* 文件名 : 蜂鳴器唱歌.c
* 描述 : 該程序?qū)崿F(xiàn)控制蜂鳴器演奏音樂。
將跳線把IN5與P1.2連接
#include<reg52.h>
uchar Count;
sbit Speak =P1^3; //蜂鳴器器控制腳
/*以下數(shù)組是音符編碼*/
unsigned char code SONG[] ={ //祝你平安
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00,
//路邊的野華不要采
0x30,0x1C,0x10,0x20,0x40,0x1C,0x10,0x18,0x10,0x20,0x10,0x1C,0x10,0x18,0x40,0x1C,
0x20,0x20,0x20,0x1C,0x20,0x18,0x20,0x20,0x80,0xFF,0x20,0x30,0x1C,0x10,0x18,0x20,
0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,
0x30,0x80,0xFF,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x20,0x1C,0x10,0x18,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,
0x20,0x2B,0x40,0x20,0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,
0x40,0x20,0x20,0x2B,0x20,0x26,0x20,0x20,0x20,0x30,0x80,0x20,0x30,0x1C,0x10,0x20,
0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,0x15,0x1F,
0x05,0x20,0x10,0x1C,0x10,0x20,0x20,0x26,0x20,0x2B,0x20,0x30,0x20,0x2B,0x40,0x20,
0x30,0x1C,0x10,0x18,0x20,0x15,0x20,0x1C,0x20,0x20,0x20,0x26,0x40,0x20,0x20,0x2B,
0x20,0x26,0x20,0x20,0x20,0x30,0x30,0x20,0x30,0x1C,0x10,0x18,0x40,0x1C,0x20,0x20,
0x20,0x26,0x40,0x13,0x60,0x18,0x20,0x15,0x40,0x13,0x40,0x18,0x80,0x00,
* 名稱 : Time0_Init()
* 功能 : 定時(shí)器的初始化,定時(shí)時(shí)間可用光碟中軟件計(jì)算,11.0592MZ晶振,10ms
* 輸入 : 無
* 輸出 : 無
void Time0_Init()
TMOD = 0x01;
IE = 0x82;
TH0 = 0xDC;
TL0 = 0x00;
* 名稱 : Time0_Int()
* 功能 : 定時(shí)器中斷,中斷中實(shí)現(xiàn) Count 加一
* 輸入 : 無
* 輸出 : 無
void Time0_Int() interrupt 1
TH0 = 0xDC;
TL0 = 0x00;
Count++; //長(zhǎng)度加1
* 名稱 : Delay_xMs()
* 功能 : 延時(shí)子程序,經(jīng)過軟件調(diào)試,測(cè)得延時(shí)程序大概為55us.
* 輸入 : x
* 輸出 : 無
void Delay_xMs(uint x)
uint i,j;
for(i=0; i<x; i++)
for(j=0; j<3; j++);
* 名稱 : Play_Song()
* 功能 : 播放蜂鳴器控制程序
* 輸入 : i (選擇播放哪首歌曲,0為“祝你平安”,1為“路邊的野花你不要采”
* 輸出 : 無
void Play_Song(uchar i)
uchar Temp1,Temp2;
uint Addr;
Count = 0; //中斷計(jì)數(shù)器清0
Addr = i * 217;
Temp1 = SONG[Addr++];
if (Temp1 == 0xFF) //休止符
TR0 = 0;
Delay_xMs(100);
else if (Temp1 == 0x00) //歌曲結(jié)束符
return;
Temp2 = SONG[Addr++];
TR0 = 1;
Speak = ~Speak;
Delay_xMs(Temp1);
if(Temp2 == Count)
Count = 0;
break;
* 名稱 : Main()
* 功能 : 主函數(shù)
* 輸入 : 無
* 輸出 : 無
void Main()
Time0_Init(); //定時(shí)器0中斷初始化
Play_Song(0); //Play_Song(0)為祝你平安 Play_Song(1)為路邊的野花你不要裁
