今天解決了一個之前困擾很久的1E狀態(tài)的問題, 把RX, TX和EXIT+RX的模式都跑通了.
代碼基于HML_FwLib_STC12, 在倉庫的examples里, 鏈接地址
使用的是STC12的硬件SPI的方式, 不是軟件模擬的SPI, 主體代碼如下, 將 CURRENT_MODE 改成不同的值, 會分別啟動到RX, TX和EXTI RX這三種模式, 運行時需要兩塊NRF24L01配合測試.
- * \file spi_nrf24l01_tx.c
- * \date
- * \brief Example code of SPI driving NRF24L01 module in TX mode
- * \note Pin connection:
- * P1_4(SS, Ignored) => CSN,
- * P1_5(MOSI) => MOSI,
- * P1_6(MISO) => MISO,
- * P1_7(SPCLK) => CLK,
- * P3_2(INT0) => IRQ,
- * P3_7(IO) => CE,
- * \version v0.1
- * \ingroup example
- * \remarks test-board: Minimum System; test-MCU: STC12C5AF56S2
- * header file *
- #include "hml/hml.h"
- #include <stdio.h>
- /********** SPI(nRF24L01) commands ***********/
- #define NRF24_CMD_REGISTER_R 0x00 // Register read
- #define NRF24_CMD_REGISTER_W 0x20 // Register write
- #define NRF24_CMD_ACTIVATE 0x50 // (De)Activates R_RX_PL_WID, W_ACK_PAYLOAD, W_TX_PAYLOAD_NOACK features
- #define NRF24_CMD_RX_PLOAD_WID_R 0x60 // Read RX-payload width for the top R_RX_PAYLOAD in the RX FIFO.
- #define NRF24_CMD_RX_PLOAD_R 0x61 // Read RX payload
- #define NRF24_CMD_TX_PLOAD_W 0xA0 // Write TX payload
- #define NRF24_CMD_ACK_PAYLOAD_W 0xA8 // Write ACK payload
- #define NRF24_CMD_TX_PAYLOAD_NOACK_W 0xB0 //Write TX payload and disable AUTOACK
- #define NRF24_CMD_FLUSH_TX 0xE1 // Flush TX FIFO
- #define NRF24_CMD_FLUSH_RX 0xE2 // Flush RX FIFO
- #define NRF24_CMD_REUSE_TX_PL 0xE3 // Reuse TX payload
- #define NRF24_CMD_LOCK_UNLOCK 0x50 // Lock/unlock exclusive features
- #define NRF24_CMD_NOP 0xFF // No operation (used for reading status register)
- // SPI(nRF24L01) register address definitions
- #define NRF24_REG_CONFIG 0x00 // Configuration register
- #define NRF24_REG_EN_AA 0x01 // Enable "Auto acknowledgment"
- #define NRF24_REG_EN_RXADDR 0x02 // Enable RX addresses
- #define NRF24_REG_SETUP_AW 0x03 // Setup of address widths
- #define NRF24_REG_SETUP_RETR 0x04 // Setup of automatic re-transmit
- #define NRF24_REG_RF_CH 0x05 // RF channel
- #define NRF24_REG_RF_SETUP 0x06 // RF setup
- #define NRF24_REG_STATUS 0x07 // Status register
- #define NRF24_REG_OBSERVE_TX 0x08 // Transmit observe register
- #define NRF24_REG_RPD 0x09 // Received power detector
- #define NRF24_REG_RX_ADDR_P0 0x0A // Receive address data pipe 0
- #define NRF24_REG_RX_ADDR_P1 0x0B // Receive address data pipe 1
- #define NRF24_REG_RX_ADDR_P2 0x0C // Receive address data pipe 2
- #define NRF24_REG_RX_ADDR_P3 0x0D // Receive address data pipe 3
- #define NRF24_REG_RX_ADDR_P4 0x0E // Receive address data pipe 4
- #define NRF24_REG_RX_ADDR_P5 0x0F // Receive address data pipe 5
- #define NRF24_REG_TX_ADDR 0x10 // Transmit address
- #define NRF24_REG_RX_PW_P0 0x11 // Number of bytes in RX payload in data pipe 0
