查看: 4712|回復(fù): 0
stc8a8k單片機(jī)+編碼器控制PWM輸出測(cè)試程序
ID:111376 發(fā)表于 2021-7-7 12:01 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
stc8a8k單片機(jī)+AB相編碼器控制PWM輸出測(cè)試程序,
#include "stc8.h"
#include "intrins.h"
//測(cè)試工作頻率為11.0592MHz
//sfr          INTCLKO  = 0x8f;
#define      EX2        0x10
#define      EX3        0x20
#define      EX4        0x40
#define    CYCLE       30000
int val = 0;
int val1 = 200;
int val2 = 5;
bit dir = 0;
bit ccw = 0;
bit cw  = 0;
void PWM_init(void);
void exint_init(void);
void Delay100us()                //@11.0592MHz
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 2;
        j = 15;
        do
                while (--j);
        } while (--i);
void Delay500us()                //@11.0592MHz
        unsigned char i, j;
        _nop_();
        _nop_();
        i = 6;
        j = 93;
        do
                while (--j);
        } while (--i);
void exint_init()       //外部中斷初始化
              //   IT0 = 0; //使能INT0上升沿和下降沿中斷
         IT0 = 1;  //使能INT0下降沿中斷
         EX0 = 1; //使能INT0中斷
       //  IT1 = 0; //使能INT1上升沿和下降沿中斷
      // IT1 = 1;  //使能INT1下降沿中斷
      //   EX1 = 1; //使能INT1中斷
         INTCLKO  = EX2; //使能INT2下降沿中斷
         //INTCLKO |= EX3; //使能INT3下降沿中斷
         //INTCLKO |= EX4; //使能INT4下降沿中斷
        // EA = 1;
void PWM_init()     //PWM初始化設(shè)置
          P_SW2  = 0x80;
    PWMCKS = 0x00; // PWM時(shí)鐘為系統(tǒng)時(shí)鐘
    PWMC   = CYCLE; //設(shè)置PWM周期為
    PWM0T1 = 0x0000;
    PWM0T2 = 0x0001;
    //PWM0CR = 0x88; //使能PWM0-P1.0輸出
    //PWM0CR = 0x80; //使能PWM0-P2.0輸出
    PWM0CR = 0x90; //使能PWM0-P6.0輸出
          PWM1T1= 0x0000;
    PWM1T2= 0x0001;
    //PWM1CR = 0x88; //使能PWM1-P1.1輸出
    //PWM1CR = 0x80; //使能PWM1-P2.1輸出
    PWM1CR = 0x90; //使能PWM1-P6.1輸出
          PWM2T1 = 0x0000;
    PWM2T2 = 0x0001;
                //PWM2CR = 0x88; //使能PWM2-P1.2輸出
    //PWM2CR = 0x80; //使能PWM2-P2.2輸出
    PWM2CR = 0x90; //使能PWM2-P6.2輸出
          PWM3T1 = 0x0000;
    PWM3T2 = 0x0001;
    //PWM3CR = 0x88; //使能PWM2-P1.3輸出
    //PWM3CR = 0x80; //使能PWM2-P2.3輸出
    PWM3CR = 0x90; //使能PWM2-P6.3輸出
          PWM4T1 = 0x0000;
    PWM4T2 = 0x0001;
                //PWM4CR = 0x88; //使能PWM4-P1.4輸出
    //PWM4CR = 0x80; //使能PWM4-P2.4輸出
    PWM4CR = 0x90; //使能PWM4-P6.4輸出
          PWM5T1 = 0x0000;
    PWM5T2 = 0x0001;
                //PWM5CR = 0x88; //使能PWM5-P1.5輸出
    //PWM5CR = 0x80; //使能PWM5-P2.5輸出
    PWM5CR = 0x90; //使能PWM5-P6.5輸出
          PWM6T1 = 0x0000;
    PWM6T2 = 0x0001;
                //PWM6CR = 0x88; //使能PWM5-P1.6輸出
    //PWM6CR = 0x80; //使能PWM6-P2.6輸出
    PWM6CR= 0x90; //使能PWM6-P6.6輸出
          PWM7T1 = 0x0000;
    PWM7T2 = 0x0001;
                //PWM7CR = 0x88; //使能PWM7-P1.7輸出
    //PWM7CR = 0x80; //使能PWM7-P2.7輸出
    PWM7CR = 0x90; //使能PWM7-P6.7輸出
    P_SW2 = 0x00;
    PWMCR = 0xc0; //啟動(dòng)PWM模塊
    //EA = 1;
//      P0M0 = 0x00;   P0M1 = 0x00;                             //設(shè)置P0.0~P0.7為雙向口模式
//      P1M0 = 0xff;   P1M1 = 0x00;                             //設(shè)置P1.0~P1.7為推挽輸出模式
//      P2M0 = 0x00;   P2M1 = 0xff;                             //設(shè)置P2.0~P2.7為高阻輸入模式
//      P3M0 = 0xff;   P3M1 = 0xff;                             //設(shè)置P3.0~P3.7為開(kāi)漏模式
//      P4M0 = 0xff;   P4M1 = 0xff;                             //設(shè)置P4.0~P4.7為開(kāi)漏模式
//      P5M0 = 0xff;   P5M1 = 0xff;                             //設(shè)置P5.0~P5.7為開(kāi)漏模式
//      P6M0 = 0xff;   P6M1 = 0xff;                             //設(shè)置P6.0~P6.7為開(kāi)漏模式
//      P7M0 = 0xff;   P7M1 = 0xff;                             //設(shè)置P7.0~P7.7為開(kāi)漏模式
            exint_init();
            PWM_init();
                        EA = 1;
      PCON = 0x02;  //MCU進(jìn)入掉電模式
      _nop_(); //掉電喚醒后立即進(jìn)入中斷服務(wù)程序
      _nop_();
     while (1)
                        if(P36==0)
           val+=val2;
                                        Delay500us();
           if (val >=30000) val=0 ;
void PWM_Isr() interrupt 22
      //static bit dir = 1;
      //static int val = 0;
    if (PWMCFG & 0x80)
        PWMCFG &= ~0x80; //清中斷標(biāo)志
       _push_(P_SW2);
       P_SW2 |= 0x80;
       PWM0T2 = val;
                         PWM1T2 = val;
                         PWM2T2 = val;
                         PWM3T2 = val;
                         PWM4T2 = val;
                         PWM5T2 = val;
                         PWM6T2 = val;
                         PWM7T2 = val;
       _pop_(P_SW2);
void INT0_Isr() interrupt 0
     if((P32==0)&&(P33==1)) ccw=1,cw=0;
           else ccw=0;
     if((P32==0)&&(P33==0)) cw=1,ccw=0;
                 else  cw=0;
                                if(ccw==1)
           val+=val1;
        if(cw==1)
                                  val-=val1;
          if (val <=0) val=30000;
void INT1_Isr() interrupt 2
void INT2_Isr() interrupt 10
       P50=!P50;
                         P51=!P51;
void INT3_Isr() interrupt 11
     P60 = !P60; //測(cè)試端口
void INT4_Isr() interrupt 16
收藏收藏5 分享淘帖 頂1 踩
