STM32單片機(jī)源程序如下:
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "usart.h"
- #include "timer.h"
- #include "motor.h"
- #include "sg90.h"
- #include "HCSR.h"
- #include "oled.h"
- #include "beep.h"
- #include "motorpwm.h"
- #include "TCRT.h"
- #define motor1_PWM TIM1->CCR1
- #define motor3_PWM TIM1->CCR3
- #define motor2_PWM TIM1->CCR2
- #define motor4_PWM TIM1->CCR4
- // motor11=1; PA7
- // motor12=0; PA6
- // motor21=1; PB7
- // motor21=0; PB6
- extern u8 res;
- int main(void)
- int len;
- delay_init(); //延時(shí)函數(shù)初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
- uart_init(9600); //串口初始化為9600
- My_USART2_Init();
- OLED_Init();
- OLED_Clear();
- motor_pwm_init();
- Motor_Init();
- TIM3_PWM_Init(199,7199); //不分頻。T為20ms,這樣的配置就是為了讓輸出的PWM信號(hào)達(dá)到舵機(jī)要求的20ms周期。
- SG90_pwm_init();
- TCRT_config(); //循跡模塊初始化
- CH_SR04_Init();
- motor1_PWM=0;motor3_PWM =0;motor21=0; motor22=0;
- // motor1_PWM=10;motor2_PWM=10;motor3_PWM =10;motor4_PWM =10;
- beep_Init();
- while(1)
- len =Senor_Using();
- // printf("距離為:%dcm\n",length);
- OLED_ShowCHinese(0,0,0);//前
- OLED_ShowCHinese(18,0,1);//方
- OLED_ShowCHinese(36,0,2);//距
- OLED_ShowCHinese(54,0,3);//離
- OLED_ShowCHinese(72,0,4);//為
- OLED_Float(3,3,len,1);
- delay_ms(20);
- // if(res=='1'){motor11=1; motor12=0;motor21=1; motor22=0;TIM_SetCompare2(TIM3,175);}//前進(jìn)右轉(zhuǎn)90
- if(res=='1')//避障
- float length_res[5]; //用來存放測距結(jié)果
- delay_ms(20);
- SG90_Front; //舵機(jī)擺正
- delay_ms(100);
- length_res[0] =Senor_Using(); //測前方距離放在數(shù)組里
- delay_ms(100);
- if(length_res[0]>40.00) //如果前方距離大于30cm 前進(jìn)
- motor1_PWM=70;motor3_PWM =70; motor21=0; motor22=0;
- SG90_Front;
- TIM_SetCompare2(TIM3,185); //方向回中
- if(length_res[0]<40.00) //如果前方距離小于30厘米 停車測左右距離
- beep=1;
- SG90_Left_45; //舵機(jī)左轉(zhuǎn)45度測距
- delay_ms(700);beep=0;
- length_res[1] =Senor_Using(); //把測量結(jié)果放進(jìn)數(shù)組
- SG90_Right_45; //舵機(jī)右轉(zhuǎn)45度測距
- delay_ms(700);
- length_res[4] =Senor_Using(); //把測量結(jié)果放進(jìn)數(shù)組
- delay_ms(100);
- if(length_res[1]>length_res[4]) //如果左邊的距離大于右邊的距離
- do //舵機(jī)擺正
- SG90_Front;
- delay_ms(10);
- length_res[0] =Senor_Using(); //重復(fù)測前方的距離同時(shí)左轉(zhuǎn)
- delay_ms(10);
- TIM_SetCompare2(TIM3,195);
- motor1_PWM=75;motor3_PWM =75; motor21=0; motor22=0;
- while(length_res[0]<40.00); //一直轉(zhuǎn)到前方距離大于30cm
