查看: 3044|回復(fù): 0
ESP8266 RTOS CHQ1838接收遙控數(shù)據(jù)命令源程序
ID:645730 發(fā)表于 2021-8-20 17:35 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
CHQ1838引腳示意圖
源程序如下:
  1. #include <stdio.h>
  2. #include <string.h>
  3. #include <stdlib.h>
  4. #include "freertos/FreeRTOS.h"
  5. #include "freertos/task.h"
  6. #include "freertos/queue.h"
  7. #include "driver/gpio.h"
  8. #include "esp_log.h"
  9. #include "esp_system.h"
  10. static const char *TAG = "main";
  11. #define GPIO_INPUT_IO_2     2   // D4
  12. #define GPIO_INPUT_PIN_SEL  (1ULL<<GPIO_INPUT_IO_2)
  13. static xQueueHandle gpio_evt_queue = NULL;
  14. extern uint32_t esp_get_time(void);        // 獲取當(dāng)前啟動毫秒數(shù)
  15. static void gpio_task_example(void *arg)
  16. {
  17.     uint32_t interval_us,ms;
  18.     for (;;) {
  19.         if (xQueueReceive(gpio_evt_queue, &interval_us, portMAX_DELAY)) {
  20.             // ESP_LOGI(TAG, "GPIO failling edge interval time: %d\n", interval_us);
  21.             // printf("data is: ");
  22.             ms = interval_us / 100;
  23.             if (ms <= 150 && ms >= 120 )    // 在 12 - 15 ms之間認(rèn)為是前導(dǎo)碼
  24.             {
  25.                 printf("\n start ");
  26.             }
  27.             else if (ms < 20 && ms >= 10)  // 在 1 - 2 ms之間認(rèn)為是0
  28.             {
  29.                 printf("0 ");
  30.             }
  31.             else if (ms <= 30 && ms >= 20)  // 在2 - 3 ms之間認(rèn)為是1
  32.             {
  33.                 printf("1 ");
  34.             }
  35.         }
  36.     }
  37. }
  38. uint32_t first_time = 0, second_time = 0,interval_time = 0;
  39. static void monitor_chq1838_break(void *arg){
  40.     first_time = second_time;
  41.     second_time = esp_get_time();
  42.     interval_time = second_time - first_time;
  43.     xQueueSendFromISR(gpio_evt_queue, &interval_time, NULL);
  44. }
  45. void app_main(void)
  46. {
  47.     gpio_config_t io_conf;
  48.     io_conf.intr_type = GPIO_INTR_NEGEDGE;
  49.     io_conf.mode = GPIO_MODE_INPUT;
  50.     io_conf.pin_bit_mask = GPIO_INPUT_PIN_SEL;
  51.     io_conf.pull_down_en = 0;
  52.     io_conf.pull_up_en = 1;
  53.     gpio_config(&io_conf);
  54.     gpio_evt_queue = xQueueCreate(100, sizeof(uint32_t));
  55.     xTaskCreate(gpio_task_example, "gpio_task_example", 2048, NULL, 10, NULL);
  56.     gpio_install_isr_service(0);
  57.     gpio_isr_handler_add(GPIO_INPUT_IO_2, monitor_chq1838_break, (void *) GPIO_INPUT_IO_2);
  58.     while (1) {
  59.         vTaskDelay(1000 / portTICK_RATE_MS);
  60.     }
  61. }
手冊下載:
CHQ1838.PDF (806.72 KB, 下載次數(shù): 13)
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎勵!
