查看: 3484|回復(fù): 0
單片機(jī)智能電子密碼鎖程序
ID:916624 發(fā)表于 2021-7-16 17:06 | 顯示全部樓層 |閱讀模式
所用模塊含:EEPROM,LCD1602,矩陣按鍵,無源蜂鳴器,LED
  1. #include <reg52.h>
  2. #include <string.h>
  3. #include "eeprom.h"
  4. #include "iic.h"
  5. #include "keyboard.h"
  6. #include "lcd1602.h"
  7. #include "sound.h"
  8. sbit led2=P2^3;                //連D2
  9. sbit led3=P2^2;                //連D4
  10. typedef unsigned char uchar;
  11. typedef unsigned int uint;
  12. void Init_Timer1(void);
  13. uchar code password[]={'1','0','0','8','6'};                //注意要以字符形式存
  14. bit sign;
  15. #define Clear {length=0;password_length=0;num=0;i=0;input_times=0;flag=0;sign=0;led=1;}
  16.
  17. void main()
  18. {
  19.         uchar length,password_length;  //實(shí)際密碼長度,輸入密碼長度
  20.         uchar num,i;
  21.         uchar password_temp[16]={0};                //輸入密碼
  22.         uchar input_times;                //記錄輸入錯誤次數(shù)
  23.         bit flag;
  24.
  25.         label:
  26.         Clear
  27.         length = sizeof(password) / sizeof(password[0]);
  28.         EEPROM_Write(password, 1, length);
  29.   EEPROM_Read(password, 1,length);
  30.   LCD_Init();
  31.         Init_Time0();
  32.         LCD_Clear();
  33.         LCD_Write_String(0,0,"LCD Cipher Lock");
  34.         LCD_Write_String(0,1,"  --Yanglizidi ");
  35.         while(1)
  36.         {
  37.                 num=KeyDriver();
  38.
  39.                 if(num!=0xff)                //如果掃描是按鍵有效值則進(jìn)行處理
  40.                 {
  41.                         led2=1;
  42.                         if(i==0)                //輸入是第一個字符的時(shí)候需要把改行清空,方便觀看密碼
  43.                         {
  44.                                 LCD_Clear();
  45.                                 LCD_Write_String(0,0,"   Yanglizidi   ");
  46.                         }
  47.                         if(i<16)
  48.                         {
  49.                                 password_temp[i]=num;
  50.                                 LCD_Write_Char(i,1,'*');   //輸入的密碼用"*"代替
  51.                         }
  52.                   i++;
  53.                         if( (num=='f') || (i==16) )        // 'f'為確認(rèn)鍵,當(dāng)按下確認(rèn)鍵和密碼長度達(dá)到16,則開始比對
  54.                         {
  55.                                 password_length=i-1;        // 輸入的密碼長度計(jì)算
  56.                                 i=0;
  57.                           if(password_length == length)//長度相等則比較,否則直接輸出錯誤
  58.               {
  59.                                         flag=0;
  60.                                         if(strncmp(password_temp,password,length) == 0)
  61.                                         {
  62.                                                 flag=1;
  63.                                         }
  64.                                  }
  65.                                         if(flag)
  66.                                         {
  67.                                                 LCD_Clear();
  68.                                                 LCD_Write_String(0,0,"   Yanglizidi   ");
  69.                                                 LCD_Write_String(0,1,"Right-->Open!>>> ");
  70.                                                 input_times=0;
  71.                                                 led2=0;
  72.                                                 flag=0;
  73.                                         }
  74.                                         else
  75.                                         {
  76.                                                 LCD_Clear();
  77.                                                 LCD_Write_String(0,0,"   Yanglizidi   ");
  78.                                                 LCD_Write_String(0,1,"Wrong ! Retry !  ");
  79.                                                 input_times++;
  80.                                                 if(input_times==3)
  81.                                                 {
  82.                                                         LCD_Clear();
  83.                                                         LCD_Write_String(0,0," Wrong 3 times !");
  84.                                                         LCD_Write_String(0,1," Wait a minute !");
  85.                                                         Init_Timer1();
  86.                                                         while(1)
  87.                                                         {
  88.        Sound_DIDA();
  89.        if(sign==0)
  90.        goto label;
  91.                                                         }
  92.                                                 }
  93.                                         }
  94.                                 }
  95.                         }
  96.                 }
  97. }
  98. void Init_Timer1()
  99. {
  100.         TMOD |=0x10;
  101.         TH1=0x4c;
  102.         TL1=0x00;          //        定時(shí)50ms
  103.         ET1=1;
  104.         sign=1;
  105.         EA=1;
  106.         TR1=1;
  107.         led3=0;
  108. }
  109. void Timer1() interrupt 3
  110. {
  111.         static uint k;
  112.         TH1=0x4c;
  113.         TL1=0x00;          //        定時(shí)50ms
  114.         k++;
  115.         if(k==1200)                //1 min
  116.         {
  117.                 k=0;
  118.                 TR1=0;
  119.                 sign=0;
  120.                 led3=1;
  121.         }
  122. }
所有代碼51hei附件下載:
LCD1602密碼鎖.7z (37.76 KB, 下載次數(shù): 26)
admin + 50 共享資料的黑幣獎勵!
