查看: 2679|回復(fù): 0
89C51單片機(jī)與DAC0832 輸出正弦波,三角波,矩形波,鋸齒波源程序
ID:978036 發(fā)表于 2021-11-4 23:27 | 顯示全部樓層 |閱讀模式
proteus仿真電路: 1.png
輸出波形:
源代碼: PS:需要什么波就留什么波,把其他注釋掉。你們也可以自己改一下,通過按鍵控制相應(yīng)波形輸出。謝謝
  1. //#include <reg51.h>
  2. //#include <absacc.h>
  3. //#define uint unsigned int
  4. //#define DAC0832 XBYTE[0xFEFF]
  5. //void main(void)
  6. //{
  7. //        uint i;
  8. //        while(1)
  9. //        {
  10. //                for(i=0;i<0x100;i++)
  11. //                {DAC0832=i;}
  12. //        }
  13. //}                             //鋸齒波
  14. //#include <reg51.h>
  15. //#include <absacc.h>
  16. //#define uchar unsigned char
  17. //#define DAC0832 XBYTE[0xFEFF]
  18. //void main()
  19. //{
  20. //        uchar i;
  21. //        while(1)
  22. //        {
  23. //                for(i=0;i<0xff;i++)
  24. //                {DAC0832=i;}
  25. //                for(i=0xff;i>0;i--)
  26. //                {DAC0832=i;}
  27. //        }
  28. //}                           //三角波
  29. //#include <reg51.h>
  30. //#include <absacc.h>
  31. //#define uchar unsigned char
  32. //#define DAC0832 XBYTE[0xFEFF]
  33. //uchar code sinbuf[] =
  34. //{
  35. //     0x80,0x83,0x86,0x89,0x8D,0x90,0x93,0x96,0x99,0x9C,0x9F,0xA2,0xA5,0xA8,0xAB,0xAE,
  36. //     0xB1,0xB4,0xB7,0xBA,0xBC,0xBF,0xC2,0xC5,0xC7,0xCA,0xCC,0xCF,0xD1,0xD4,0xD6,0xD8,
  37. //     0xDA,0xDD,0xDF,0xE1,0xE3,0xE5,0xE7,0xE9,0xEA,0xEC,0xEE,0xEF,0xF1,0xF2,0xF4,0xF5,
  38. //     0xF6,0xF7,0xF8,0xF9,0xFA,0xFB,0xFC,0xFD,0xFD,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  39. //     0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFD,0xFC,0xFB,0xFA,0xF9,0xF8,0xF7,0xF6,
  40. //     0xF5,0xF4,0xF2,0xF1,0xEF,0xEE,0xEC,0xEA,0xE9,0xE7,0xE5,0xE3,0xE1,0xDF,0xDD,0xDA,
  41. //     0xD8,0xD6,0xD4,0xD1,0xCF,0xCC,0xCA,0xC7,0xC5,0xC2,0xBF,0xBC,0xBA,0xB7,0xB4,0xB1,
  42. //     0xAE,0xAB,0xA8,0xA5,0xA2,0x9F,0x9C,0x99,0x96,0x93,0x90,0x8D,0x89,0x86,0x83,0x80,
  43. //     0x80,0x7C,0x79,0x76,0x72,0x6F,0x6C,0x69,0x66,0x63,0x60,0x5D,0x5A,0x57,0x55,0x51,
  44. //     0x4E,0x4C,0x48,0x45,0x43,0x40,0x3D,0x3A,0x38,0x35,0x33,0x30,0x2E,0x2B,0x29,0x27,
  45. //     0x25,0x22,0x20,0x1E,0x1C,0x1A,0x18,0x16,0x15,0x13,0x11,0x10,0x0E,0x0D,0x0B,0x0A,
  46. //     0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
  47. //     0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,
  48. //     0x0A,0x0B,0x0D,0x0E,0x10,0x11,0x13,0x15,0x16,0x18,0x1A,0x1C,0x1E,0x20,0x22,0x25,
  49. //     0x27,0x29,0x2B,0x2E,0x30,0x33,0x35,0x38,0x3A,0x3D,0x40,0x43,0x45,0x48,0x4C,0x4E,
  50. //     0x51,0x55,0x57,0x5A,0x5D,0x60,0x63,0x66,0x69,0x6C,0x6F,0x72,0x76,0x79,0x7C,0x7E
  51. //};
  52. //void main()
  53. //{
  54. //        uchar i;
  55. //        while(1)
  56. //        {
  57. //                for(i=0;i<=0xff;i++)
  58. //                DAC0832=sinbuf[i];
  59. //        }
  60. //}                                     //正弦波
  61. #include <reg51.h>
  62. #include <absacc.h>
  63. #define uchar unsigned char
  64. #define DAC0832 XBYTE[0xFEFF]
  65. void delay()
  66. {
  67.         uchar i;
  68.         for(i=0;i<0xff;i++)
  69.         {;}
  70. }
  71. void main()
  72. {
  73.         uchar i;
  74.         while(1)
  75.         {
  76.                 DAC0832=0;
  77.                 delay();
  78.                 DAC0832=0xff;
  79.                 delay();
  80.         }
  81. }                                     //方波
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 共享資料的黑幣獎(jiǎng)勵(lì)!
