查看: 2311|回復(fù): 5
4*4矩陣掃描 STM32f103RCT6的程序是對的 改成ZET6就不對了
回帖獎勵 5 黑幣 回復(fù)本帖可獲得 5 黑幣獎勵! 每人限 1 次
ID:849635 發(fā)表于 2021-9-9 22:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
RCT6的程序是對的,改成原子ZET6核心板就不對了
#include "key4_4.h"
#include "delay.h"
#include "sys.h"
//8個引腳 4個為行 4個為列
//行輸出端口定義
#define X1_GPIO_PORT GPIOA
#define X2_GPIO_PORT GPIOA
#define X3_GPIO_PORT GPIOA
#define X4_GPIO_PORT GPIOB
//列輸入端口定義
#define Y1_GPIO_PORT GPIOB
#define Y2_GPIO_PORT GPIOB
#define Y3_GPIO_PORT GPIOB
#define Y4_GPIO_PORT GPIOB
//行輸出引腳定義
#define X1_GPIO_PIN GPIO_Pin_11
#define X2_GPIO_PIN GPIO_Pin_12
#define X3_GPIO_PIN GPIO_Pin_15
#define X4_GPIO_PIN GPIO_Pin_5
//列輸入引腳定義
#define Y1_GPIO_PIN GPIO_Pin_6
#define Y2_GPIO_PIN GPIO_Pin_7
#define Y3_GPIO_PIN GPIO_Pin_8
#define Y4_GPIO_PIN GPIO_Pin_9
//行輸出時鐘定義
#define X1_RCC RCC_APB2Periph_GPIOA
#define X2_RCC RCC_APB2Periph_GPIOA
#define X3_RCC RCC_APB2Periph_GPIOA
#define X4_RCC RCC_APB2Periph_GPIOB
//列輸入時鐘定義
#define Y1_RCC RCC_APB2Periph_GPIOB
#define Y2_RCC RCC_APB2Periph_GPIOB
#define Y3_RCC RCC_APB2Periph_GPIOB
#define Y4_RCC RCC_APB2Periph_GPIOB
//移植代碼只需要修改上面的端口和引腳和時鐘即可,下面的代碼不用修改。
//矩陣鍵盤所用的8個引腳可連續(xù)可不連續(xù),看實際需要和個人愛好自己定義。
unsigned char Y1,Y2,Y3,Y4;
void Key_Init(void)
   RCC_APB2PeriphClockCmd(X1_RCC|X2_RCC|X3_RCC|X4_RCC|Y1_RCC|Y2_RCC|Y3_RCC|Y4_RCC|RCC_APB2Periph_AFIO, ENABLE);
   GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
//    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
////開啟AFIO時鐘
//GPIO_PinRemapConfig(GPIO_Remap_SWJ_Disable,ENABLE);
////改變指定管腳的映射 GPIO_Remap_SWJ_Disable SWJ 完全禁用(JTAG+SW-DP)
//GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);
////改變指定管腳的映射 GPIO_Remap_SWJ_JTAGDisable ,JTAG-DP 禁用 + SW-DP 使能
/*****************************4行輸出*********************************************/
   GPIO_InitStructure.GPIO_Pin =  X1_GPIO_PIN ;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
   GPIO_Init(X1_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  X2_GPIO_PIN ;
   GPIO_Init(X2_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  X3_GPIO_PIN ;
   GPIO_Init(X3_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin = X4_GPIO_PIN ;
   GPIO_Init(X4_GPIO_PORT, &GPIO_InitStructure);
/**************************************4列輸入*************************************/
   GPIO_InitStructure.GPIO_Pin =  Y1_GPIO_PIN ;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;
   GPIO_Init(Y1_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  Y2_GPIO_PIN ;
   GPIO_Init(Y2_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin =  Y3_GPIO_PIN ;
   GPIO_Init(Y3_GPIO_PORT, &GPIO_InitStructure);
   GPIO_InitStructure.GPIO_Pin = Y4_GPIO_PIN;
   GPIO_Init(Y4_GPIO_PORT, &GPIO_InitStructure);
int Key_Scan(void)
   uchar KeyVal;
   GPIO_SetBits(X1_GPIO_PORT,X1_GPIO_PIN);  //先讓X1輸出高
   GPIO_SetBits(X2_GPIO_PORT,X2_GPIO_PIN);  //先讓X2輸出高
   GPIO_SetBits(X3_GPIO_PORT,X3_GPIO_PIN);  //先讓X3輸出高
   GPIO_SetBits(X4_GPIO_PORT,X4_GPIO_PIN);  //先讓X4輸出高
