查看: 2062|回復(fù): 0
VS-RK3399內(nèi)核的kernel的dts簡(jiǎn)寫
ID:959225 發(fā)表于 2021-10-26 10:22 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
VS-RK3399 內(nèi)核的kernel的dts簡(jiǎn)寫:
/dts-v1/;
#include <dt-bindings/input/input.h>
#include "rk3399-videostrong-board.dtsi"
#include "rk3399-android.dtsi"
#include "rk3399-vop-clk-set.dtsi"
#include <dt-bindings/sensor-dev.h>
        model = "Rockchip RK3399 VideoStrong Board MID (Android)";
        compatible = "rockchip,android", "rockchip,rk3399-VideoStrong-boad", "rockchip,rk3399";
          backlight: backlight {      //背光控制
                status = "disabled";
                compatible = "pwm-backlight";
                pwms = <&pwm0 0 25000 0>;
                brightness-levels = <
                          0   1   2   3   4   5   6   7
                          8   9  10  11  12  13  14  15
                         16  17  18  19  20  21  22  23
                         24  25  26  27  28  29  30  31
                         32  33  34  35  36  37  38  39
                         40  41  42  43  44  45  46  47
                         48  49  50  51  52  53  54  55
                         56  57  58  59  60  61  62  63
                         64  65  66  67  68  69  70  71
                         72  73  74  75  76  77  78  79
                         80  81  82  83  84  85  86  87
                         88  89  90  91  92  93  94  95
                         96  97  98  99 100 101 102 103
                        104 105 106 107 108 109 110 111
                        112 113 114 115 116 117 118 119
                        120 121 122 123 124 125 126 127
                        128 129 130 131 132 133 134 135
                        136 137 138 139 140 141 142 143
                        144 145 146 147 148 149 150 151
                        152 153 154 155 156 157 158 159
                        160 161 162 163 164 165 166 167
                        168 169 170 171 172 173 174 175
                        176 177 178 179 180 181 182 183
                        184 185 186 187 188 189 190 191
                        192 193 194 195 196 197 198 199
                        200 201 202 203 204 205 206 207
                        208 209 210 211 212 213 214 215
                        216 217 218 219 220 221 222 223
                        224 225 226 227 228 229 230 231
                        232 233 234 235 236 237 238 239
                        240 241 242 243 244 245 246 247
                        248 249 250 251 252 253 254 255>;
                default-brightness-level = <200>;
        test-power {
                status = "okay";
vsgpio_set {   //自定義
                compatible = "videostrong,gpio";
                pinctrl-names = "default";
                pinctrl-0 = <&b3G_gpio>;
                3G_power = <&gpio0 2 GPIO_ACTIVE_LOW>;
                3G_Spk_GP = <&gpio0 11 GPIO_ACTIVE_HIGH>;
                POWR_LED = <&gpio1 1 GPIO_ACTIVE_HIGH>;
                status = "okay";
vsproc_set {
                compatible = "videostrong,proc";
&backlight {
        status = "okay";
        #enable-gpios = <&gpio1 13 GPIO_ACTIVE_HIGH>;
&i2s1 {
        status = "okay";
        rockchip,i2s-broken-burst-len;
        rockchip,playback-channels = <2>;
        rockchip,capture-channels = <2>;
        #sound-dai-cells = <0>;
&i2s2 {   //打開音頻通道
        status = "okay";
&hdmi {//打開音頻通道
        status = "okay";
&hdmi_sound {
        status = "okay";
&i2c1 {
        status = "okay";
&i2c4 {
        status = "okay";
        gslx680@40 { //配置觸摸屏
        compatible = "videostrong,gslx680";
        reg = <0x40>;
        touch-gpio = <&gpio1 20 IRQ_TYPE_EDGE_RISING>;
        reset-gpio = <&gpio1 22 GPIO_ACTIVE_LOW>;
        max_x = <1024>;
        max_y = <600>;
        gt9xx@5d { //觸摸屏配置
        compatible = "videostrong,gt9xx";
        reg = <0x5d>;
        tp-size=<911>;
        max-x = <1024>;
        max-y = <600>;
mipitolvds@5a { //mipi 轉(zhuǎn)LVDS配置
              status = "okay";
        compatible = "videostrong,mipitolvds";
        reset-gpio = <&gpio4 30 GPIO_ACTIVE_HIGH>;
        reg = <0x2d>;
        lsm330_accel@1e {  //重力定義
                status = "okay";
                compatible = "lsm330_acc";
                pinctrl-0 = <&lsm330a_irq_gpio>;
                reg = <0x1e>;
                irq-gpio = <&gpio4 26 IRQ_TYPE_EDGE_RISING>;
                type = <SENSOR_TYPE_ACCEL>;
                irq_enable = <0>;
                poll_delay_ms = <30>;
                layout = <4>;
        lsm330_gyro@6a {
                status = "okay";
                compatible = "lsm330_gyro";
                pinctrl-0 = <&lsm330g_irq_gpio>;
                reg = <0x6a>;
                irq-gpio = <&gpio1 24 IRQ_TYPE_EDGE_RISING>;
                type = <SENSOR_TYPE_GYROSCOPE>;
                irq_enable = <0>;
        sensor@0f {
                status = "okay";
                compatible = "ak8963";
                pinctrl-0 = <&ak8963_irq_gpio>;
                reg = <0x0f>;
                type = <SENSOR_TYPE_COMPASS>;
                irq_enable = <0>;
                layout = <3>;
        mma7600@4c {
                status = "okay";
