- *File name: main.c
- *Description:在第一個十字路口打開閘道
- timer0:
- timer1:
- timer2: uart2/4
- timer3: uart3
- timer4: 1ms 時鐘滴答
- /*引入頭文件*/
- #include <STC8.H>
- #include "car_control.h"
- #include "pwm_pca.h"
- #include "delay.h"
- #include "ir.h"
- #include "hc-sr04.h"
- #include "uart.h"
- #include "timer.h"
- #include "disp.h"
- #include "user_string.h"
- #include "intrins.h"
- #include "color.h"
- #define KEY4 P54
- signed char temperature = 0; // 溫度
- signed char humidity = 0; // 濕度
- signed long encode_count_chA = 0; // 通道A編碼器計數(shù)值
- signed long encode_count_chB = 0; // 通道B編碼器計數(shù)值
- unsigned char at_com_type = 0; // AT指令讀數(shù)據(jù)狀態(tài)
- extern unsigned short R_data,G_data,B_data;
- * 名 稱:main
- * 功 能:程序入口
- * 入口參數(shù):無
- * 出口參數(shù):無
- * 說 明:無
- * 調用方法:無
- void main()
- unsigned char t_10s = 10;
- unsigned int dat=0;
- unsigned char pre_tick = 0;
- xdata unsigned char u4_txBuf[20];
- P1M0 = 0xC0;
- P1M1 = 0x0;
- // P54口設為輸入口
- P5M0 &= ~0x10;
- P5M1 |= 0x10;
- uart4_init();
- uart3_init();
- uart2_init();
- EA = 1; /* 開總中斷 */
- car_init(); /* 小車初始化 */
- HC_SR04_Init(); /*超聲波初始化*/
- delay_ms(100);
- MOTOR_GO_EN;
- delay_ms(10);
- // disp_number(temperature);
- disp_number(distance); // 數(shù)碼管顯示距離
- uart4_tx_idle = 10;
- uart4_send_array("AT+EON\r\n", sizeof("AT+EON\r\n")); // 控制指令不返回OK
- delay_ms(10);
- Timer4Init();
- tick = 0;
- //Color_Init();//開啟顏色檢測
- // 使能串口2/3接收狀態(tài)
- uart2_restart_rx();
- uart3_restart_rx();
- while(1)
- if (pre_tick != tick)
- { // 每1ms刷新一次數(shù)碼管
- pre_tick = tick;
- disp_isr_call();
- if (carWorking.delay != 0) // 特殊任務計時
- carWorking.delay--;
- if (trafficLight_opevmv.tick != 0) // 攝像頭計時
- trafficLight_opevmv.tick--;
- else
- trafficLight_opevmv.light = 0;
- if (tick >= 100)
- tick = 0;
- /*//disp_number(G_data);
- u4_txBuf[0] = 'E';
- u4_txBuf[1] = 'S';
- u4_txBuf[2] = 'P';
- u4_txBuf[3] = 1;
- u4_txBuf[4] = 9;
- u4_txBuf[5] = 6;
- u4_txBuf[6] = R_data >> 8;
- u4_txBuf[7] = R_data;
- u4_txBuf[8] = G_data >> 8;
- u4_txBuf[9] = G_data;
- u4_txBuf[10] = B_data >> 8;
- u4_txBuf[11] = B_data;
- u4_txBuf[12] = 0xF8 + u4_txBuf[6] + u4_txBuf[7] + u4_txBuf[8] + u4_txBuf[9] + u4_txBuf[10] + u4_txBuf[11];
- u4_txBuf[13] = 'E';
- u4_txBuf[14] = 'N';
- u4_txBuf[15] = 'D';
- uart4_send_array(u4_txBuf, 16);*/
- /*if (R_data >= G_data){
- disp_number(R_data - G_data);
- else{
- disp_number(G_data - R_data);
- disp_number_1(10);
- dat = HC_SR04_Read();//讀取超聲波距離 每100ms測量一次
- if(dat != -1)//距離采集成功
- distance = dat;
- t_10s--;
- if (t_10s == 0)
- t_10s = 100;
- uart4_send_array("AT+TEMPERATURE?\r\n", 17);
- // 重新開始接收數(shù)據(jù)
- uart4_restart_rx();
- at_com_type = 1; // AT指令讀數(shù)據(jù)類型 1溫度 2濕度 3編碼器計數(shù)值 4速度 5電池電量
- if (uart4_rx_idle == 3)
- { // 驅動板接收數(shù)據(jù)解析
- unsigned char rx_len = 100 - uart4_buf.r_free;
- if (rx_len > 6)
- // if (uart4_rx_buf[0] == '+')
- unsigned char st;
- switch (at_com_type)
- case 1: // 溫度
- st = user_array_seek(uart4_rx_buf, rx_len, "+TEMPERATURE:", 13);
