查看: 3080|回復(fù): 3
基于51單片機(jī)的簡易數(shù)字鐘
ID:975438 發(fā)表于 2021-10-27 16:29 | 顯示全部樓層 |閱讀模式
#include<at89x52.h>
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit S1=P3^2;
sbit S2=P3^3;
sbit S3=P3^4;
uchar data hour=23,minute=59,second=50;
uchar count=0;
bit flag1s=0;
unsigned char v_time[9];
unsigned char disp[]="2021-09-07";
unsigned char v_key=0;
//函數(shù)聲明
void LCD_init();
void Set_xy(unsigned char line,unsigned char col);
void Write_dat(unsigned char data_d);
void delay_nms(unsigned char t);
void Write_com(unsigned char com_d);
void Display(unsigned char line,unsigned char col,unsigned char *dlcd);
/*------------LCD初始化函數(shù)-------------*/
void LCD_init()
        delay_nms(15);
        Write_com(0x38);
        delay_nms(5);
        Write_com(0x0c);
        delay_nms(5);
        Write_com(0x06);
/*------------LCD寫命令函數(shù)-------------*/
        RS=0;
        RW=0;
        E=1;
        P0=com_d;
        E=0;
/*------------LCD設(shè)置顯示位置函數(shù)-------------*/
        unsigned char address;
        if(line==0)
                address=0x80+col;
                address=0xc0+col;
        delay_nms(5);
        Write_com(address);
/*------------LCD寫數(shù)據(jù)函數(shù)------------*/
        RS=1;
        RW=0;
        E=1;
        P0=data_d;
        E=0;
/*------------LCD固定字符串顯示函數(shù)------------*/
        Set_xy(line,col);
        while(*dlcd)
                delay_nms(5);
                Write_dat(*dlcd);
                dlcd++;
    unsigned int i, j;
    for (i = t; i > 0; i--)
            for (j = 110; j > 0; j--);
/*--------T0初始化函數(shù)---------*/
void T0_Init()
        EA=1;
        ET0=1;
        TMOD=0x01;
        TH0=0x3c;
        TL0=0xb0;
        TR0=1;
/*-------時鐘函數(shù)--------*/
void timer_init()
        if(flag1s)
                flag1s=0;
                if(++second==60)
                        second=0;
                        if(++minute==60)
                                minute=0;
                                if(++hour==24)
                                        hour=0;
/*--------拆分處理函數(shù)---------*/
void convert()
        v_time[0]=hour/10+0x30;
        v_time[1]=hour%10+0x30;
        v_time[2]=':';
        v_time[3]=minute/10+0x30;
        v_time[4]=minute%10+0x30;
        v_time[5]=':';
        v_time[6]=second/10+0x30;
        v_time[7]=second%10+0x30;
        v_time[8]=0;
/*---------按鍵掃描函數(shù)----------*/
void key_scan()
        if(S1==0)
                delay_nms(10);
                if(S1==0)
                        v_key++;        TR0=0;
                        if(v_key>=3)
                                v_key=0;
                                TR0=1;
                        while(S1==0);//按鍵S1按下處理函數(shù)
/*----------調(diào)分函數(shù)------------*/
void adjust_minute()
        if(S2==0)
                delay_nms(10);
                if(S2==0)
                        minute++;
                        if(minute==60)        minute=0;
                        while(S2==0);
        if(S3==0)
                delay_nms(10);
                if(S3==0)
                        minute--;
                        if(minute==255)        minute=59;
/*----------調(diào)時函數(shù)------------*/
void adjust_hour()
        if(S2==0)
                delay_nms(10);
                if(S2==0)
                        hour++;
                        if(hour==24)        hour=0;
                        while(S2==0);
        if(S3==0)
                delay_nms(10);
                if(S3==0)
                        hour--;
                        if(hour==255)        hour=23;
//主函數(shù)
main()
        T0_Init();
        LCD_init();
        EA=1;
                key_scan();
                switch(v_key)
                        case 0:timer_init();break;
                        case 1:adjust_minute();break;
                        case 2:adjust_hour();
                convert();
                Display(1,3,v_time);
                Display(0,3,disp);
/*--------T0中斷服務(wù)函數(shù)---------*/
void T0_ser() interrupt 1
        TH0=0X3c;
        TL0=0xb0;
        if(++count==20)
                flag1s=1;
                count=0;
ID:997840 發(fā)表于 2021-12-29 09:37 | 顯示全部樓層
請問一下如果要把按鍵3改成在調(diào)節(jié)功能下切換位置怎么改?
ID:1058042 發(fā)表于 2022-12-18 14:42 | 顯示全部樓層
你好 那個功能鍵我把他們換到P1口了 改完后按下去沒反應(yīng) 是怎么回事?
ID:1058042 發(fā)表于 2022-12-18 14:57 | 顯示全部樓層
你好 那個減的按鍵為什么一次減兩下 需要怎么改
