查看: 1798|回復(fù): 0
超聲波測距代碼
ID:955647 發(fā)表于 2021-7-27 21:19 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#define LCD1602_DB  P0
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
sbit Trig = P2^1;
sbit Echo = P2^0;
uchar PuZh[]="The Distance: ";
uchar code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9','.','-','C','M'};
void Read_Busy()
         uchar sta;
    LCD1602_DB = 0xff;
    LCD1602_RS = 0;
    LCD1602_RW = 1;
    do
        LCD1602_EN = 1;
        sta = LCD1602_DB;
        LCD1602_EN = 0;
    }while(sta & 0x80);
void delayms(uint ms)
        uchar i=100,j;
        for(;ms;ms--)
                while(--i)
                        j=10;
                        while(--j);
void Lcd1602_Write_Cmd(uchar cmd)
    Read_Busy();
    LCD1602_RS = 0;
    LCD1602_RW = 0;
    LCD1602_DB = cmd;
    LCD1602_EN = 1;
    LCD1602_EN = 0;
void Lcd1602_Write_Data(uchar dat)
      Read_Busy();
      LCD1602_RS = 1;
      LCD1602_RW = 0;
      LCD1602_DB = dat;
      LCD1602_EN = 1;
      LCD1602_EN = 0;
        void LcdSetCursor(uchar x,uchar y)
    uchar addr;
    if(y == 0)
        addr = 0x80 + x;
        addr = 0x40 + x;
    Lcd1602_Write_Cmd(addr|0x80);
        void DisplayOneChar(uchar X, unsigned char Y, uchar DData)
        Y &= 0x1;
        X &= 0xF;
        if (Y) X |= 0x40;
        X |= 0x80;
        Lcd1602_Write_Cmd(X);
        Lcd1602_Write_Data(DData);
void LcdShowStr(uchar x,uchar y,uchar *str)
    LcdSetCursor(x,y);
    while(*str != '\0')
        Lcd1602_Write_Data(*str++);
void InitLcd1602()
    Lcd1602_Write_Cmd(0x38);
    Lcd1602_Write_Cmd(0x0c);
    Lcd1602_Write_Cmd(0x06);
    Lcd1602_Write_Cmd(0x01);
static uchar DisNum = 0;
       uint  time=0;
           unsigned long S=0;
           bit      flag =0;
           uchar disbuff[4]           ={ 0,0,0,0,};
void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.7)/100;
         if((S>=700)||flag==1)
          flag=0;
          DisplayOneChar(0, 1, ASCII[11]);
          DisplayOneChar(1, 1, ASCII[10]);
          DisplayOneChar(2, 1, ASCII[11]);
          DisplayOneChar(3, 1, ASCII[11]);
          DisplayOneChar(4, 1, ASCII[12]);
          disbuff[0]=S/100;
          disbuff[1]=S%100/10;
          disbuff[2]=S%100%10;
          DisplayOneChar(0, 1, ASCII[disbuff[0]]);
          DisplayOneChar(2, 1, ASCII[disbuff[1]]);
          DisplayOneChar(3, 1, ASCII[disbuff[2]]);
                DisplayOneChar(5, 1, ASCII[13]);
void zd0() interrupt 1
    flag=1;
void  StartModule()
          Trig=1;
          _nop_();  _nop_(); _nop_(); _nop_();
          Trig=0;
        void main(void)
         TMOD=0x01;
         TH0=0;
         TL0=0;
         ET0=1;
         EA=1;
  InitLcd1602();
        LcdShowStr(0,0,PuZh);
                 StartModule();
             while(!Echo);
             TR0=1;
             while(Echo);
             TR0=0;
         Conut();
                 delayms(80);
