot_dir=1;
clock=1;
dir=1;
//定時器1中斷:反轉(zhuǎn)
void t_1() interrupt 3
dir_flag=0;
mot_clock=0;
mot_dir=0;
clock=0;
dir=0;
delay_ms(100);
mot_clock=1;
mot_dir=1;
clock=1;
dir=1;
//中斷0:加速程序
void SpeedUp() interrupt 0
if(RunSpeed>=12)
RunSpeed=RunSpeed-2;
//中斷1:減速程序
void SpeedDowm() interrupt 2
if(RunSpeed<=100)
RunSpeed=RunSpeed+2;
void qiting()
if(kaiguan==0)
zuozhuan=0;
youzhuan=0;
if(kaiguan==1)
zuozhuan=1;
youzhuan=1;
void Read_value()
Tr=0; //啟動一次模塊
Delay10us();
Tr=1;
ET0=1; //啟動計數(shù)器T0,用以計時
TR0=1;
EA=1;
j=50; //延時
while(j--)
Ec=1;
j=0;
while(Ec) //判斷接收回路是否收到超聲波的回波
j++;
if(j>=2500) //如果達到一定時間沒有收到回波,則將csbint置零,退出接收回波處理程序
Ec=0;
TR0=0;
s1=TH0*256+TL0; //讀取時間數(shù)據(jù)
TH0=0;
TL0=0;
s1=s1*csbc-4;
s1/=2;
a[0]=s1/10+'0';
a[1]=s1%10+'0';
if((s1>30)&&(tui!=0))
WriteCmd(LCD_CLS);
while((s1>30)&&(tui!=0))
zuozhuan=0;
youzhuan=0;
DisplayString(0x4,1,"stop");
//LCD_Write_String(0,1,a);
DisplayString(0x0,0,"youzhangaiwu");
WriteCmd(LCD_CLS);
if(tui==0)
zuozhuan=1;
youzhuan=1;
LCDInit();
/*定時器設(shè)置*/
TMOD|=0x61; //定時器0,1都為計數(shù)方式;方式2;
EA=1; //開中斷
TH0=0; //定時器0初值FFH;
TL0=0;
ET0=1;
TR0=0;
TH1=0xff; //定時器1初值FFH;
TL1=0xff;
ET1=1;
TR1=1;
IT0=1; //脈沖方式
EX0=1; //開外部中斷0:加速
IT1=1; //脈沖方式
EX1=1; //開外部中斷1:減速
mot_clock=1;
dir_flag =1;
mot_dir=1;
clock=1;
dir=1;
DisplayString(0x0,0,"forward");
delay_ms(RunSpeed);
mot_clock=~mot_clock;
clock=~clock;
Read_value();
DisplayString(0x2,1,"cm");
qiting();
if(zheng==0)
zhengzhuan();
if(dir_flag==1)//正轉(zhuǎn)
clock=~clock;
//delay_ms(RunSpeed);
if(zuok==0)
WriteCmd(LCD_CLS);
zuozhuan=0;
clock=1;
dir=1;
while(zuos!=0)
delay_ms(RunSpeed);
clock=~clock;
DisplayString(0x0,0,"Turn Left small");
WriteCmd(LCD_CLS);
if(youk==0)
WriteCmd(LCD_CLS);
youzhuan=0;
clock=1;
dir=1;
while(yous!=0)
delay_ms(RunSpeed);
DisplayString(0x0,0,"Turn Right small");
WriteCmd(LCD_CLS);
if(dir_flag==0)//反轉(zhuǎn)
if(zheng==0)
zhengzhuan();
mot_dir=~mot_dir;
dir=~dir;
if(zuok==0)
WriteCmd(LCD_CLS);
zuozhuan=0;
mot_clock=1;
mot_dir=1;
while(zuos!=0)
clock=~clock;
delay_ms(RunSpeed);
dir=~dir;
DisplayString(0x0,0,"back Turn Left ");
WriteCmd(LCD_CLS);
if(youk==0)
WriteCmd(LCD_CLS);
youzhuan=0;
mot_clock=1;
mot_dir=1;
while(yous!=0)
clock=~clock;
delay_ms(RunSpeed);
mot_dir=~mot_dir;
DisplayString(0x0,0,"back Turn Right ");
WriteCmd(LCD_CLS);
LCD1602:
** 宏定義區(qū) **
/*------------------------------- LCD模塊 ------------------------------------*/
sbit LCD_RW =P3^6; //讀寫控制端
sbit LCD_RS =P1^7; //數(shù)據(jù)命令選擇端
sbit LCD_E =P3^7; //執(zhí)行使能端
#define Busy 0x80 //忙信號
#define LCD_Data P2
#define Write 0x00 //低電平寫入
#define Read 0x01 //高電平讀出
#define Data 0x01 //高電平選擇數(shù)據(jù)
#define Cmd 0x00 //低電平選擇命令
#define Enable 0x00 //躍變到低電平時執(zhí)行命令
