查看: 4007|回復: 4
基于51單片機的出租車計費系統Proteus仿真原理圖PCB與源程序
ID:576900 發(fā)表于 2021-7-26 20:07 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
用51單片機做了一個模擬計程車計費系統,內容包括AD畫圖,PCB制作,Protues仿真,代碼程序。
電路原理圖如下:
單片機源程序如下:
  1. #include "include.h"
  2. bit fare_flag = 0;//開始計費標志
  3. uchar hour,min,sec;//時鐘三變量
  4. uchar vol,speed;//AD輸出電壓和模擬速度
  5. uchar dang_flag = 0;//檔位
  6. uchar mode  = 1;//數碼管顯示3個界面
  7. uint cost,cost1,time;//計費時間和費用
  8. void Timer0_Init(void);
  9. void main(void)
  10. {
  11.         uchar temp;
  12.
  13.         init_ds1302();
  14.         Timer0_Init();
  15.         pcf8591_write(3);
  16.         LED = 0;
  17.         while(1)
  18.         {
  19.                 sec = Read_Ds1302_Byte(0x81);
  20.                 min = Read_Ds1302_Byte(0x83);
  21.                 hour = Read_Ds1302_Byte(0x85);
  22.
  23.                 vol = pcf8591_read();
  24.                 vol = (float)vol/255*5;
  25.
  26.                 if(fare_flag)
  27.                 {
  28.                         switch(vol)
  29.                         {
  30.                                 case 0: dang_flag = 1; break;
  31.                                 case 1: dang_flag = 2; break;
  32.                                 case 2: dang_flag = 3; break;
  33.                                 case 3: dang_flag = 4; break;
  34.                                 case 4: dang_flag = 5; break;
  35.                         }
  36.                         speed = dang_flag*10;
  37.
  38.                         if(temp != dang_flag)
  39.                         {
  40.                                 time = 0;
  41.                                 cost1 = cost;
  42.                         }
  43.                         temp = dang_flag;
  44.                         cost = dang_flag*10*time/18+cost1;
  45.                 }
  46.
  47.
  48.                 if(key == 1)
  49.                 {
  50.                         key = 0;
  51.                         fare_flag = ~fare_flag;
  52.                         if(fare_flag)
  53.                                 time = 0;
  54.                 }
  55.                 else if(key == 2)
  56.                 {
  57.                         key = 0;
  58.                         mode++;
  59.                         if(mode >= 4)
  60.                                 mode = 1;
  61.                 }
  62.
  63.                 if(mode == 1)
  64.                 {
  65.                         Dis[0] = Tab[hour/16];
  66.                         Dis[1] = Tab[hour%16]|0x80;
  67.                         Dis[2] = Tab[min/16];
  68.                         Dis[3] = Tab[min%16];
  69.                 }
  70.                 else if(mode == 2)
  71.                 {
  72.                         Dis[0] = Tab[dang_flag];
  73.                         Dis[1] = Tab[10];
  74.                         Dis[2] = Tab[speed/10];
  75.                         Dis[3] = Tab[speed%10];
  76.                 }
  77.                 else if(mode == 3)
  78.                 {
  79.                         Dis[0] = Tab[cost/1000%10];
  80.                         Dis[1] = Tab[cost/100%10];
  81.                         Dis[2] = Tab[cost/10%10]|0x80;
  82.                         Dis[3] = Tab[cost%10];
  83.                 }
  84.         }
  85. }
  86. void Timer0_Init(void)
  87. {
  88.         TMOD |= 0x01;//設置為16位計數器
  89.         TH0 = (65535-20000)/256;//時間定為20ms
  90.         TL0 = (65535-20000)%256;
  91.         EA = 1;
  92.         ET0 = 1;
  93.         TR0 = 1;
  94. }
  95. void Interrupt0(void)interrupt 1
  96. {
  97.         static uint t = 0;
  98.
  99.         TH0 = (65535-20000)/256;
  100.         TL0 = (65535-20000)%256;
  101.         if(fare_flag == 1)//如果開始計費
  102.         {
  103.                 LED = 1;
  104.                 t++;
  105.                 if(t>=50)
  106.                 {
  107.                         time++;
  108.                         t = 0;
  109.                 }
  110.         }
  111.         else if(fare_flag == 0)//如果停止計費
  112.         {
  113.                 LED = 0;
  114.                 t= 0;
  115. //                cost = 0;
  116.                 cost1 = 0;
  117.                 time = 0;
  118.                 dang_flag = 0;
  119.                 speed = 0;
  120.         }
  121.
  122.         key2();
  123.         Display();
  124. }
復制代碼
以上資料51hei附件下載:
基于C51的計程車計費系統.zip (2.52 MB, 下載次數: 126)
參與人數 1黑幣 +50 收起 理由
admin + 50 回帖助人的獎勵!
收藏收藏6 分享淘帖 頂 踩
ID:862074 發(fā)表于 2022-6-29 19:49 | 只看該作者
你好,請問代碼里的 mode2 是實現什么功能啊,怎么改預設的時間?
ID:576900 發(fā)表于 2022-8-10 10:37 | 只看該作者
Frode117 發(fā)表于 2022-6-29 19:49
您好,mode=2是在數碼管上顯示檔位和速度的,要調預設時間的話呢,需要到時鐘驅動代碼里面調哦
ID:954635 發(fā)表于 2022-8-29 16:20 | 只看該作者
出租車計費器的按鍵程序不太懂,能否請樓主解答
ID:1078572 發(fā)表于 2023-5-20 19:34 | 只看該作者
請問,pcb里面有pcb原件封裝庫嗎
Powered by 單片機教程網
