查看: 3211|回復(fù): 3
分享一個(gè)基于MSP430F149的步進(jìn)電機(jī)入門教程,附Lv8731驅(qū)動(dòng)芯片及驅(qū)動(dòng)手冊(cè)
ID:914689 發(fā)表于 2021-8-4 21:05 | 顯示全部樓層 |閱讀模式
#include  <msp430x14x.h>
#define Step_A P4OUT=0xfe;
#define Step_B P4OUT=0xfd;
#define Step_C P4OUT=0xfb;
#define Step_D P4OUT=0xf7;
#define Step_AB P4OUT=0xfc;
#define Step_BC P4OUT=0xf9;
#define Step_CD P4OUT=0xf3;
#define Step_DA P4OUT=0xf6;
#define Step_OFF P4OUT=0xf0;
unsigned char a[4]={0xfe,0xfd,0xfb,0xf7},i;
void DelayUs2x(unsigned char t);
void DelayMs(unsigned char t);
/********************主函數(shù)**********************/
void main(void)
       unsigned char temp;
       unsigned int Speed;               //旋轉(zhuǎn)一周時(shí)間
       Speed=4;
       WDTCTL = WDTPW + WDTHOLD;                    // 關(guān)狗
    /*------選擇系統(tǒng)主時(shí)鐘為8MHz-------*/
       BCSCTL1 &= ~XT2OFF;                          //打開XT2高頻晶體振蕩器
       do
        IFG1 &= ~OFIFG;                             //清除晶振失敗標(biāo)志
        for (temp = 0xFF; temp > 0; temp--);        //等待8MHz晶體起振
       while ((IFG1 & OFIFG));                      //等待晶振運(yùn)行起來
       BCSCTL2 |= SELM1 + SELS + DIVM_3 +DIVS_3;
       P1DIR = 0xff;P1OUT = 0xff;
       P2DIR = 0xff;P2OUT = 0xff;
       P3DIR = 0xff;P3OUT = 0xff;
       P4DIR = 0xff;P4OUT = 0xff;
       P5DIR = 0xff;P5OUT = 0xff;
       P6DIR = 0xff;P6OUT = 0xff;
            /*Step_AB
            DelayMs(Speed);                    //電機(jī)轉(zhuǎn)速調(diào)整,數(shù)字越小,轉(zhuǎn)速越快
            Step_BC                           //四相八拍運(yùn)行方式即 A-AB-B-BC-C-CD-D-DA-A.
            DelayMs(Speed);
            Step_CD
            DelayMs(Speed);
            Step_DA
            DelayMs(Speed);*/
                 /*Step_A
                 Step_AB                            //四相四拍運(yùn)行方式
                 DelayMs(Speed);
                 Step_B
                 DelayMs(Speed);
                 Step_BC
                 DelayMs(Speed);
                 Step_C
                 DelayMs(Speed);
                 Step_CD
                 DelayMs(Speed);
                 Step_D
                 DelayMs(Speed);
                 Step_DA
                 DelayMs(Speed);*/
                 Step_DA
                 Step_D                            //四相四拍運(yùn)行方式
                 DelayMs(Speed);
                 Step_CD
                 DelayMs(Speed);
                 Step_C
                 DelayMs(Speed);
                 Step_BC
                 DelayMs(Speed);
                 Step_B
                 DelayMs(Speed);
                 Step_AB
                 DelayMs(Speed);
                 Step_A
                 DelayMs(Speed);
          /*for(i=0;i<4;i++)
            P4OUT=a[ i];
            DelayMs(Speed);
uS延時(shí)函數(shù),大致延時(shí)
長(zhǎng)度 T=tx2+5 uS
while(--t);
mS延時(shí)函數(shù)
while(t--)
     //大致延時(shí)1mS
     DelayUs2x(245);
     DelayUs2x(245);
430F149步進(jìn).rar
5.03 MB, 下載次數(shù): 18, 下載積分: 黑幣 -5
ID:966040 發(fā)表于 2021-9-14 17:34 | 顯示全部樓層
有MSP430F149的中文用戶手冊(cè)嗎?
ID:966040 發(fā)表于 2021-9-14 17:35 | 顯示全部樓層
MSP430F149的用戶手冊(cè)有嗎?
ID:966040 發(fā)表于 2021-9-15 20:29 | 顯示全部樓層
你們用的啥IDE?