#define Disable 0x01
#define True 0x01
#define False 0x00
#define LCD_Init 0x38 //初始化模式
#define LCD_DispCtr 0x0C //開顯示及光標設(shè)置
#define LCD_CloseCtr 0x08 //關(guān)顯示
#define LCD_CLS 0x01 //清屏幕
#define LCD_EnterSet 0x06 //顯示光標
/*------------------------------- LCD模塊 -------------------------------------*/
void LCDInit(void); //LCD初始化
void SetWriteCmd(void); //設(shè)置寫命令模式
void SetReadCmd(void); //設(shè)置讀命令模式
void SetWriteData(void); //設(shè)置寫數(shù)據(jù)模式
void WriteCmd(char cmd); //寫命令
void WriteData(char ddata); //寫數(shù)據(jù)
void ExecuteCmd(void); //執(zhí)行命令
void SetXY(char x,char y); //定位顯示地址
void DisplaySingleChar(char x,char y,char cchar); //顯示單個字符
void DisplayString(char x,char y,char *str); //顯示一段字符串
void Delay(unsigned int time); //延時主程序
//void delay500ms(void) ;
void write_com(unsigned char com);
void write_data(unsigned char date);
void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s);
bit IsBusy(void); //判斷忙標志函數(shù)
//void DisplayTime(void); //顯示時間
//void DisplayAVGSpeed(void); //顯示平均速度
//void DisplayDistance(void); //顯示路程
** LCD驅(qū)動模塊 **
/*--------------------------------- LCD初始化函數(shù)--------------------------------------*/
void LCDInit(void)
//三次顯示模式設(shè)置
LCD_Data=0;
LCD_E=Disable;
Delay(5);
WriteCmd(LCD_Init);
Delay(5);
WriteCmd(LCD_Init);
Delay(5);
WriteCmd(LCD_Init);
WriteCmd(LCD_Init); //初始化
WriteCmd(LCD_CloseCtr); //關(guān)顯示
WriteCmd(LCD_CLS); //清屏幕
WriteCmd(LCD_EnterSet); //光標移動設(shè)置
WriteCmd(LCD_DispCtr); //顯示開以及光標設(shè)置
/*--------------------------------- LCD模式設(shè)置函數(shù)--------------------------------------*\
SetWriteCmd() 設(shè)置LCD為寫命令模式
SetReadCmd() 設(shè)置LCD為讀命令模式
SetWriteData() 設(shè)置LCD為寫數(shù)據(jù)模式
LCD_RW=Write;
LCD_RS=Cmd;
LCD_RW=Read;
LCD_RS=Cmd;
LCD_RW=Write;
LCD_RS=Data;
/*--------------------------------- LCD功能執(zhí)行函數(shù)--------------------------------------*\
WriteCmd() 寫命令
WriteData() 寫數(shù)據(jù)
ExecuteCmd() 執(zhí)行命令
SetXY() 顯示定位
DisplaySingleChar() 顯示單個字符
DisplayString() 顯示一串字符
IsBusy() 忙標志檢測
while(IsBusy());
LCD_Data=cmd;
SetWriteCmd();
ExecuteCmd();
while(IsBusy());
LCD_Data=ddata;
SetWriteData();
ExecuteCmd();
LCD_E=Enable;
LCD_E=Disable;
if (y)
x|=0x40;
x|=0x80;
Delay(5);
WriteCmd(x);
SetXY(x,y);
WriteData(cchar);
while(*str)
Delay(5);
DisplaySingleChar(x++,y,*str);
str++;
bit IsBusy(void)
LCD_Data=0xFF;
SetReadCmd();
ExecuteCmd();
return (bit)(P2 & 0x80);
void write_com(unsigned char com) //寫命令
LCD_RS=0;
LCD_RW=0;
LCD_Data=com;
Delay(5);
LCD_E=1;
Delay(5);
LCD_E=0;
void write_data(unsigned char date) //寫一個字符
LCD_RS=1;
LCD_RW=0;
LCD_Data=date;
Delay(5);
LCD_E=1;
Delay(5);
LCD_E=0;
if (y == 0)
write_com(0x80 + x);
write_com(0xC0 + x);
while (*s)
write_data( *s);
s ++;
