查看: 1799|回復: 2
單片機串口的自定義數據協議發(fā)送程序問題
ID:923440 發(fā)表于 2021-7-9 16:39 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
求幫忙看看單片機代碼是不是有什么問題;描述是:發(fā)送的串口協議的 幀頭AA,長度4,數據(3個字節(jié))異或校驗(只校驗數據位);
只有輸入正確的話會把數據發(fā)送到串口助手在電腦上顯示出來;
現在是發(fā)什么它都接受,根本給規(guī)定的不一樣;
代碼:#include <reg51.h>
#include<intrins.h>
#define uint  unsigned int
#define FOSC 11059200UL
#define BRT (65536 - FOSC / 115200 / 4)
sfr AUXR = 0x8e;
sfr T2H = 0xd6;
sfr T2L = 0xd7;
sfr S2CON = 0x9a;
sfr S2BUF = 0x9b;
sfr IE2 = 0xaf;
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P1M1 = 0x91;
sfr P1M0 = 0x92;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xb1;
sfr P3M0 = 0xb2;
sfr P4M1 = 0xb3;
sfr P4M0 = 0xb4;
sfr P5M1 = 0xc9;
sfr P5M0 = 0xca;
bit busy;
uchar xor_check;//異或校驗
  uchar recv_data;//臨時變量用來接收S2BUF中的數據
   uchar recv_cnt = 0;
uchar  recv_buf[10];//接收數據
uchar recv_flag = 0;
uchar machine_step = 0;
void delay_140us(void);
//void delay_1ms(unsigned int i);
void Uart2SEND(uint dat);
void Uart2SENDStr(char *p);
void Delay500ms()                //@11.0592MHz
uchar i, j, k;
        _nop_();
        _nop_();
        i = 22;
        j = 3;
        k = 227;
        do
                do
                        while (--k);
                } while (--j);
        } while (--i);
void Uart2Isr() interrupt 8
if ((S2CON & 0x01) == 1)
   S2CON &= ~0x01;
         recv_data = S2BUF;
         switch(machine_step)
                 case 0:
                             if(recv_data == 0xAA)//判斷是不是幀頭
                                                 machine_step = 1;
                                                        machine_step = 0;
                                                 break;
                        case 1:
            if(recv_data == 04)//判斷第二個數據
                                                         machine_step = 2;
                                                         recv_cnt = 0;//
                                                        machine_step = 0;
                                                 break;
                 case 2: //開始接收數據(3個字節(jié))
                         xor_check ^= recv_data;
                       recv_buf[recv_cnt] = recv_data;
                         recv_cnt++;
                              if(recv_cnt > 2)
                                                        machine_step = 3;
                machine_step = 2;
                         break;
                        case 3:
                                    if(xor_check == recv_data)
                                                        recv_flag = 1;
                                                machine_step = 0;
                                                recv_cnt = 0;
                                                xor_check = 0;
                                                break;
                        default: break;
if ((S2CON & 0x02)== 1)
S2CON &= ~0x02;
busy = 0;
void Uart2Init()
S2CON = 0x10;
T2L = BRT;
T2H = BRT >> 8;
AUXR = 0x14;
busy = 0;
while (busy)
busy = 1;
S2BUF = dat;
//Delay500ms();
while (*p)
Uart2SEND(*p++);
P0M0 = 0x00;
P0M1 = 0x00;
P1M0 = 0x00;
P1M1 = 0x00;
P2M0 = 0x00;
P2M1 = 0x00;
P3M0 = 0x00;
P3M1 = 0x00;
P4M0 = 0x00;
P4M1 = 0x00;
P5M0 = 0x00;
P5M1 = 0x00;
Uart2Init();
IE2 = 0x01;
EA = 1;
Uart2SENDStr("test");
while (1)
         if(recv_flag == 1)
                 recv_flag = 0;
                // Uart2SEND(recv_data);
         Uart2SENDStr(recv_buf);
ID:123289 發(fā)表于 2021-7-10 08:54 | 只看該作者
1、電腦上的串口助手是不會聽你的協議的,它不受你的協議束縛,所以它能收發(fā)。
2、單片機的串口,硬件上也不受你的協議控制,它是來一個收一個,根本不會聽你協議。
3、你能做的就是,CPU收到數據后,組裝一下,再用軟件與你的協議進行比對,不符合協議的就放棄這組數據,符合的就解析這組數據(執(zhí)行協議內容、指令)。
ID:939710 發(fā)表于 2021-7-10 09:20 | 只看該作者
你定了協議 你軟件要按照協議寫軟件功能啊。。不然協議是用來干啥的。
Powered by 單片機教程網
