電子日歷功能,在電腦屏幕顯示出來(lái),功能如下:
按下key1鍵,顯示當(dāng)前的日期:年/月/日;
按下key2鍵,顯示當(dāng)前的時(shí)間:時(shí)/分/秒;
按下key3鍵,顯示當(dāng)前的日期時(shí)間:年/月/日時(shí)/分/秒;
顯示在數(shù)碼管上.
最好選STC89C52的芯片,因?yàn)榈匠绦蛟O(shè)計(jì)的時(shí)候,用到了三個(gè)定時(shí)器,剛剛好夠用;
仿真原理圖
2021-7-22 22:45 上傳
- #include "public.h"
- //共陽(yáng)極數(shù)碼管顯示編碼
- u16 code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- //數(shù)碼管顯示內(nèi)容
- bit smg_show_flag = 1;
- bit smg_show_flag1 = 1;
- //數(shù)碼管顯示功能,1:數(shù)碼管顯示年月日,2:數(shù)碼管顯示時(shí)分秒,3:串口輸出日期
- u8 smg_show_mode = 1;
- u8 time_buf[50]={0};
- //定義年月日變量
- u16 year = 2021;
- u16 month = 7;
- u16 day = 3;
- //定義時(shí)分秒變量
- u16 hour=3,min=12,sec,ssec;
- //延時(shí)函數(shù)
- void delay(u8 i)
- u8 k;
- for(k=0;k<i;k++);
- 函數(shù)名字:TIM0_IT_Init
- 函數(shù)功能:定時(shí)器0的中斷初始化函數(shù)
- void Timer0Init(void)
- //1.配置定時(shí)器0為工作方式1
- TMOD |= 0x01;
- //2.配置TH和TL確定定時(shí)時(shí)長(zhǎng),50ms
- //單片機(jī)時(shí)鐘頻率為12000000Hz,定時(shí)器時(shí)鐘頻率=單片機(jī)時(shí)鐘頻率/12=1000000Hz
- //50ms = 50/1000 = 1/20s,所以50ms定時(shí)器計(jì)數(shù)值為1000000/20 = 50000
- //由于定時(shí)器是自加計(jì)數(shù)
- TH0 = (65535-50000) / 256;
- TL0 = (65535-50000) % 256;
- //3.啟動(dòng)定時(shí)器0開(kāi)始計(jì)數(shù)
- TR0 = 1;
- //4.清零定時(shí)器0的溢出標(biāo)志位
- TF0 = 0;
- //5.打開(kāi)定時(shí)器0中斷
- ET0 = 1;
- //6.打開(kāi)全局中斷
- EA = 1;
- //定時(shí)器1的初始化函數(shù)
- void Timer1Init()
- TMOD|=0X10;
- TH1=0Xd8;
- TL1=0Xf0;
- ET1=1;
- EA=1;
- TR1=1;
- 函數(shù)名字:smg_display_date
- 函數(shù)功能:數(shù)碼管顯示日期函數(shù)
- 參數(shù):顯示的內(nèi)容標(biāo)志:1:年,0:月和日
- void smg_display_date(u8 showflag)
- u8 i;
- if(showflag == 1)
- for(i=0; i<4; i++)
- switch(i)
- //進(jìn)行數(shù)碼管位選1,點(diǎn)亮第1位數(shù)碼管
- case 0: WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[year/1000%10];break;
- //進(jìn)行數(shù)碼管位選2,點(diǎn)亮第2位數(shù)碼管
- case 1: WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[year/100%10];break;
- //進(jìn)行數(shù)碼管位選3,點(diǎn)亮第3位數(shù)碼管
- case 2: WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[year/10%10];break;
- //進(jìn)行數(shù)碼管位選4,點(diǎn)亮第4位數(shù)碼管
- case 3: WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[year%10];break;
- //點(diǎn)亮延時(shí)2ms
- delay(2000);
- //關(guān)顯示
- SMG_PORT = 0xff;
- else if(showflag == 0)
- switch(i)
- case 0: WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[month/10%10];break;
- case 1: WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[month%10];break;
- case 2: WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[day/10%10];break;
- case 3: WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[day%10];break;
- delay(2000);
- //關(guān)顯示
- SMG_PORT = 0xff;
- void smg_display_time(u8 showflag1)
- u8 i;
- if(showflag1 == 1)
- switch(i)