                compatible = "gs_mma7660";
                pinctrl-0 = <&mma7660_irq_gpio>;
                reg = <0x4c>;
                irq_enable = <1>;
&pwm3 { //遙控器配置
        status = "okay";
        interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH 0>;
        compatible = "rockchip,remotectl-pwm";
        remote_pwm_id = <3>;
        handle_cpu_id = <0>;
        ir_key0 {
                rockchip,usercode = <0xff00>;
                rockchip,key_table =
                        <0xa6        KEY_POWER>,
                        <0xf2        KEY_HOME>,
                        <0xfa        KEY_BACK>,
                        <0xba        KEY_MENU>,
                        <0xf9        KEY_UP>,
                        <0xe9        KEY_DOWN>,
                        <0xa5        KEY_LEFT>,
                        <0xe4        KEY_RIGHT>,
                        <0xe5        KEY_ENTER>,
                        <0xec        KEY_VOLUMEUP>,
                        <0xe8        KEY_VOLUMEDOWN>,
                        <0xe6        KEY_MUTE>,
                  <0xed        388>,
                        <0xad        KEY_1>,
                        <0xaf        KEY_2>,
                        <0xef        KEY_3>,
                        <0xa9        KEY_4>,
                        <0xab        KEY_5>,
                        <0xeb        KEY_6>,
                        <0xb1        KEY_7>,
                        <0xb3        KEY_8>,
                        <0xf3        KEY_9>,
                        <0xf0        KEY_0>,
                        <0xae        KEY_BACKSPACE>,
      <0xde        KEY_SEARCH>;
         ir_key1 {
                rockchip,usercode = <0xfe01>;
                        <0xb0 KEY_BACK>,
                        <0xb4 KEY_F12>,
                        <0xb2 KEY_F11>,
                    <0xed 388>,
            <0xde KEY_SEARCH>;
&isp0 {
        status = "okay";
&isp1 {
        status = "okay";
&isp0_mmu {
        status = "okay";
&isp1_mmu {
        status = "okay";
&pcie_phy {
        status = "okay";
&pcie0 {
        ep-gpios = <&gpio2 4 GPIO_ACTIVE_HIGH>;
        num-lanes = <4>;
        pinctrl-0 = <&pcie_clkreqn>;
        status = "okay";
&mipi_dsi { //MIPI接口的LCD配置
        status = "okay";
        panel {
                compatible ="simple-panel-dsi";
                reg = <0>;
                backlight = <&backlight>;
                dsi,flags = <(MIPI_DSI_MODE_VIDEO | MIPI_DSI_MODE_VIDEO_BURST |
                                MIPI_DSI_MODE_VIDEO_SYNC_PULSE)>;
                dsi,format = <MIPI_DSI_FMT_RGB888>;
                dsi,lanes = <4>;
                status = "okay";
                display-timings {
                        native-mode = <&timing0>;
                        timing0: timing0 {
                                clock-frequency = <65000000>;
                                hactive = <1024>;
                                vactive = <600>;
                                hback-porch = <80>;
                                hfront-porch = <80>;
                                vback-porch = <20>;
                                vfront-porch = <12>;
                                hsync-len = <2>;
                                vsync-len = <3>;
                                hsync-active = <0>;
                                vsync-active = <0>;
                                de-active = <0>;
                                pixelclk-active = <0>;
&route_hdmi {
        status = "okay";
        connect = <&vopb_out_hdmi>;
&route_mipi {  //MIPI開啟開機(jī)圖片功能
        connect = <&vopl_out_mipi>;
        status = "okay";
&mipi_in_vopb {
&hdmi_in_vopl{
&vopb {
        assigned-clocks = <&cru DCLK_VOP0_DIV>;
        assigned-clock-parents = <&cru PLL_VPLL>;
&vopl {
        assigned-clocks = <&cru DCLK_VOP1_DIV>;
        assigned-clock-parents = <&cru PLL_CPLL>;
&pinctrl {
        lcd-panel {
                lcd_panel_reset: lcd-panel-reset {
                        rockchip,pins = <4 30 RK_FUNC_GPIO &pcfg_pull_up>;
        hdmiin {
                hdmiin_gpios: hdmiin_gpios {
                rockchip,pins =
                                <2 5 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 6 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 7 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 8 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 9 RK_FUNC_GPIO &pcfg_pull_none>,
                                <2 12 RK_FUNC_GPIO &pcfg_pull_none>;
        ak8963{
            ak8963_irq_gpio:ak8963_irq_gpio{
                rockchip,pins = <4 26 RK_FUNC_GPIO &pcfg_pull_none>;
        mma7660 {
                mma7660_irq_gpio: mma7660_irq_gpio {
   lsm330_a {
                lsm330a_irq_gpio: lsm330a-irq-gpio {
        lsm330_g {
                lsm330g_irq_gpio: lsm330g-irq-gpio {
                        rockchip,pins = <1 24 RK_FUNC_GPIO &pcfg_pull_none>;
vsgpio_back {//配置GPIO輸出功能
                b3G_gpio: b3G_gpio {
                        rockchip,pins = <0 2 RK_FUNC_GPIO &pcfg_pull_up>,
                         <2 12 RK_FUNC_GPIO &pcfg_pull_up>,
                         <2 27 RK_FUNC_GPIO &pcfg_pull_up>,
                         <2 28 RK_FUNC_GPIO &pcfg_pull_up>;
