查看: 2951|回復(fù): 1
初步實(shí)現(xiàn)STM32單片機(jī)+MQTT上傳DHT11溫度到onenet源程序
ID:190564 發(fā)表于 2021-10-30 22:37 | 顯示全部樓層 |閱讀模式
初步實(shí)現(xiàn)MQTT上傳DHT11溫度到onenet。根據(jù)正點(diǎn)原子的ESP8266例子,改成mqtt協(xié)議通信上傳溫濕度到onenet
  1. #include "stm32f4xx.h"
  2. #include "sys.h"
  3. #include "delay.h"
  4. #include "usart.h"
  5. #include "led.h"
  6. #include "lcd.h"
  7. #include "key.h"
  8. #include "usmart.h"
  9. #include "sram.h"
  10. #include "malloc.h"
  11. #include "w25qxx.h"
  12. #include "sdio_sdcard.h"
  13. #include "ff.h"
  14. #include "exfuns.h"
  15. #include "fontupd.h"
  16. #include "text.h"
  17. #include "usmart.h"
  18. #include "touch.h"
  19. #include "usart3.h"
  20. #include "common.h"
  21. #include "dht11.h"
  22. int temp_limit_up = 35, temp_limit_down = 10, humi_limit_up = 90, humi_limit_down = 20;   //溫濕度閾值
  23. //測(cè)試界面主UI
  24. void esp_8266_mtest_ui(u16 x,u16 y)
  25. {
  26.         LCD_Clear(WHITE);
  27.         POINT_COLOR=RED;
  28.         Show_Str_Mid(0,y,"ESP8266 WIFI應(yīng)用",16,240);
  29.         Show_Str(x,y+25,200,16,"請(qǐng)選擇網(wǎng)絡(luò)模式:",16,0);
  30.         Show_Str(x,y+45,200,16,"KEY0:WIFI STA+AP",16,0);
  31.         Show_Str(x,y+65,200,16,"KEY1:WIFI STA",16,0);
  32.         Show_Str(x,y+85,200,16,"KEY2:WIFI AP",16,0);
  33.         Show_Str(x,y+105,200,16,"WK_UP:WIFI STAMQTT",16,0);
  34.
  35. }
  36. //esp-ESP8266模塊測(cè)試主函數(shù)
  37. void esp_8266_test(void)
  38. {
  39.         u8 key;
  40.         POINT_COLOR=RED;  //LCD字體設(shè)置紅色
  41.         while(esp_8266_send_cmd("AT","OK",20))//檢查WIFI模塊是否在線
  42.         {
  43.                 esp_8266_quit_trans();//退出透?jìng)?br />
  44.                 esp_8266_send_cmd("AT+CIPMODE=0","OK",200);  //關(guān)閉透?jìng)髂J?nbsp;
  45.                 Show_Str(40,55,200,16,"未檢測(cè)到模塊!!!",16,0);
  46.                 delay_ms(800);
  47.                 LCD_Fill(40,55,200,55+16,WHITE);  //對(duì)矩形區(qū)域填充白色
  48.                 Show_Str(40,55,200,16,"嘗試連接模塊...",16,0);
  49.         }
  50.                 while(esp_8266_send_cmd("ATE0","OK",20));//關(guān)閉回顯
  51.                 esp_8266_mtest_ui(32,30);  //顯示UI界面
  52.         while(1)
  53.         {
  54.                 delay_ms(10);
  55.                 key=KEY_Scan(0);
  56.                 if(key)
  57.                 {
  58.                         LCD_Clear(WHITE);
  59.                         POINT_COLOR=RED;
  60.                         switch(key)
  61.                         {
  62.                                 case 1://KEY0
  63.                                         Show_Str_Mid(0,30,"ESP WIFI-AP+STA 測(cè)試",16,240);
  64.                                         Show_Str_Mid(0,50,"正在配置ESP8266模塊,請(qǐng)稍等...",12,240);
  65.                                   esp_8266_apsta_test();//WIFI APSTA測(cè)試
  66.                                         break;
  67.                                 case 2://KEY1
  68.                                         Show_Str_Mid(0,30,"ESP WIFI-STA 測(cè)試",16,240);
  69.                                         Show_Str_Mid(0,50,"正在配置ESP8266模塊,請(qǐng)稍等...",12,240);
  70.                                   esp_8266_wifista_test();//WIFI STA測(cè)試
  71.                                         break;
  72.                                 case 3://KEY2
  73.                                         Show_Str_Mid(0,30,"ESP WIFI-AP 測(cè)試",16,240);
  74.                                         Show_Str_Mid(0,50,"正在配置ESP8266模塊,請(qǐng)稍等...",12,240);
  75.                                   esp_8266_wifiap_test();//WIFI AP測(cè)試
  76.                                         break;
  77.                           case 4://KEY_UP
  78.                                         Show_Str_Mid(0,30,"ESP WIFI-STA-MQTT 測(cè)試",16,240);
  79.                                         Show_Str_Mid(0,50,"正在配置ESP8266模塊,請(qǐng)稍等...",12,240);
  80.                                   esp_8266_wifistamqtt_test();//WIFI STA MQTT測(cè)試
  81.                                         break;
  82.                         }
  83.                 }
  84.         }
  85. }
  86. int main(void)
  87. {
