查看: 1887|回復(fù): 1
單片機控制LED流水燈PLUS
ID:954312 發(fā)表于 2021-7-19 18:10 | 顯示全部樓層 |閱讀模式
#include <REGX52.H>
void Delay1ms(unsigned int xms);                //@12.000MHz
                P2=0xFE;//1111 1110
                Delay1ms(1000);
                P2=0xFD;//1111 1101
                Delay1ms(1000);
                P2=0xFB;//1111 1011
                Delay1ms(100);
                P2=0xF7;//1111 0111
                Delay1ms(100);
                P2=0xEF;//1110 1111
                Delay1ms(100);
                P2=0xDF;//1101 1111
                Delay1ms(100);
                P2=0xBF;//1011 1111
                Delay1ms(100);
                P2=0x7F;//0111 1111
                Delay1ms(100);
void Delay1ms(unsigned int xms)                //@12.000MHz
        unsigned char i, j;
        while(xms)
                i = 2;
                j = 239;
                do
                        while (--j);
                } while (--i);
                xms--;
ID:906597 發(fā)表于 2021-12-9 09:21 | 顯示全部樓層
如果其中有一個LED是P4口的第2個LED燈,是不是能改成P4=0xfd?
