單片機源程序如下:
通過按鍵控制3個繼電器開關,并在1602A液晶顯示屏上顯示
#include<reg52.h>
sbit E=P3^4; //1602使能引腳
sbit RW=P3^6; //1602讀寫引腳
sbit RS=P3^5; //1602數據/命令選擇引腳
sbit key_s2 = P3^0;//獨立按鍵S2
sbit key_s3 = P3^1;//獨立按鍵S3
sbit key_s4 = P3^2;//獨立按鍵S4
sbit key_s5 = P3^3;//獨立按鍵S5
sbit M1= P1^0;
sbit M2= P1^1;
sbit M3= P1^2;
sbit beep= P2^3;
uchar j;
uchar flag;//定義標志位
uchar code tab1[]="welcome to you "; //要顯示什么就在這兒改
uchar code tab2[]="enter exit"; //要顯示什么就在這兒改
uchar code tabhang1[]="motor: M1 M2 M3 "; //要顯示什么就在這兒改
uchar code tab00[]="enter 000 exit";
uchar code tab01[]="enter 001 exit";
uchar code tab02[]="enter 010 exit";
uchar code tab03[]="enter 011 exit";
uchar code tab04[]="enter 100 exit";
uchar code tab05[]="enter 101 exit";
uchar code tab06[]="enter 110 exit";
uchar code tab07[]="enter 111 exit";
void delay(uint del) //延時1ms
uint i,j;
for(i=0;i<del;i++)
for(j=0;j<=168;j++);
void writecmd(uchar com) //寫指令
E=0;
RS=0;
RW=0;
P0=com;
delay(2);
E=1;
delay(2);
E=0;
void writedata(uchar dat)//寫數據
E=0;
RS=1;
RW=0;
P0=dat;
delay(2);
E=1;
delay(2);
E=0;
void kaiji() //開機主頁
writecmd(0x80); //告訴液晶在哪個地方顯示 (設置地址指針)//80H+00
for(j=0;j<16;j++) //有16個字符,要循環(huán)16次
writedata(tab1[j]);
delay(2);
writecmd(0x80+0x40); //再設置第二行的起始位置80H+40H
{ writedata(tab2[j]);
delay(2);
void delay1(uint z) //延時子函數
uint x,y;
for(x = z; x > 0; x--)
for(y = 114; y > 0 ; y--);
void init(void) //初始化
delay(15);
writecmd(0x38);
delay(5);
writecmd(0x38);
delay(5);
writecmd(0x38);
writecmd(0x38);
writecmd(0x08);
writecmd(0x01);
writecmd(0x06);
writecmd(0x0c);
M1=0;
M2=0;
M3=0;
kaiji();
void moshi0()
writedata(tabhang1[j]);
delay(2);
writedata(tab00[j]);
delay(2);
if(key_s2==0)
{ delay1(10);
if(key_s2 == 0)
M1=0;
M2=0;
M3=0;
while(!key_s2);//松手檢測
void moshi1()
delay(2);
writedata(tab01[j]);
delay(2);
if(key_s2==0)
{ delay1(10);
if(key_s2 == 0)
M1=0;
M2=0;
M3=1;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
while(!key_s5);//松手檢測
void moshi2()
delay(2);
{ writedata(tab02[j]);
delay(2);
if(key_s2==0)
{ delay1(10);
if(key_s2 == 0)
M1=0;
M2=1;
M3=0;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
void moshi3()
delay(2);
writedata(tab03[j]);
delay(2);
if(key_s2==0)
delay1(10);
if(key_s2 == 0)
M1=0;
M2=1;
M3=1;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
void moshi4()
delay(2);
writedata(tab04[j]);
delay(2);
if(key_s2==0)
{ delay1(10);
if(key_s2 == 0)
M1=1;
M2=0;
M3=0;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
void moshi5()
delay(2);
writedata(tab05[j]);
delay(2);
if(key_s2==0)
{ delay1(10);
if(key_s2 == 0)
M1=1;
M2=0;
M3=1;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
void moshi6()
delay(2);
writedata(tab06[j]);
delay(2);
if(key_s2==0)
delay1(10);
if(key_s2 == 0)
M1=1;
M2=1;
M3=0;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
void moshi7()
delay(2);
writedata(tab07[j]);
delay(2);
if(key_s2==0)
delay1(10);
if(key_s2 == 0)
M1=1;
M2=1;
M3=1;
if(key_s5==0)
{ delay1(10);
if(key_s5== 0)
M1=0;
M2=0;
M3=0;
void keyscan()
if(key_s2==0)
{ delay1(10);
if(key_s2 == 0)
moshi0();
if(key_s4==0)
{ delay1(10);
if(key_s4 == 0)
flag++;
if(flag==9)
flag=1;
while(!key_s4);//松手檢測
if(key_s3==0)
{ delay1(10);
if(key_s3 == 0)
flag--;
if(flag==0)
flag=8;
while(!key_s3);//松手檢測
init();
keyscan();
delay(20);
switch(flag)
case 1: moshi0(); break;
case 2: moshi1(); break;
case 3: moshi2(); break;
case 4: moshi3(); break;
case 5: moshi4(); break;
case 6: moshi5(); break;
case 7: moshi6(); break;
case 8: moshi7(); break;
default:break;