  88.         u8 key,fontok=0;
  89.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置系統(tǒng)中斷優(yōu)先級(jí)分組2
  90.         delay_init(168);  //初始化延時(shí)函數(shù)
  91.         uart_init(115200);                //初始化串口波特率為115200
  92.         usart3_init(115200);  //初始化串口3波特率為115200
  93.         LED_Init();                                        //初始化LED
  94.          LCD_Init();                                        //LCD初始化
  95.          KEY_Init();                                        //按鍵初始化
  96.         W25QXX_Init();                                //初始化W25Q128
  97.         tp_dev.init();                                //初始化觸摸屏
  98.         usmart_dev.init(168);                //初始化USMART
  99.         my_mem_init(SRAMIN);                //初始化內(nèi)部?jī)?nèi)存池
  100.         my_mem_init(SRAMCCM);                //初始化CCM內(nèi)存池
  101.         exfuns_init();                                //為fatfs相關(guān)變量申請(qǐng)內(nèi)存
  102.   f_mount(fs[0],"0:",1);                 //掛載SD卡
  103.          f_mount(fs[1],"1:",1);                 //掛載FLASH.
  104.         key=KEY_Scan(0);
  105.         if(key==KEY0_PRES)                //強(qiáng)制校準(zhǔn)
  106.         {
  107.                 LCD_Clear(WHITE);        //清屏
  108.                 TP_Adjust();                  //屏幕校準(zhǔn)
  109.                 TP_Save_Adjdata();
  110.                 LCD_Clear(WHITE);        //清屏
  111.         }
  112.         fontok=font_init();                //檢查字庫(kù)是否OK
  113.         if(fontok||key==KEY1_PRES)//需要更新字庫(kù)
  114.         {
  115.                 LCD_Clear(WHITE);                           //清屏
  116.                  POINT_COLOR=RED;                        //設(shè)置字體為紅色
  117.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  118.                 while(SD_Init())                        //檢測(cè)SD卡
  119.                 {
  120.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  121.                         delay_ms(200);
  122.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  123.                         delay_ms(200);
  124.                 }
  125.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  126.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  127.                 key=update_font(20,110,16,"0:");//從SD卡更新
  128.                 while(key)//更新失敗
  129.                 {
  130.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  131.                         delay_ms(200);
  132.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  133.                         delay_ms(200);
  134.                 }
  135.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  136.                 delay_ms(1500);
  137.                 LCD_Clear(WHITE);//清屏
  138.         }
  139.
  140.         if(DHT11_Init())           //dht11器件不存在
  141.         {
  142.                 Show_Str_Mid(0,30,"DHT11 Init ERROR",16,240);
  143.
  144.         }
  145.
  146.         /*
  147.                 while(1)
  148.         {
  149.
  150.                 key=KEY_Scan(0);
  151.                 if(key)
  152.                 {
  153.
  154.                         switch(key)
  155.                         {
  156.                                 case 1://KEY0
  157.                                         printf("a");
  158.                                         break;
  159.                                 case 2://KEY1
  160.                                         printf("b");
  161.                                         break;
  162.                                 case 3://KEY2
  163.                                         printf("c");
  164.                                         break;
  165.                           case 4://KEY_UP
  166.                                         printf("d");
  167.                                         break;
  168.                         }
  169.                 }
  170.         }
  171.         */
  172.         esp_8266_test();                //進(jìn)入ATK_ESP8266測(cè)試
  173. }
所有資料51hei附件下載:
MQTT應(yīng)用代碼.7z (829.88 KB, 下載次數(shù): 60)
ID:346927 發(fā)表于 2021-11-2 11:44 | 顯示全部樓層
很好的資料,已下載,謝謝分享!
