查看: 2919|回復(fù): 2
LCD1602模塊化代碼,超級(jí)方便,以后再不用打那么長(zhǎng)的代碼LCD1602.c和LCD1602.h
ID:936280 發(fā)表于 2021-7-12 09:40 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
主要內(nèi)容顯示如下:
模塊化LCD1602.c和LCD1602.h如下文件
#include <REGX52.H>
sbit LCD_RW=P2^5;
sbit LCD_RS=P2^6;//1為數(shù)據(jù),0為指令
sbit LCD_E=P2^7;
#define LCD_DataPort P0
void Delay(unsigned char xms)
        unsigned char i=2,j=199;
        while(xms--)
                do
                        while(--j);
                }while(--i);
void LCD_WriteCommand(unsigned char Command)
        LCD_RS=0;
        LCD_RW=0;
        LCD_DataPort=Command;
        LCD_E=1;
        Delay(1);
        LCD_E=0;
        Delay(1);
void LCD_WriteData(unsigned char Data)
        LCD_RS=1;
        LCD_RW=0;
        LCD_DataPort=Data;
        LCD_E=1;
        Delay(1);
        LCD_E=0;
        Delay(1);
void LCD_Init(void)
        LCD_WriteCommand(0x38);
        LCD_WriteCommand(0x0C);
        LCD_WriteCommand(0x06);
        LCD_WriteCommand(0x01);
void LCD_SetAC(unsigned char Line,unsigned char Column)
        LCD_WriteCommand(0x80);
        if(Line==1)
                LCD_WriteCommand(0x80|(Column-1));
        else if(Line==2)
                LCD_WriteCommand(0x80|(Column-1)+0x40);
void LCD_ShowChar(unsigned char Line,unsigned char Column,unsigned char Char)
        LCD_SetAC(Line,Column);
        LCD_WriteData(Char);
void LCD_ShowString(unsigned char Line,unsigned char Column,unsigned char *String)
                if(*String!='\0'){LCD_WriteData(*String);}
                else{break;}
                String++;
int Power(unsigned char X,unsigned char Y)
        unsigned char i;
        int result=1;
        for(i=0;i<Y;i++)
                result*=X;
        return result;
void LCD_ShowNum(unsigned char Line,unsigned char Column,int Number,unsigned char Length)
        unsigned char i;
        for(i=Length;i>0;i--)
                LCD_WriteData('0'+Number/Power(10,i-1)%10);
void LCD_ShowsignedNum(unsigned char Line,unsigned char Column,int Num1,unsigned char Length)
        int Number1;
        unsigned char i;
        if(Num1>0)
                LCD_WriteData('+');
                Number1=Num1;
        else if(Num1<0)
                LCD_WriteData('-');
                Number1=-Num1;
                LCD_WriteData('0'+Number1/Power(10,i-1)%10);
                LCD_Init();
                LCD_ShowChar(1,1,'A');
                LCD_ShowString(1,3,"Hello");
                LCD_ShowNum(1,9,66,2);
                LCD_ShowsignedNum(1,12,-88,2);
LCD.rar
25.4 KB, 下載次數(shù): 74, 下載積分: 黑幣 -5
LCD1602模塊化
收藏收藏5 分享淘帖 頂1 踩
ID:1107186 發(fā)表于 2023-12-30 14:50 | 只看該作者
為什么沒有檢測(cè)BF是否處于忙標(biāo)識(shí)呢
ID:1113035 發(fā)表于 2024-3-14 23:28 來(lái)自觸屏版 | 只看該作者
怪了,俺的lcd函數(shù)為什么不能用
