查看: 1941|回復(fù): 0
關(guān)于STM8/32單片機(jī)使數(shù)碼管簡便顯示的方法
ID:728915 發(fā)表于 2021-10-9 11:30 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
請教各位大佬,本人比較菜,用STM8寫了一個程序,其中關(guān)于點(diǎn)亮數(shù)碼管的部分,雖然能用,但是感覺特別繁瑣。然后看網(wǎng)上其它人寫的,說實(shí)話,可能個人腦瓜不是很靈光,有點(diǎn)看不懂。所以想請各位大佬多抬貴手,詳細(xì)注釋一下,萬分感謝。!
/****以下是代碼內(nèi)容,重復(fù)部分就不一一列舉了****/
//定義ON/OFF
#define ON  1
#define OFF 0
//第1-4位(從左往右)數(shù)碼管 使能/不使能定義。 數(shù)碼管:U4,4位,紅色共陰
#define shumaguan_U4_1_shineng(ON_OFF)  if(ON_OFF==OFF)GPIO_WriteHigh(GPIOC, GPIO_PIN_6);\
                                          else GPIO_WriteLow(GPIOC, GPIO_PIN_6)
#define shumaguan_U4_2_shineng(ON_OFF)  if(ON_OFF==OFF)GPIO_WriteHigh(GPIOC, GPIO_PIN_5);\
                                          else GPIO_WriteLow(GPIOC, GPIO_PIN_5)
//定義數(shù)碼管的a,b亮/滅,每段一個I/O口控制,高電平點(diǎn)亮
#define shumaguan_U4_xianshi_a(ON_OFF)    if(ON_OFF==ON)GPIO_WriteHigh(GPIOD, GPIO_PIN_0);\
                                            else GPIO_WriteLow(GPIOD, GPIO_PIN_0)
#define shumaguan_U4_xianshi_b(ON_OFF)    if(ON_OFF==ON)GPIO_WriteHigh(GPIOD, GPIO_PIN_1);\
                                            else GPIO_WriteLow(GPIOD, GPIO_PIN_1)
//定義數(shù)碼管分別顯示0-1、.(小數(shù)點(diǎn))亮/滅,多個I/O口同時組合使能,高電平點(diǎn)亮
#define shumaguan_U4_xianshi_0(ON_OFF)    if(ON_OFF==ON)GPIO_WriteHigh(GPIOD, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2| GPIO_PIN_3|GPIO_PIN_4| GPIO_PIN_5);\
                                            else GPIO_WriteLow(GPIOD, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2| GPIO_PIN_3|GPIO_PIN_4| GPIO_PIN_5)
#define shumaguan_U4_xianshi_1(ON_OFF)    if(ON_OFF==ON)GPIO_WriteHigh(GPIOD, GPIO_PIN_1|GPIO_PIN_2);\
                                            else GPIO_WriteLow(GPIOD, GPIO_PIN_1|GPIO_PIN_2)
//數(shù)碼管顯示“[]”亮/滅,多個I/O口同時組合使能,高電平點(diǎn)亮
#define shumaguan_U4_xianshi_fangkuang_zuoce(ON_OFF)       if(ON_OFF==ON)GPIO_WriteHigh(GPIOD, GPIO_PIN_0|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5);\
                                                             else GPIO_WriteLow(GPIOD, GPIO_PIN_0|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5)
#define shumaguan_U4_xianshi_fangkuang_shangxia(ON_OFF)    if(ON_OFF==ON)GPIO_WriteHigh(GPIOD, GPIO_PIN_0|GPIO_PIN_3);\
                                                             else GPIO_WriteLow(GPIOD, GPIO_PIN_0|GPIO_PIN_3)
//各I/O口的引腳初始化
void GPIO_Config()
   //數(shù)碼管U4位選引腳 PC4-7(低電平亮) , 數(shù)碼管顯示引腳PD0-7 (高電平亮)初始化
   GPIO_Init(GPIOC, GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7, GPIO_MODE_OUT_PP_LOW_FAST);   //初始化使數(shù)碼管1-4默認(rèn)為全選擇狀態(tài)
   GPIO_Init(GPIOD, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2| GPIO_PIN_3|GPIO_PIN_4| GPIO_PIN_5|GPIO_PIN_6| GPIO_PIN_7, GPIO_MODE_OUT_PP_HIGH_FAST);
/****使用時,向下面這樣ON/OFF就能讓數(shù)碼管亮/滅了
shumaguan_U4_1_shineng(ON);
shumaguan_U4_xianshi_0(ON);
shumaguan_U4_xianshi_0(OFF);
雖然按照這種羅列的方式也能使數(shù)碼管顯示想要的圖案,但是,太繁瑣了,所以,我想學(xué)習(xí)一下各大佬優(yōu)秀的方法。在此先感謝!