- #define NRF24_REG_RX_PW_P1 0x12 // Number of bytes in RX payload in data pipe 1
- #define NRF24_REG_RX_PW_P2 0x13 // Number of bytes in RX payload in data pipe 2
- #define NRF24_REG_RX_PW_P3 0x14 // Number of bytes in RX payload in data pipe 3
- #define NRF24_REG_RX_PW_P4 0x15 // Number of bytes in RX payload in data pipe 4
- #define NRF24_REG_RX_PW_P5 0x16 // Number of bytes in RX payload in data pipe 5
- #define NRF24_REG_FIFO_STATUS 0x17 // FIFO status register
- #define NRF24_REG_DYNPD 0x1C // Enable dynamic payload length
- #define NRF24_REG_FEATURE 0x1D // Feature register
- // Register bits definitions
- #define NRF24_CONFIG_PRIM_RX 0x01 // PRIM_RX bit in CONFIG register
- #define NRF24_CONFIG_PWR_UP 0x02 // PWR_UP bit in CONFIG register
- #define NRF24_FEATURE_EN_DYN_ACK 0x01 // EN_DYN_ACK bit in FEATURE register
- #define NRF24_FEATURE_EN_ACK_PAY 0x02 // EN_ACK_PAY bit in FEATURE register
- #define NRF24_FEATURE_EN_DPL 0x04 // EN_DPL bit in FEATURE register
- #define NRF24_FLAG_RX_DREADY 0x40 // RX_DR bit (data ready RX FIFO interrupt)
- #define NRF24_FLAG_TX_DSENT 0x20 // TX_DS bit (data sent TX FIFO interrupt)
- #define NRF24_FLAG_MAX_RT 0x10 // MAX_RT bit (maximum number of TX re-transmits interrupt)
- // Register masks definitions
- #define NRF24_MASK_REG_MAP 0x1F // Mask bits[4:0] for CMD_RREG and CMD_WREG commands
- #define NRF24_MASK_CRC 0x0C // Mask for CRC bits [3:2] in CONFIG register
- #define NRF24_MASK_STATUS_IRQ 0x70 // Mask for all IRQ bits in STATUS register
- #define NRF24_MASK_RF_PWR 0x06 // Mask RF_PWR[2:1] bits in RF_SETUP register
- #define NRF24_MASK_RX_P_NO 0x0E // Mask RX_P_NO[3:1] bits in STATUS register
- #define NRF24_MASK_DATARATE 0x28 // Mask RD_DR_[5,3] bits in RF_SETUP register
- #define NRF24_MASK_EN_RX 0x3F // Mask ERX_P[5:0] bits in EN_RXADDR register
- #define NRF24_MASK_RX_PW 0x3F // Mask [5:0] bits in RX_PW_Px register
- #define NRF24_MASK_RETR_ARD 0xF0 // Mask for ARD[7:4] bits in SETUP_RETR register
- #define NRF24_MASK_RETR_ARC 0x0F // Mask for ARC[3:0] bits in SETUP_RETR register
- #define NRF24_MASK_RXFIFO 0x03 // Mask for RX FIFO status bits [1:0] in FIFO_STATUS register
- #define NRF24_MASK_TXFIFO 0x30 // Mask for TX FIFO status bits [5:4] in FIFO_STATUS register
- #define NRF24_MASK_PLOS_CNT 0xF0 // Mask for PLOS_CNT[7:4] bits in OBSERVE_TX register
- #define NRF24_MASK_ARC_CNT 0x0F // Mask for ARC_CNT[3:0] bits in OBSERVE_TX register
- #define NRF24_ADDR_WIDTH 5 // RX/TX address width
- #define NRF24_PLOAD_WIDTH 32 // Payload width
- #define NRF24_TEST_ADDR "nRF24"
- typedef enum
- NRF24_MODE_RX = 0x00,
- NRF24_MODE_TX = 0x01,
- NRF24_MODE_IT = 0x02
- } NRF24_MODE;
- const uint8_t TX_ADDRESS[NRF24_ADDR_WIDTH] = {0x32,0x4E,0x6F,0x64,0x65};
