查看: 3322|回復(fù): 1
warning: #3731-D: intrinsic is deprecated 請(qǐng)問(wèn)一下這個(gè)警告要怎么消除
ID:514901 發(fā)表于 2021-9-11 09:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
100黑幣
用的最新的HAL庫(kù),uart相關(guān)的庫(kù)代碼更新了,加了原子鎖還是啥不太懂,繞后然后報(bào)警告..\LIB\STM32F4xx_HAL_Driver\Src\stm32f4xx_hal_uart.c(3619): warning:  #3731-D: intrinsic is deprecated
最佳答案
查看完整內(nèi)容
CAUSE The Arm Compiler does not guarantee to preserve the state of the exclusive monitor. This is why the __ldrex, __ldrexd, __strex and __strexd intrinsics are deprecated. RESOLUTION Either ignore the warnings or update the Arm CMSIS Pack to a version later than 4.3.0 to get these warning messages suppressed. 具體參考:https://www.keil.com/support/docs/3783.htm
ID:875095 發(fā)表于 2021-9-11 09:09 | 只看該作者
CAUSE
RESOLUTION