- case 0: WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[min/10%10];break;
- case 1: WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[min%10];break;
- case 2: WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[sec/10%10];break;
- case 3: WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[sec%10];break;
- delay(2000);
- //關(guān)顯示
- SMG_PORT = 0xff;
- else if(showflag1 == 0)
- switch(i)
- case 0: WEI1 = 0,WEI2 = 1,WEI3 = 1,WEI4 = 1;SMG_PORT = table[hour/10%10];break;
- case 1: WEI1 = 1;WEI2 = 0;WEI3 = 1,WEI4 = 1;SMG_PORT = table[hour%10];break;
- case 2: WEI1 = 1;WEI2 = 1;WEI3 = 0,WEI4 = 1;SMG_PORT = table[min/10%10];break;
- case 3: WEI1 = 1;WEI2 = 1;WEI3 = 1,WEI4 = 0;SMG_PORT = table[min%10];break;
- delay(2000);
- //關(guān)顯示
- SMG_PORT = 0xff;
- 函數(shù)名字:USART_Init
- 函數(shù)功能:串口初始化函數(shù),沒(méi)有開(kāi)啟串口中斷
- void USART_Init(void)
- T2MOD =0; //自動(dòng)重載
- T2CON = 0x30; //T2用做發(fā)送接收時(shí)鐘
- TH2 = 0xFF; //9600波特率,11.0592Mhz晶振
- TL2 = 0xDC;
- RCAP2H = 0xFF;
- RCAP2L = 0xDC;
- SCON = 0x50; //串口方式1,1個(gè)起始位,1個(gè)停止位,8位數(shù)據(jù),可變波特率
- PCON = 0X00; //波特率不加倍
- TR2 = 1; //啟動(dòng)T2
- // ES = 1; //開(kāi)串口中斷
- // EA = 1;
- 函數(shù)名字:Send_Byte
- 函數(shù)功能:發(fā)送字符函數(shù)
- void Send_Byte(u8 da)
- //發(fā)送字符H
- SBUF = da;
- //等待發(fā)送完成
- while(TI != 1);
- //清空發(fā)送標(biāo)志位
- TI = 0;
- 函數(shù)名字:Send_Str
- 函數(shù)功能:發(fā)送封裝發(fā)送字符串函數(shù)符函數(shù)
- void Send_Str(u8 *str)
- u8 i;
- for(i=0; str[i]!='\0'; i++)
- Send_Byte(str[i]);
- //按鍵函數(shù)
- void key_san()
- if(KEY1==0)
- Send_Str(" 當(dāng)前運(yùn)行的功能為A\r\n");
- delay(200);
- if(KEY1==0)
- smg_display_date(smg_show_flag);
- if(KEY2==0)
- Send_Str(" 當(dāng)前運(yùn)行的功能為B\r\n");
- delay(200);
- if(KEY2==0)
- smg_display_time(smg_show_flag1);
- if(KEY3==0)
- Send_Str(" 當(dāng)前運(yùn)行的功能為C\r\n");
- delay(200);
- if(KEY3==0)
- sprintf(time_buf, "當(dāng)前時(shí)間為%d年%d月%d日%d時(shí)%d分%d秒\r\n",year,month,day,hour,min,sec);
- Send_Str(time_buf);
- 函數(shù)名字:timer0_irq
- 函數(shù)功能:定時(shí)器0的中斷服務(wù)函數(shù)
- void timer0_irq(void) interrupt 1
- static u8 i = 0;
- //循環(huán)給定時(shí)器0裝入初值
- //讓計(jì)數(shù)值自加
- i++;
- //40*50=2000ms,即2秒的延時(shí)
- if(i == 40)
- //清空計(jì)數(shù)值,讓程序進(jìn)行下一次1秒的延時(shí)
- i = 0;
- //每2秒鐘切換數(shù)碼管顯示的內(nèi)容
- smg_show_flag=~smg_show_flag;
- smg_show_flag1=~smg_show_flag1;
- //定時(shí)器1的中斷服務(wù)函數(shù)
- void Timer0() interrupt 3
- TH1=0Xd8;
- TL1=0Xf0;
- ssec++;
- if(ssec>=100)
- ssec=0;
- sec++;
- if(sec>=60)
- sec=0;
- min++;
- if(min>=60)
- min=0;
- hour++;
- if(hour>=24)
- hour=0;
2021-7-22 23:33 上傳
仿真工程暫不提供,大家造帖子里面的圖直接畫(huà)一個(gè)就行了
Keil代碼工程51hei附件下載:
電子日歷代碼.7z
(22.57 KB, 下載次數(shù): 24)
2021-7-22 23:34 上傳
點(diǎn)擊文件名下載附件
代工程碼 下載積分: 黑幣 -5
