查看: 2328|回復(fù): 0
byd單片機(jī)+蜂鳴器播放熱愛105度的你 源程序
ID:404263 發(fā)表于 2021-7-9 16:02 | 顯示全部樓層 |閱讀模式
  1. #include "music.h"
  2. unsigned int code Freq[3][8] = {
  3. //  0     1     2     3     4    5      6     7
  4.         {63627,63627,63835,64020,64103,64260,64399,64523},
  5.         {64579,64579,64684,64777,64819,64898,64967,65029},
  6.         {65058,65058,65110,65156,65160,65217,65251,65281},
  7. };               //用于發(fā)出do re mi聲音的頻率第一階為低音 第二階為中音 第二階為高音   元素0湊數(shù)而已為了1為do 2為re
  8. unsigned char code GePu[114] = {
  9.         13,13,14,13,12,13,
  10.         6,12,11,6,11,
  11.         12,12,12,13,12,11,12,
  12.         13,11,6,11,11,
  13.         6,13,13,14,13,12,11,
  14.         13,13,6,6,11,
  15.         11,7,7,13,12,
  16.         11,
  17.         5,
  18.         15,13,12,11,12,13,11,
  19.         12,5,6,5,4,5,
  20.         13,13,12,13,5,
  21.         5,5,
  22.         15,12,12,11,12,13,11,
  23.         12,5,6,5,4,5,
  24.         13,13,12,13,21,
  25.         17,15,6,7,
  26.         11,11,7,11,12,
  27.         12,12,11,12,7,
  28.         11,11,7,11,5,
  29.         6,6,7,
  30.         11,11,7,11,12,
  31.         12,12,12,11,12,7,
  32.         11,
  33. };            //歌譜 1代表低音do 11代表中音do 21代表高音do
  34. unsigned char code Time[114] = {
  35.         1,1,1,1,1,1,
  36.         2,1,1,2,2,
  37.         2,1,1,1,1,1,1,
  38.         2,1,1,2,2,
  39.         2,1,1,1,1,1,1,
  40.         2,1,2,1,1,
  41.         2,1,1,2,2,
  42.         8,
  43.         1,
  44.         2,1,1,1,1,1,1,
  45.         4,1,1,1,1,1,
  46.         2,1,1,2,2,
  47.         4,1,
  48.   2,1,1,1,1,1,1,
  49.         2,1,1,1,1,1,
  50.         2,1,1,2,2,
  51.         2,2,2,2,
  52.         2,1,1,2,2,
  53.         2,1,1,2,2,
  54.         2,1,1,2,2,
  55.         4,1,1,
  56.         2,1,1,1,2,
  57.         1,1,1,1,2,2,
  58.         8,
  59. };            //節(jié)拍數(shù)1代表1/2拍 2代表1拍 4代表2拍 8代表4拍
  60. bit gBuzFlag = 0;
  61. void OutCtrl()
  62. {
  63.         if(gBuzFlag)                 //標(biāo)志位置1響蜂鳴器
  64.         {
  65.                 DATAB ^= 0x01;
  66.         }
  67.         else
  68.         {
  69.                 DATAB &= ~0x01;
  70.         }
  71. }
  72. unsigned char gRunCount = 0;              //樂譜跑到第幾個音
  73. unsigned char gSystemMode = 0;           //系統(tǒng)模式 0賦值模式 1響蜂鳴器 2停止
  74. unsigned char gOpenTime = 0;             //開的時間
  75. unsigned char gCloseTime = 0;            //關(guān)的時間
  76. void TimeCtrl()
  77. {
  78.         if(gSystemMode == 0)          //賦值
  79.         {
  80.                 TH0_Reload = (unsigned char)(Freq[GePu[gRunCount] / 10][GePu[gRunCount] % 10] >> 8);         //給16位定時器賦值
  81.                 TL0_Reload = (unsigned char)(Freq[GePu[gRunCount] / 10][GePu[gRunCount] % 10] & 0x00ff);     //給16位定時器賦值
  82.                 gOpenTime = Time[gRunCount]*10;          //響的時間Time[gRunCount]*10*125*100 us
  83.                 gCloseTime = Time[gRunCount]*10;         //停止等待的時間
  84.                 gSystemMode = 1;                         //跳轉(zhuǎn)到響
  85.                 gBuzFlag = 0;                            //蜂鳴器關(guān)閉
  86.         }
  87.         if(gSystemMode == 1)         //響
  88.         {
  89.                 if(gOpenTime > 0)          //響的時間大于0
  90.                 {
  91.                         gBuzFlag = 1;           //響
  92.                         gOpenTime--;              //時間--
  93.                 }
  94.                 else
  95.                 {
  96.                         gBuzFlag = 0;                //關(guān)閉
  97.                         gSystemMode = 2;             //跳轉(zhuǎn)到等待
  98.                 }
  99.         }
  100.         if(gSystemMode == 2)           //停止
  101.         {
  102.                 if(gCloseTime > 0)            //停的時間大于0
  103.                 {
  104.                         gBuzFlag = 0;
  105.                         gCloseTime--;
  106.                 }
  107.                 else
  108.                 {
  109.                         gBuzFlag = 0;
  110.                         gSystemMode = 0;           //跳轉(zhuǎn)到賦值
  111.                         gRunCount++;              //樂譜第幾個音++
  112.                         if(gRunCount >= 114)      //跑完整個樂譜從頭開始跑
  113.                         {
  114.                                 gRunCount = 0;
  115.                         }
  116.                 }
  117.         }
  118. }
keil代碼下載: 熱愛105度的你.zip (606.83 KB, 下載次數(shù): 29)
admin + 50 共享資料的黑幣獎勵!
