已開(kāi)源,代碼詳細(xì)見(jiàn)附錄
Altium Designer畫(huà)的原理圖和PCB圖如下:(51hei附件中可下載工程文件)
2021-10-18 03:45 上傳
2021-10-18 03:46 上傳
- int main(void)
- /* USER CODE BEGIN 1 */
- // float pitch,roll,yaw; //歐拉角
- unsigned char switch_value; //獲取到的按鍵值
- // unsigned long STEPS = 0;
- /* USER CODE END 1 */
- /* MCU Configuration--------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_DMA_Init();
- MX_ADC1_Init();
- MX_I2C1_Init();
- MX_SPI1_Init();
- MX_TIM2_Init();
- MX_TIM4_Init();
- MX_USART1_UART_Init();
- MX_RTC_Init();
- MX_I2C2_Init();
- /* USER CODE BEGIN 2 */
- /*調(diào)節(jié)蜂鳴器*/
- HAL_TIM_PWM_Start(&htim4, TIM_CHANNEL_4); //開(kāi)啟定時(shí)器PWM通道 定時(shí)器2 通道3
- __HAL_TIM_SET_COMPARE(&htim4, TIM_CHANNEL_4, 0); //設(shè)置PWM的占空比,這里初始化占空比為0
- printf("初始化蜂鳴器\r\n");
- /*調(diào)節(jié)屏幕背光*/
- HAL_TIM_PWM_Start(&htim2, TIM_CHANNEL_4); //開(kāi)啟定時(shí)器PWM通道 定時(shí)器2 通道3
- __HAL_TIM_SET_COMPARE(&htim2, TIM_CHANNEL_4, 70); //設(shè)置PWM的占空比,調(diào)節(jié)背光
- printf("調(diào)節(jié)背光\r\n");
- printf("初始化寄存器\r\n");
- // HAL_UART_Receive_IT(&huart1, (uint8_t *)&aRxBuffer, 1); //打開(kāi)串口接收中斷
- /*主顯示界面*/
- MENU_init();
- printf("初始化界面\r\n");
- MPU_Init(); //初始化MPU6050
- while(mpu_dmp_init())//初始化DMP
- printf("error\r\n");
- HAL_Delay(10);
- printf("初始化陀螺儀\r\n");
- HAL_GPIO_WritePin(LED_GPIO_Port, LED_Pin, GPIO_PIN_SET); //更新LED燈的狀態(tài),開(kāi)機(jī)后熄滅
- Screen_off_time = sTime.Seconds + 10; //設(shè)置自動(dòng)熄滅屏幕的時(shí)間是20秒
- if( Screen_off_time > 59 ) //如果設(shè)計(jì)的屏幕熄滅實(shí)踐超過(guò)了一分鐘就倒退回去
- Screen_off_time = Screen_off_time -60; //得到正確的時(shí)間
- usart_print_flag = 0;
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- //傳感器檢測(cè)
- Get_Sensor_data();
- /*主界面顯示部分*/
- MENU_main();
- /*根據(jù)按鍵方向按鍵按下來(lái)進(jìn)入應(yīng)用界面*/
- MENU_APP(switch_value);
- /*處理后臺(tái)運(yùn)行的程序*/
- Background_detection(switch_value);
- /*檢測(cè)按鍵以及處理自動(dòng)熄屏和喚醒屏幕*/
- switch_value = Get_Key_value(1);
- if( switch_value == 2)
- /*熄滅屏幕*/
- __HAL_TIM_SET_COMPARE(&htim2, TIM_CHANNEL_4, 0); //設(shè)置PWM的占空比,調(diào)節(jié)背光
- set_Screen_off_flag = 0; //代表已經(jīng)熄滅了屏幕 熄滅屏幕的狀態(tài)下不對(duì)按鍵等操作進(jìn)行反應(yīng)
- // /*陀螺儀獲取角度部分*/
- // if( mpu_dmp_get_data( &pitch, &roll, &yaw ) == 0 )
- // if(usart_print_flag)
- // printf("%.2f %.2f %.2f \r\n",pitch,roll,yaw);
- // printf("溫度:%.1f 濕度:%.1f 電量百分比:%d 按鍵值:%d 日期:%d:%d:%d 時(shí)間:%d:%d:%d \r\n",
- // temperature,humidity, Battery_voltage ,
- // switch_value,
- // sDate.Year, sDate.Month, sDate.Date,
- // sTime.Hours, sTime.Minutes, sTime.Seconds);
- /* USER CODE END 3 */
所有資料51hei附件下載:
THwatch.7z
(15.86 MB, 下載次數(shù): 182)
2021-10-18 03:51 上傳
點(diǎn)擊文件名下載附件
