查看: 1912|回復(fù): 0
單片機(jī)+ET2046+LCD1602繼電器源程序
ID:955647 發(fā)表于 2021-7-27 21:14 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
sbit RS = P2^6;
sbit RW = P2^5;
sbit EN = P2^7;
sbit DCLK = P3^6;
sbit DIN = P3^4;
sbit CS = P3^5;
sbit DOUT = P3^7;
uint disp[4];
void delayms(uint xms)
     int i,j;
        for(i=xms;i>0;i--)
            for(j=114;j>0;j--);
void write_com(int com)
        EN = 0;
    RS = 0;
    RW = 0;
        P0 = com;
        delayms(1);
    EN = 1;
    delayms(5);
        EN = 0;
void write_date(int date)
        EN = 0;
    RS = 1;
    RW = 0;
        P0 = date;
        delayms(1);
        EN = 1;
        delayms(5);
        EN = 0;
void lcdset()
    write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void display()
        write_com(0x80);
        write_date((disp[0])+'0');
        write_com(0x81);
        write_date((disp[1])+'0');
        write_com(0x82);
        write_date((disp[2])+'0');
        write_com(0x83);
        write_date((disp[3])+'0');
void SPI_Write(uchar dat)
        uchar i;
        DCLK = 0;
        for(i=0; i<8; i++)
                DIN = dat >> 7;
                dat <<= 1;
                DCLK = 0;
                DCLK = 1;
uint SPI_Read(void)
        uint i, dat = 0;
        DCLK = 0;
        for(i=0; i<12; i++)
                dat <<= 1;
                DCLK = 1;
                DCLK = 0;
                dat |= DOUT;
        return dat;
uint Read_AD_Data(uchar cmd)
        uchar i;
        uint AD_Value;
        DCLK = 0;
        CS  = 0;
        SPI_Write(cmd);
        for(i=6; i>0; i--);
        DCLK = 1;
        _nop_();
        _nop_();
        DCLK = 0;
        _nop_();
        _nop_();
        AD_Value=SPI_Read();
        CS = 1;
        return AD_Value;
void datapros()
        uint temp;
        static uint i;
        if(i==50)
                i=0;
                temp = Read_AD_Data(0x94);
        i++;
        disp[0]= temp/1000;
        disp[1]= temp%1000/100;
        disp[2]= temp%1000%100/10;
        disp[3]=temp%1000%100%10;
        lcdset();
           datapros();
       display();
