查看: 2636|回復(fù): 0
TM1640顯示數(shù)字例程,各位多多指教
ID:134345 發(fā)表于 2021-10-9 10:16 | 顯示全部樓層 |閱讀模式
51單片機驅(qū)動TM1640輪流顯示數(shù)字1-8
代碼如下:
#include<reg51.h>
#include<intrins.h>
#define Delay(us) {_nop_();_nop_();_nop_();_nop_();}
#define FOSC 18432000L
//*******1640驅(qū)動************
sbit sda=P1^1; //TM1640數(shù)據(jù)線
sbit scl=P3^7; //TM1640時鐘線
unsigned char date[] = {
0xb7,0x82,0x9d,0x3d,0x2e,0x3b,0xbb,0x25,0xbf,0x3f,0xaf,0x9e,0x9d,0x82,0x3b,0x8b,0xbc,0x6f,0x2f,0x40};
//*********START***************
void start() //1640開始
        //scl=0;
        sda=1;
        _nop_();
        _nop_();
        scl=1;
        _nop_();
        _nop_();
        sda=0;
        _nop_();
        _nop_();
        scl=0;
        _nop_();
        _nop_();
void stop() //1640結(jié)束
        scl=0;
        _nop_();
        _nop_();
        sda=0;
        //scl=1;
        _nop_();
        _nop_();
        scl=1;
        _nop_();
        _nop_();
        sda=1;
        _nop_();
        _nop_();
void write(unsigned char date) //1640寫字節(jié)
        unsigned char i,aa;
        aa=date;
        //sda=0;
        //scl=0;
        for(i=0;i<8;i++)
                scl=0;
                if(aa&0x01)
                sda=1;
                _nop_();
                _nop_();
                        sda=0;
                        _nop_();
                        _nop_();
                scl=1;
                _nop_();
                aa=aa>>1;
        //scl=0;
        //sda=0;
//**************向TM1640發(fā)送顯示數(shù)據(jù)***************************
void send(unsigned char date1)
//void send()
        unsigned char ii;
//        unsigned char mask;
        start();
        write(0x40); //設(shè)置數(shù)據(jù),地址加1模式
        stop();
        start();
        write(0xC0); //起始地址
        for(ii=0;ii<16;ii++)   //16個地址
            write(date1);
/*        for(mask=0x80;mask!=0;mask>>=1)
                if((mask&date1) == 0)
                   I2C_SDA = 0;
                   I2C_SDA = 1;
                   I2CDelay();
               I2C_SCL = 1;
               I2CDelay();
               I2C_SCL = 0;
        stop();
        start();
        write(0x8f); //控制顯示,開顯示,脈沖寬度為14/16
        stop();
void send1()
        unsigned char i;
        start();
        //write(0x40); //設(shè)置數(shù)據(jù),地址加1模式
        write(0x44); //固定地址模式
        stop();
        start();
        write(0x00);
        write(0xff);
        stop();
        start();
        write(0x01);
        write(0x01);
        stop();
        start();
        write(0x02);
        write(0x01);
        stop();
        start();
        write(0x03);
        write(0x01);
        stop();
        start();
        write(0x04);
        write(0x01);
        stop();
        start();
        write(0x05);
        write(0x01);
        stop();
        start();
        write(0x06);
        write(0x01);
        stop();
        start();
        stop();
void delay(unsigned int z) //延時子程序
        unsigned int x,y;
        for(x=z;x>0;x--)
        for(y=487;y>0;y--);
{     /* unsigned char h;
    for(h=0;h>20;h++)
    send(date[h]);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    delay(200);
    //send(date[20]);
      send(date[1]);
      delay(200);
      send(date[2]);
      delay(200);
      send(date[3]);
      delay(200);
      send(date[4]);
      delay(200);
      send(date[5]);
      delay(200);
          send(date[6]);
      delay(200);
      send(date[7]);
    delay(200);
    send(date[8]);
    delay(200);