- if (st != 0xFF)
- signed long buf;
- if (user_str_DECnumStr2num(uart4_rx_buf + st + 15, &buf) != 0)
- temperature = buf;
- break;
- case 2: // 濕度
- st = user_array_seek(uart4_rx_buf, rx_len, "+HUMIDITY:", 10);
- if (st != 0xFF)
- signed long buf;
- if (user_str_DECnumStr2num(uart4_rx_buf + st + 12, &buf) != 0)
- humidity = buf;
- //disp_number(humidity);
- break;
- case 3: // 編碼器
- st = user_array_seek(uart4_rx_buf, rx_len, "+MTENCODER:", 11);
- if (st != 0xFF)
- signed long buf;
- register unsigned char len = user_str_DECnumStr2num(uart4_rx_buf + st + 13, &buf);
- if (len != 0)
- { // <channel A>
- encode_count_chA = buf;
- st = len + st + 1;
- len = user_str_DECnumStr2num(uart4_rx_buf + st + 13, &buf);
- if (len != 0)
- { // <channel B>
- encode_count_chB = buf;
- break;
- case 4: // 速度
- { // 需用戶自行完善
- st = user_array_seek(uart4_rx_buf, rx_len, "+MTRPM:", 6);
- if (st != 0xFF)
- { // <channel A>,<channel B> 轉/分鐘
- signed long buf;
- register unsigned char len = user_str_DECnumStr2num(uart4_rx_buf + st + 8, &buf);
- if (len != 0)
- { // <channel A>
- break;
- case 5: // 電池電量
- { // 需用戶自行完善
- st = user_array_seek(uart4_rx_buf, rx_len, "+BATTERY:", 8);
- if (st != 0xFF)
- { // <電壓>,<電流>,<剩余電量>,<節(jié)數(shù)>,<已消耗電量>
- signed long buf;
- register unsigned char len = user_str_DECnumStr2num(uart4_rx_buf + st + 10, &buf);
- if (len != 0)
- { // <電壓>
- break;
- case 6: // 報警狀態(tài)
- { // 需用戶自行編寫
- break;
- at_com_type = 0;
- if (rx_len != 0)
- { // 重新開始接收數(shù)據(jù)
- else if (uart4_rx_idle >= 50)
- uart4_rx_idle = 5;
- if (at_com_type != 0)
- at_com_type = 0;
- if((distance<300) && //距離小于300mm 如果有路障重新規(guī)劃路線,則建議將此部分屏蔽掉
- (carWorking.type == 0)) // 非特殊任務時,才執(zhí)行
- MOTOR_GO_STOP;//停車
- else
- car_FollowLine();//循跡
- if (uart3_rx_idle == 5)
- { // lora通信測試
- unsigned char len = 100 - uart3_buf.r_free;
- if ((len >= 6) && (uart3_rx_buf[4] + 6 <= len))
- { // 紅綠燈命令解析,用戶可根據(jù)實際情況進行修改
- if (uart3_rx_buf[5] == 'r')
- disp_number_1(1);
- else if (uart3_rx_buf[5] == 'g')
- disp_number_1(0);
- else if (uart3_rx_buf[5] == 'y')
- disp_number_1(2);
- disp_number_2(0);
- disp_number_3(uart3_rx_buf[7] / 10);
- disp_number_4(uart3_rx_buf[7] % 10);
- if (uart2_rx_idle == 5)
- { // 攝像頭通信測試
- unsigned char len = 100 - uart2_buf.r_free;
- if (len > 17)
- { // 攝像頭檢測到紅綠燈時,發(fā)送以下字符串
- // "traffic light is red"
- // "traffic light is green"
- // "traffic light is yellow"
- if (user_str_cmp(uart2_rx_buf, "traffic light is ") >= 17)
- if (uart2_rx_buf[17] == 'r')
- { // "red"
- trafficLight_opevmv.light = 'r';
- //disp_number_1(1);
- else if (uart2_rx_buf[17] == 'g')
- { // "green"
- trafficLight_opevmv.light = 'g';
- //disp_number_1(3);
- else if (uart2_rx_buf[17] == 'y')
- { // "yellow"
- trafficLight_opevmv.light = 'y';
- //disp_number_1(2);
- trafficLight_opevmv.tick = 250;
- else
復制代碼 Keil代碼工程:
小車綜合任務-源碼.rar
(157.88 KB, 下載次數(shù): 16)
2021-10-7 15:56 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
