查看: 3176|回復(fù): 4
51單片機(jī)矩陣鍵盤數(shù)碼管顯示 Proteus仿真代碼 數(shù)碼管顯示不完整
ID:974141 發(fā)表于 2021-10-23 22:06 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  3. #define uint unsigned int
  4. void delay1(int x){
  5.         uint i,j;
  6.         for(i=0;i<123;i++)
  7.                 for(j=0;j<x;j++);
  8. }
  9. //uchar led[]={0x00,0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0X77,0X7C,0X39,0X5e,0X79,0X71};
  10. uchar led[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E,0X71 };
  11. unsigned int num[]={0xee,0xed,0xeb,0xe7,0xde,0xdd,0xdb,0xd7,
  12.                                         0xbe,0xbd,0xbb,0xb7,0x7e,0x7d,0x7b,0x77};
  13. unsigned char hang[]={0xef,0xdf,0xbf,0x7f};
  14.         uchar key_scan(){
  15.                 uchar a,i,n;
  16.                 for(a=0;a<4;a++){
  17.                         P1=hang[a];
  18.                         if(P1!=hang[a]){
  19.                                 delay1(100);
  20.                                 if(P1!=hang[a]){
  21.                                         for(i=0;i<4;i++){
  22.                                                 if(P1==num[4*a+i]){
  23.                                                         n=4*a+i+1;
  24.                                                 }
  25.                                         }
  26.                                 }
  27.                         }
  28.         }
  29.         return n;
  30. }
  31. main()
  32. {
  33.         P2=0XFE;
  34.         while(1)
  35.         {
  36.                 P0=led[key_scan()];
  37.         }
  38. }
  39.
  40.
Proteus7.5版本的dsn工程文件下載:
51單片機(jī)_矩陣鍵盤.zip (66.34 KB, 下載次數(shù): 79)
參與人數(shù) 1黑幣 +10 收起 理由
admin + 10 共享資料的黑幣獎(jiǎng)勵(lì)!
ID:767282 發(fā)表于 2022-6-15 12:52 | 顯示全部樓層
請(qǐng)問(wèn)為什么我的仿真數(shù)碼管顯示不完整啊
ID:1082543 發(fā)表于 2023-6-7 23:47 | 顯示全部樓層
19863998098 發(fā)表于 2022-6-15 12:52
可以檢查一下電阻
ID:332444 發(fā)表于 2023-6-8 16:38 | 顯示全部樓層
編號(hào)數(shù)組={119,183,215,231,123,187,219,235,125,189,221,237,126,190,222,238}這樣就完成了對(duì)矩陣鍵盤的重編正好用上前些天寫的對(duì)無(wú)序數(shù)組四分快速查找算法.
ID:332444 發(fā)表于 2023-6-9 10:18 | 顯示全部樓層
依據(jù)不同電路圖重新排列