- if(length_res[1]<length_res[4]) //如果右邊的距離大于左邊的距離
- do
- SG90_Front;
- delay_ms(10);
- delay_ms(10);
- TIM_SetCompare2(TIM3,175);
- if(res=='2')
- if(Senor_Using()<30)
- { beep=1;
- delay_ms(500);
- beep=0;motor1_PWM=0;motor3_PWM =0;motor21=0; motor22=0;delay_ms(300);}motor1_PWM=75;motor3_PWM =65;motor21=0; motor22=0; TIM_SetCompare2(TIM3,180);}//前進(jìn)右轉(zhuǎn)45
- if(res=='3')
- {beep=1;
- delay_ms(500);
- beep=0;motor1_PWM=0;motor3_PWM =0;motor21=0; motor22=0;delay_ms(600);
- motor1_PWM=75;motor3_PWM =75;motor21=0; motor22=0; TIM_SetCompare2(TIM3,185);}//直行
- if(res=='4')
- {beep=1;
- delay_ms(500);
- beep=0;motor1_PWM=0;motor3_PWM =0;motor21=0; motor22=0;delay_ms(300);}motor1_PWM=65;motor3_PWM =75;motor21=0; motor22=0; TIM_SetCompare2(TIM3,190);}//前進(jìn)左轉(zhuǎn)45
- // if(res=='5'){motor11=1; motor12=0;motor21=1; motor22=0;TIM_SetCompare2(TIM3,195);}//前進(jìn)左轉(zhuǎn)90
- if(res=='0'){TIM_SetCompare2(TIM3,185);motor1_PWM=0;motor3_PWM =0;;motor21=0; motor22=0;}
- if(res=='6'){motor1_PWM=30;motor3_PWM =30;motor21=1; motor22=1;TIM_SetCompare2(TIM3,185);}//后退
- if(res=='7'){motor1_PWM=30;motor3_PWM =30;motor21=1; motor22=1;TIM_SetCompare2(TIM3,180);}//后退右轉(zhuǎn)45
- if(res=='8'){motor1_PWM=30;motor3_PWM =30;motor21=1; motor22=1;TIM_SetCompare2(TIM3,190);}//后退左轉(zhuǎn)45
- if(res=='5')
- Read_TCRT_Date(); //讀循跡線值
- TIM_SetCompare2(TIM3,185); //回中
- if(L==1&&M==1&&R==1)//11
- motor1_PWM=75;motor3_PWM =75;motor21=0; motor22=0; //如果都沒有讀取到黑線,直走
- TIM_SetCompare2(TIM3,0);
- delay_ms(10);
- if(L==1&&M==0&&R==1)//101
- motor1_PWM=75;motor3_PWM =75;motor21=0; motor22=0; //如果中間一個(gè)讀取到黑線,直走
- delay_ms(10);
- if(L==1&&M==1&&R==0)//110
- motor1_PWM=75;motor3_PWM =75;motor21=0; motor22=0; //直走
- TIM_SetCompare2(TIM3,179); //如果右邊讀取到黑線,右轉(zhuǎn)
- delay_ms(10);
- if(L==0&&M==1&&R==1)//011
- TIM_SetCompare2(TIM3,191); //如果左邊讀取到黑線,左轉(zhuǎn)
- delay_ms(10);
- if(L==0&&M==0&&R==0)//000
- //在周期20ms的PWM信號(hào)中,不同的脈寬對(duì)應(yīng)舵機(jī)不同的轉(zhuǎn)動(dòng)角度,在0.5ms-2.5ms間有效
- // TIM_SetCompare2(TIM4,175);//總共計(jì)數(shù)200,前面設(shè)置的模式是計(jì)數(shù)在比較值之后才是高電平
- //也就是高電平的時(shí)間是[(200-175)/200]*20ms=2.5ms,即轉(zhuǎn)過360度,180度舵機(jī)依次類推
2021-7-28 19:10 上傳
所有程序51hei附件下載:
stm32利用藍(lán)牙控制舵機(jī)1.3.7z
(215.34 KB, 下載次數(shù): 31)
2021-7-28 19:11 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
