1、 完成硬件電路的設(shè)計(jì),其中包括單片機(jī)和CC1101模塊的設(shè)計(jì);
2、完成無(wú)線通信模塊的程序設(shè)計(jì)與實(shí)現(xiàn);
部分關(guān)鍵代碼:
#include "main.h" //main.h 中含有TX/RX選擇配置選項(xiàng)
const char *g_Ashining = "433Mtest";
uint8_t g_TxMode = 0, g_UartRxFlag = 0;
uint8_t g_UartRxBuffer[100] = { 0 };
uint8_t g_RF24L01RxBuffer[32] = { 0 };
* @brief :主函數(shù)
* @param :無(wú)
* @note :無(wú)
* @retval:無(wú)
int main(void)
uint8_t i = 0;
//串口初始化
drv_uart_init();
//LED初始化
drv_led_init();
//SPI初始化
drv_spi_init();
//CC1101初始化
CC1101_Init();
for (i = 0; i < 6; i++)
led_red_flashing();
led_green_flashing();
drv_delay_ms(500);
#ifdef __CC1101_TX_TEST__
//按鍵初始化
drv_button_init();
while (1)
//模式切換
if (BUTOTN_PRESS_DOWN == drv_button_check())
g_TxMode = 1 - g_TxMode; //模式會(huì)在 TX_MODE_1( 0 ),TX_MODE_2( 1 )之間切換
//狀態(tài)顯示清零
led_green_off();
led_red_off();
if (TX_MODE_1 == g_TxMode)
led_red_flashing(); //固定發(fā)送模式,紅燈閃爍3次
drv_delay_ms(500);
led_green_flashing(); //串口發(fā)送模式,綠燈閃爍3次
drv_delay_ms(500);
//模式切換
//發(fā)送
CC1101_Tx_Packet((uint8_t *)g_Ashining, 8, ADDRESS_CHECK); //模式1發(fā)送固定字符,1S一包
drv_delay_ms(1000);
led_red_flashing();
//查詢(xún)串口數(shù)據(jù)
i = drv_uart_rx_bytes(g_UartRxBuffer);
if (0 != i)
CC1101_Tx_Packet(g_UartRxBuffer, i, ADDRESS_CHECK);
led_red_flashing();
#else
接收
while (1)
CC1101_Clear_RxBuffer();
CC1101_Set_Mode(RX_MODE);
while (0 != CC1101_GET_GDO0_STATUS());
while (0 == CC1101_GET_GDO0_STATUS());
i = CC1101_Rx_Packet(g_RF24L01RxBuffer); //接收字節(jié)
if (0 != i)
drv_uart_tx_bytes(g_RF24L01RxBuffer, i); //輸出接收到的字節(jié)
#endif
