查看: 3475|回復: 0
單片機+DHT11+DS18B20智能報警源程序
ID:933150 發(fā)表于 2021-7-20 23:17 | 顯示全部樓層 |閱讀模式
      下面是我做的溫度報警,溫度在30-35之間報警,溫度顯示在數碼管上面,dht11模塊的數值顯示在1602液晶顯示屏上面,能夠獲取實時的溫度和適度.
      原理圖如下:
原理圖
原理圖
      部分代碼:
#include "reg52.h"
#include<intrins.h>
#include "XMF_DS18B20_51.h"
sbit beep=P3^0;
sbit Data=P3^7;
uchar rec_dat[16];
sbit lcdrs=P3^5    ;
sbit lcdrw=P3^4;
sbit lcden=P3^3;
const char SMGNoDot_CC[10]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
const char SMGDot_CA[10]={0x40,0x79,0x24,0x30,0x19,0x12,0x02,0x78,0x00,0x10};
unsigned int temp = 0;
unsigned char Send_dat[6] = {0xbf,0x00,0x00,0x00,0x00,0xfb};
void Delay(unsigned int t);
void DelaySMG(unsigned int t);
void DisplaySMG_Bit(unsigned char pos, unsigned char dat);
void ShowTemperature();
void ReadTemperature();
void bee(void);
void write_com(uchar com);
void write_dat(uchar dat);
void init_lcd();
void DHT11_delay_us(uchar n);
void DHT11_delay_ms(uint z);
void DHT11_start();
uchar DHT11_rec_byte();
void DHT11_receive();
{        uchar rec_date[]={'C','R','S',':','1','9','1','1','1','3','0','6','1','3','2'};
  uchar i,a;
   init_lcd();
        ReadTemperature();
        ShowTemperature();
        bee();
        DHT11_delay_ms(100);
    DHT11_receive();
    write_com(0x80);
    for(i=0;i<16;i++)
        write_dat(rec_dat[ i]);
        write_com(0x80+0x40);
        for(a=0;a<17;a++)
        write_dat(rec_date[a]);
    while(t--)
        ShowTemperature();
        DelaySMG(100);
    while(t--);
P0=0x01;
P1=SMGNoDot_CC[temp/100];
DelaySMG(300);
P1=0xff;
P0=0x02;
P1=SMGDot_CA[temp%100/10];
DelaySMG(300);
P1=0xff;
P0=0x04;
P1=SMGNoDot_CC[temp%10];
DelaySMG(300);
P1=0xff;
P0=0x08;
P1=0xc6;
DelaySMG(200);
P1=0xff;
    unsigned char LSB,MSB ;
    Init_DS18B20();
    Write_DS18B20(0xCC);
    Write_DS18B20(0x44);
    Delay(100);
    Init_DS18B20();
    Write_DS18B20(0xBE);
    LSB = Read_DS18B20();
    MSB = Read_DS18B20();
    temp = 0x0000;
    temp = MSB;
    temp <<= 8;
    temp = temp | LSB;
    temp >>= 4;
    temp = temp*10;
    temp = temp + (LSB&0x0f)*0.625;
    if((MSB>>4) == 0x0f)
        temp |= 0x8000;
void bee()
if(2<(temp/100)>=3||(temp%100/10)>4)
  beep=1;
    Delay(100);
    beep=0;
    Delay(100);
beep=0;
          lcdrw=0;
        lcdrs=0;
        P2=com;
         DelaySMG(5);
        lcden=1;
        DelaySMG(5);
        lcden=0;
{       lcdrw=0;
        lcdrs=1;
        P2=dat;
         DelaySMG(5);
        lcden=1;
       DelaySMG(5);
        lcden=0;
void init_lcd()
{       lcdrw=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
    while(--n);
   uint i,j;
   for(i=z;i>0;i--)
      for(j=110;j>0;j--);
void DHT11_start()
   Data=1;
   DHT11_delay_us(2);
   Data=0;
   DHT11_delay_ms(30);
   Data=1;
   DHT11_delay_us(30);
   uchar i,dat=0;
  for(i=0;i<8;i++)
      while(!Data);
      DHT11_delay_us(8);
      dat<<=1;
      if(Data==1)
         dat+=1;
      while(Data);
    return dat;
    uchar R_H,R_L,T_H,T_L,RH,RL,TH,TL,revise;
    DHT11_start();
    if(Data==0)
        while(Data==0);
        DHT11_delay_us(40);
        R_H=DHT11_rec_byte();
        R_L=DHT11_rec_byte();
        T_H=DHT11_rec_byte();
        T_L=DHT11_rec_byte();
        revise=DHT11_rec_byte();
        DHT11_delay_us(25);
        if((R_H+R_L+T_H+T_L)==revise)
            RH=R_H;
            RL=R_L;
            TH=T_H;
            TL=T_L;
        rec_dat[0]='S';
        rec_dat[1]='D';
                rec_dat[2]=':';
        rec_dat[3]='0'+(RH/10);
        rec_dat[4]='0'+(RH%10);
        rec_dat[5]='R';
        rec_dat[6]='H';
                rec_dat[7]=' ';
                rec_dat[8]=' ';
                rec_dat[9]='W';
                rec_dat[10]='D';
                 rec_dat[11]=':';
        rec_dat[12]='0'+(TH/10);
        rec_dat[13]='0'+(TH%10);
        rec_dat[14]='C';
全部代碼51hei附件下載:
Ds18b20報警+DTH11溫濕度顯示.7z (37.38 KB, 下載次數: 38)
參與人數 1黑幣 +40 收起 理由
admin + 40 共享資料的黑幣獎勵!
Powered by 單片機教程網
