查看: 3397|回復(fù): 2
51單片機(jī)豆?jié){機(jī)仿真電路+程序源碼
ID:663775 發(fā)表于 2021-8-24 15:41 | 顯示全部樓層 |閱讀模式
豆?jié){機(jī)仿真
豆?jié){機(jī)仿真
豆?jié){機(jī)程序
豆?jié){機(jī)程序
豆?jié){機(jī)仿真電路圖+程序源碼
  u8 jiyi=0;
  beep=1;
  Motor=0;//關(guān)電機(jī)
  M_LED=1;//關(guān)電機(jī)指示燈
  LED=0;
  LCD_Initial();
  LCD_Print(2,0, "soybean milk");
  LCD_Print(4,1, "machine");
  delayms(300);
  LCD_Write(0x00, 0x01);//清屏
  LCD_Print(0,0, "Please Add Water");
  LCD_Print(0,1, "Percentage:000  ");
  TIME_INIT_0();//開定時(shí)器
    KEY();
/***********************************************漿液溢出***********************************************/
        if(yichu_flag==1)
          LCD_Print(0,0,"Foam Over");
          LCD_Print(0,1,"Time:  S");
          jiyi=Star_Flag;//記錄系統(tǒng)運(yùn)行狀態(tài)
          Star_Flag=0;
          Timeyichu_Set=10;//設(shè)置10秒消泡沫
          yichu_flag=2;
        if(yichu_flag==2)
          Timeyichu=yichu_fen*60+yichu_miao;//計(jì)算時(shí)間
      dis[1]=Timeyichu/10+'0';
      dis[2]=Timeyichu%10+'0';
      LCD_Print(5,1,&dis[1]);
      LCD_Print(6,1,&dis[2]);
          if(Timeyichu>=Timeyichu_Set)//達(dá)到預(yù)設(shè)
            Timeyichu_Set=0;
            yichu_haomiao=0;
            yichu_miao=0;
            yichu_fen=0;
                  yichu_flag=0;
                if(jiyi%2==0)
                  Star_Flag=jiyi-1;//恢復(fù)系統(tǒng)運(yùn)行狀態(tài)
                    Star_Flag=jiyi;//恢復(fù)系統(tǒng)運(yùn)行狀態(tài)
/***************************************1600W加熱到80℃*******************************************/
        if(Star_Flag==1)//正常啟動(dòng)
          LCD_Print(0,0,"Power:1600W");
          LCD_Print(0,1,"Tempe:  ");
          LCD_Print(10,1,WD);
          Star_Flag=2;//將進(jìn)入1600W加熱到80度
        if(Star_Flag==2)//1600W加熱到80度
                if(temp>0&&temp<=1600)
                    chuli(temp,Temp_Dis);          //數(shù)據(jù)處理
              LCD_PutChar(6,1,&Temp_Dis[0]);
                    LCD_PutChar(7,1,&Temp_Dis[1]);
                  LCD_Print(8,1,".");
          LCD_PutChar(9,1,&Temp_Dis[2]);
                  if(temp>800)
                    break;
      haomiao=0;
          miao=0;
          fen=0;
          Star_Flag=3;//將進(jìn)入啟動(dòng)電機(jī)打漿,加熱功率1600W
/****************************************打漿120S不加熱*****************************************/
        if(Star_Flag==3)//啟動(dòng)電機(jī)打漿120s
          Motor=1;//啟動(dòng)電機(jī)打漿
          M_LED=0;//開電機(jī)指示燈
          LCD_Print(0,0,"No Heating");
          LCD_Print(0,1,"Motor Star:   S");
          Time_Set=120;//設(shè)定電機(jī)打漿120秒
          Star_Flag=4;//將進(jìn)入等待打漿時(shí)間到
        if(Star_Flag==4)//等待打漿時(shí)間到
          Time=fen*60+miao;//計(jì)算時(shí)間
          dis[0]=Time/100+'0';
      dis[1]=Time%100/10+'0';
      dis[2]=Time%100%10+'0';
