查看: 1643|回復(fù): 0
SL8451 6.5V-80V輸入電壓 LED降壓恒壓芯片 超大功率200W LED工作燈專用芯片
General Description
The SL8411 is an average current mode control LED driver IC operating in a constant off-time
mode. SL8411 does not produce a peak-to-average error, and therefore greatly improves accuracy,
line and load regulation of the LED current without any need for loop compensation or high-side
current sensing. The output LED current accuracy is ±2%.
The SL8411 can be powered from an 8.0 - 100V supply. PWM & Linear dimming input is provided