    if((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN)|GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN)|GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN)|GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))==0x0000)
        return -1; //如果X1到X4全為零則沒有按鍵按下
        delay_ms(5);    //延時5ms去抖動
        return -1;
     GPIO_ResetBits(X1_GPIO_PORT,X1_GPIO_PIN);
     GPIO_ResetBits(X2_GPIO_PORT,X2_GPIO_PIN);
     GPIO_ResetBits(X3_GPIO_PORT,X3_GPIO_PIN);
    Y1=GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN);Y2=GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN);
    Y3=GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN);Y4=GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN);
     if(Y1==1&&Y2==0&&Y3==0&&Y4==0)
            KeyVal='*';
     if(Y1==0&&Y2==1&&Y3==0&&Y4==0)
            KeyVal=0;
     if(Y1==0&&Y2==0&&Y3==0&&Y4==1)
            KeyVal='D';
     if(Y1==0&&Y2==0&&Y3==1&&Y4==0)
            KeyVal='#';
     while(((GPIO_ReadInputDataBit(Y1_GPIO_PORT,Y1_GPIO_PIN))|(GPIO_ReadInputDataBit(Y2_GPIO_PORT,Y2_GPIO_PIN))|(GPIO_ReadInputDataBit(Y3_GPIO_PORT,Y3_GPIO_PIN))|(GPIO_ReadInputDataBit(Y4_GPIO_PORT,Y4_GPIO_PIN))) > 0);
    //等待按鍵釋放
     GPIO_ResetBits(X4_GPIO_PORT,X4_GPIO_PIN);
            KeyVal=1;
            KeyVal=2;
            KeyVal=3;
            KeyVal='A';
            KeyVal=4;
            KeyVal=5;
            KeyVal=6;
            KeyVal='B';
            KeyVal=7;
            KeyVal=8;
            KeyVal=9;
            KeyVal='C';
        return KeyVal;
        按鍵表盤為:        1  2  3  A
                            4  5  6  B
                            7  8  9  C
                            *  0  #  D
void Key_Test(void)
    int num;
      num = Key_Scan();
      switch(num)
                case 0: printf("0\n"); break;
                case 1: printf("1\n"); break;
                case 2: printf("2\n"); break;
                case 3: printf("3\n"); break;
                case 4: printf("4\n"); break;
                case 5: printf("5\n"); break;
                case 6: printf("6\n"); break;
                case 7: printf("7\n"); break;
                case 8: printf("8\n"); break;
                case 9: printf("9\n"); break;
                case 'A': printf("A\n"); break;
                case 'B': printf("B\n"); break;
                case 'C': printf("C\n"); break;
                case 'D': printf("D\n"); break;
                case '#': printf("#\n"); break;
                case '*': printf("*\n"); break;
51.7z
222.48 KB, 下載次數(shù): 2
ID:965024 發(fā)表于 2021-9-10 09:22 | 只看該作者
是不是庫文件有問題
ID:514901 發(fā)表于 2021-9-10 09:59 | 只看該作者
一般沒問題的,你說的不對是程序不能用還是鍵盤和數(shù)字對不上,后者的話建議檢測接線順序
ID:849635 發(fā)表于 2021-9-10 11:43 | 只看該作者
鄭漢松 發(fā)表于 2021-9-10 09:59
接線沒有問題的,但是16個按鍵只能打印一兩個,還不對
ID:849635 發(fā)表于 2021-9-10 11:50 | 只看該作者
hal_w 發(fā)表于 2021-9-10 09:22
是不是庫文件有問題
庫文件?HD,s嗎?
ID:96682 發(fā)表于 2021-9-10 12:09 來自觸屏版 | 只看該作者
問題是芯片型號后綴不一樣能直接使用么?