          LCD_Print(11,1,&dis[0]);
      LCD_Print(12,1,&dis[1]);
      LCD_Print(13,1,&dis[2]);
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                  Star_Flag=5;//將進(jìn)入800W加熱,打漿同時(shí)進(jìn)行,60s
/*****************************************800W煮漿同時(shí)打漿*****************************************/
        if(Star_Flag==5)//800W加熱,打漿同時(shí)進(jìn)行,60s
          LCD_Print(0,0,"Power:800W");
          Time_Set=60;//設(shè)定800W加熱同時(shí)電機(jī)打漿60秒
          Star_Flag=6;//將進(jìn)入等待煮漿打漿時(shí)間到
        if(Star_Flag==6)//等待煮漿打漿時(shí)間到
      dis[1]=Time/10+'0';
      dis[2]=Time%10+'0';
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                Motor=0;//關(guān)閉電機(jī)打漿
                  Star_Flag=7;//將進(jìn)入煮漿
/*******************************************450W煮漿60s,350W煮漿120s*****************************************/
        if(Star_Flag==7)//煮漿
          Time_Set=180;//設(shè)定180s煮漿
          Star_Flag=8;//將進(jìn)入等待煮漿打漿時(shí)間到
        if(Star_Flag==8)//煮漿
          if(Time<=60)//400W煮漿
             LCD_Print(0,0,"Power:400W");
        dis[1]=(Time)/10+'0';
        dis[2]=(Time)%10+'0';
        LCD_Print(6,1,&dis[1]);
        LCD_Print(7,1,&dis[2]);
          if(Time>60&&Time<=180)//350W煮漿
                   LCD_Print(0,0,"Power:350W");
                dis[0]=(Time-60)/100+'0';
        dis[1]=(Time-60)%100/10+'0';
        dis[2]=(Time-60)%100%10+'0';
        LCD_Print(5,1,&dis[0]);
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                  Star_Flag=9;//將進(jìn)結(jié)束
/********************************************結(jié)束10s**************************************/
        if(Star_Flag==9)//結(jié)束
          LCD_Print(0,0,"End of Run");
          Time_Set=10;//設(shè)定10s
          Star_Flag=10;
        if(Star_Flag==10)//結(jié)束
      dis[1]=Time/10+'0';
      dis[2]=Time%10+'0';
          if(Time>=Time_Set)
                  Time_Set=0;
            haomiao=0;
            miao=0;
            fen=0;
                  Star_Flag=11;//將進(jìn)入蜂鳴器
/********************************************10后報(bào)警*******************************************/
        if(Star_Flag==11)//蜂鳴器
          Time_Set=2;//設(shè)定10s
          Star_Flag=12;
        if(Star_Flag==12)//蜂鳴器
          if(Time>0&&Time<=1)
                  beep=0;
          if(Time>1&&Time<=2)
                  beep=1;
          if(Time>=Time_Set)
            haomiao=0;
            miao=0;
            fen=0;
Proteus7.5版本的仿真工程dsn文件和代碼下載: 豆?jié){機(jī).zip (233.21 KB, 下載次數(shù): 127)
ID:130230 發(fā)表于 2021-8-24 17:14 | 顯示全部樓層
建議模塊化編程,魔鬼數(shù)字用宏替代增加代碼可讀性。真正工作后就能體會(huì)到,好的程序員不是能實(shí)現(xiàn)多么牛叉的功能,而是把簡(jiǎn)單的功能實(shí)現(xiàn)的清晰明了。程序可維護(hù)性,健壯性都是靠層次和規(guī)范來保證的。
參與人數(shù) 1黑幣 +20 收起 理由
ID:1024528 發(fā)表于 2022-5-7 15:19 | 顯示全部樓層
這個(gè)程序前面定義的部分能發(fā)一下嗎