- const uint8_t RX_ADDRESS[NRF24_ADDR_WIDTH] = {0x32,0x4E,0x6F,0x64,0x22};
- const NRF24_MODE CURRENT_MODE = NRF24_MODE_IT;
- uint8_t rx_buf[NRF24_PLOAD_WIDTH];
- #define NRF_CSN P1_4
- #define NRF_MOSI P1_5
- #define NRF_MISO P1_6
- #define NRF_SCK P1_7
- #define NRF_IRQ P3_2
- #define NRF_CE P3_7
- uint8_t NRF24L01_Write_Reg(uint8_t reg,uint8_t value)
- uint8_t status;
- NRF_CSN = 0;
- status = SPI_RW(reg);
- SPI_RW(value);
- NRF_CSN = 1;
- return status;
- uint8_t NRF24L01_Read_Reg(uint8_t reg)
- uint8_t value;
- NRF_CSN = 0;
- SPI_RW(reg);
- value = SPI_RW(NRF24_CMD_NOP);
- NRF_CSN = 1;
- return value;
- uint8_t NRF24L01_Read_To_Buf(uint8_t reg, uint8_t *pBuf, uint8_t len)
- uint8_t status, u8_ctr;
- NRF_CSN = 0;
- for (u8_ctr = 0; u8_ctr < len; u8_ctr++)
- pBuf[u8_ctr] = SPI_RW(NRF24_CMD_NOP);
- NRF_CSN = 1;
- return status;
- uint8_t NRF24L01_Write_From_Buf(uint8_t reg, const uint8_t *pBuf, uint8_t len)
- NRF_CSN = 0;
- SPI_RW(*pBuf++);
- NRF_CSN = 1;
- return status;
- * Flush the RX FIFO
- void NRF24L01_FlushRX(void)
- NRF24L01_Write_Reg(NRF24_CMD_FLUSH_RX, NRF24_CMD_NOP);
- * Flush the TX FIFO
- void NRF24L01_FlushTX(void)
- NRF24L01_Write_Reg(NRF24_CMD_FLUSH_TX, NRF24_CMD_NOP);
- * Clear IRQ bit of the STATUS register
- * reg - NRF24_FLAG_RX_DREADY
- * NRF24_FLAG_TX_DSENT
- * NRF24_FLAG_MAX_RT
- void NRF24L01_ClearIRQFlag(uint8_t reg)
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_STATUS, reg);
- * Clear RX_DR, TX_DS and MAX_RT bits of the STATUS register
- void NRF24L01_ClearIRQFlags(void)
- uint8_t reg;
- reg = NRF24L01_Read_Reg(NRF24_REG_STATUS);
- reg |= NRF24_MASK_STATUS_IRQ;
- NRF24L01_Write_Reg(NRF24_REG_STATUS, reg);
- uint8_t NRF24L01_RxPacket(uint8_t *rxbuf)
- while(NRF_IRQ);
- uint8_t state = NRF24L01_Read_Reg(NRF24_REG_STATUS);
- printf_tiny("Interrupted, state: %x\r\n", state);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_STATUS, state);
- if (state & NRF24_FLAG_RX_DREADY)
- NRF24L01_Read_To_Buf(NRF24_CMD_RX_PLOAD_R, rxbuf, NRF24_PLOAD_WIDTH);
- NRF24L01_FlushRX();
- return state;
- uint8_t NRF24L01_TxPacket(uint8_t *txbuf)
- uint8_t state;
- NRF_CE = 0;
- NRF24L01_Write_From_Buf(NRF24_CMD_TX_PLOAD_W, txbuf, NRF24_PLOAD_WIDTH);
- NRF_CE = 1;
- while (NRF_IRQ == 1);
- state = NRF24L01_Read_Reg(NRF24_REG_STATUS);
- if (state & NRF24_FLAG_MAX_RT)
- NRF24L01_FlushTX();
- NRF24L01_ClearIRQFlag(NRF24_FLAG_MAX_RT);
- if (state & NRF24_FLAG_TX_DSENT)
- NRF24L01_ClearIRQFlag(NRF24_FLAG_TX_DSENT);
- return state;
- uint8_t NRF24L01_Check(void)
- uint8_t i;
- uint8_t *ptr = (uint8_t *)NRF24_TEST_ADDR;
- NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W | NRF24_REG_TX_ADDR, ptr, NRF24_ADDR_WIDTH);
- NRF24L01_Read_To_Buf(NRF24_CMD_REGISTER_R | NRF24_REG_TX_ADDR, rx_buf, NRF24_ADDR_WIDTH);
