查看: 2945|回復(fù): 10
單片機(jī)16*16點(diǎn)陣程序老是顯示error c141:syntax error near“0xFF”等
ID:970037 發(fā)表于 2021-10-5 23:25 | 顯示全部樓層 |閱讀模式
#include<reg51.h>#define uchar unsigned char
#define out0 P0
#define out2 P2
#define out1 P1
void delay(uint j)                                //延時(shí)函數(shù)
uchar i=250;
for(;j>0;j--)
   while(--i);
i=100;
uchar  code string[]=
{//漢字“”的16*16點(diǎn)陣的列碼0xFF,0xFF,0xFF,0xFF,0x80,0x07,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF6,0xFF,0xFA,0xFF,0xFC,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF
//漢字“”的16*16點(diǎn)陣的列碼0xFF,0xFF,0xFB,0xFF,0xF7,0xFF,0xE0,0x80,0xDB,0xF7,0xFB,0xF7,0xE0,0xF7,0xFB,0xF7,0xFB,0xC1,0xE0,0xF7,0xFB,0xF5,0xFA,0xF6,0xF9,0xF7,0xFB,0x80,0xFF,0xFF,0xFF,0xFF
//漢字“”的16*16點(diǎn)陣的列碼0xFF,0xFF,0xB8,0x60,0xDB,0x77,0xE8,0x60,0xFB,0x6E,0xF8,0x6E,0xBD,0xEA,0xDE,0xEA,0xE8,0x2A,0xFC,0x6A,0xFD,0x6A,0xEC,0x7B,0xDA,0xBB,0xB4,0xD5,0x7E,0xEE,0xFF,0xFF} void main()
uchar i,j,n;
        for(j=0;j<3;j++)
  for(n=0;n<40;n++)
   for(i=0;i<16;i++)
                  out1=i%16;
          out0=string[i*2+j*32];
                  out2=string[i*2+1+j*32];
                          delay(4);
          out0=0xff;
          out2=0xff;
ID:939710 發(fā)表于 2021-10-6 04:35 | 顯示全部樓層
兄弟的你的主函數(shù)main標(biāo)識(shí)呢。。。
ID:939710 發(fā)表于 2021-10-6 04:40 | 顯示全部樓層
string數(shù)組里面第一二行最后都少一個(gè)逗號(hào)
ID:332444 發(fā)表于 2021-10-6 08:15 | 顯示全部樓層
數(shù)據(jù)都注釋掉還有數(shù)據(jù)能加載?
ID:235200 發(fā)表于 2021-10-6 08:29 | 顯示全部樓層
在定義的這個(gè) string[]={};數(shù)組后面加上分號(hào)就可以了
ID:827243 發(fā)表于 2021-10-6 08:41 | 顯示全部樓層
每個(gè)漢字的最后一個(gè)0xFF后面,少了,
ID:462827 發(fā)表于 2021-10-6 08:57 | 顯示全部樓層
你從哪里抄來(lái)的代碼,又不好好排版,很多內(nèi)容應(yīng)該換行的你又不換行,它們擠在一起就變成了語(yǔ)法錯(cuò)誤了。
第1行的包含頭文件與后面的#define要換行;
string數(shù)組現(xiàn)在不換行后面的內(nèi)容都跟著變成了注釋,而且還缺逗號(hào)。最末還缺了分號(hào)。
void main()應(yīng)該換到新行。
不排版的代碼就是%%。
ID:94031 發(fā)表于 2021-10-6 09:12 | 顯示全部樓層
這樣改一下:
#include<reg51.h>
#define out0 P0
#define out2 P2
#define out1 P1
        uchar i=250;
        for(;j>0;j--)
                 while(--i);
           i=100;
        0xFF,0xFF,0xFF,0xFF,0xF6,0xFF,0xFA,0xFF,0xFC,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
        0xFB,0xC1,0xE0,0xF7,0xFB,0xF5,0xFA,0xF6,0xF9,0xF7,0xFB,0x80,0xFF,0xFF,0xFF,0xFF,
        uchar i,j,n;
                for(j=0;j<3;j++)
                        for(n=0;n<40;n++)
                          for(i=0;i<16;i++)
                                        out1=i%16;
                                        delay(4);
                                        out0=0xff;
                                        out2=0xff;
ID:161164 發(fā)表于 2021-10-6 09:16 | 顯示全部樓層
少了一些逗號(hào)和分號(hào)
        0xFF,0xFF,0xFF,0xFF,0x80,0x07,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF6,0xFF,0xFA,0xFF,0xFC,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
        0xFF,0xFF,0xFB,0xFF,0xF7,0xFF,0xE0,0x80,0xDB,0xF7,0xFB,0xF7,0xE0,0xF7,0xFB,0xF7,0xFB,0xC1,0xE0,0xF7,0xFB,0xF5,0xFA,0xF6,0xF9,0xF7,0xFB,0x80,0xFF,0xFF,0xFF,0xFF,
        0xFF,0xFF,0xB8,0x60,0xDB,0x77,0xE8,0x60,0xFB,0x6E,0xF8,0x6E,0xBD,0xEA,0xDE,0xEA,0xE8,0x2A,0xFC,0x6A,0xFD,0x6A,0xEC,0x7B,0xDA,0xBB,0xB4,0xD5,0x7E,0xEE,0xFF,0xFF};
ID:939018 發(fā)表于 2023-4-14 11:25 來(lái)自觸屏版 | 顯示全部樓層
hantu 發(fā)表于 2021-10-6 08:57
第 ...
這是張毅剛c51的書上的代碼艸
ID:69038 發(fā)表于 2023-4-14 14:04 | 顯示全部樓層
考試周破防 發(fā)表于 2023-4-14 11:25
這是張毅剛c51的書上的代碼艸
老孟早就說(shuō)了:盡信書不如無(wú)書。