- for (i = 0; i < NRF24_ADDR_WIDTH; i++) {
- if (rx_buf[i] != *ptr++) return 1;
- return 0;
- void NRF24L01_init(NRF24_MODE mode)
- NRF_CE = 0;
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_RX_PW_P0, NRF24_PLOAD_WIDTH);
- NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W + NRF24_REG_TX_ADDR, (uint8_t *)TX_ADDRESS, NRF24_ADDR_WIDTH);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_EN_AA, 0x3f);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_EN_RXADDR, 0x3f);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_SETUP_RETR, 0x0a);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_RF_CH, 40);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_RF_SETUP, 0x07);
- switch (mode)
- case NRF24_MODE_RX:
- case NRF24_MODE_IT:
- NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W + NRF24_REG_RX_ADDR_P0, (uint8_t *)RX_ADDRESS, NRF24_ADDR_WIDTH);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_CONFIG, 0x0F);
- break;
- case NRF24_MODE_TX:
- default:
- NRF24L01_Write_From_Buf(NRF24_CMD_REGISTER_W + NRF24_REG_RX_ADDR_P0, (uint8_t *)TX_ADDRESS, NRF24_ADDR_WIDTH);
- NRF24L01_Write_Reg(NRF24_CMD_REGISTER_W + NRF24_REG_CONFIG, 0x0E);
- break;
- NRF_CE = 1;
- void NRF24L01_printBuf(void)
- for (uint8_t i = 0; i < NRF24_PLOAD_WIDTH; i++)
- printf_tiny("%x ", rx_buf[i]);
- printf_tiny("\r\n");
- void NRF24L01_irqHandler(void) __interrupt IE0_VECTOR
- NRF24L01_Read_To_Buf(NRF24_CMD_RX_PLOAD_R, rx_buf, NRF24_PLOAD_WIDTH);
- NRF24L01_printBuf();
- void EXTI_init(void)
- EXTI_configTypeDef ec;
- ec.mode = EXTI_mode_lowLevel;
- ec.priority = IntPriority_High;
- EXTI_config(PERIPH_EXTI_0, &ec);
- EXTI_cmd(PERIPH_EXTI_0, ENABLE);
- UTIL_setInterrupts(ENABLE);
- void SPI_init(void)
- SPI_configTypeDef sc;
- sc.baudRatePrescaler = SPI_BaudRatePrescaler_4;
- sc.cpha = SPI_CPHA_1Edge;
- sc.cpol = SPI_CPOL_low;
- sc.firstBit = SPI_FirstBit_MSB;
- sc.pinmap = SPI_pinmap_P1;
- sc.nss = SPI_NSS_Soft;
- sc.mode = SPI_Mode_Master;
- SPI_config(&sc);
- SPI_cmd(ENABLE);
- void main(void)
- UTIL_enablePrintf();
- SPI_init();
- while (NRF24L01_Check())
- printf_tiny("Check failed, waiting retry\r\n");
- sleep(500);
- NRF24L01_init(CURRENT_MODE);
- if (CURRENT_MODE == NRF24_MODE_RX)
- while (true)
- uint8_t sta = NRF24L01_RxPacket(rx_buf);
- printf_tiny("RX stat: %x\r\n", sta);
- else if (CURRENT_MODE == NRF24_MODE_IT)
- EXTI_init();
- while(true);
- else
- uint8_t tmp[] = {
- 0x1F, 0x80, 0x13, 0x14, 0x15, 0x16, 0x17, 0x18,
- 0x21, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x28,
- 0x31, 0x12, 0x13, 0x14, 0x15, 0x16, 0x17, 0x38,
- 0x41, 0x12, 0x13, 0x14, 0x15, 0x16, 0x37, 0x48};
- while (true)
- uint8_t sta = NRF24L01_TxPacket(tmp);
- tmp[1] = sta;
- printf_tiny("TX stat: %x\r\n", sta);
- sleep(500);
復制代碼
