stm8S103 手輪DIY 代碼如下:
#include "IOSTM8S103F3.h"
#define u8 uint8_t
#define u16 uint16_t
#define u32 uint32_t
#define LED10 PA_ODR_ODR2
#define LED100 PA_ODR_ODR3
#define LEDX PD_ODR_ODR4
#define LEDY PD_ODR_ODR5
#define LEDZ PD_ODR_ODR6
#define LEDA PA_ODR_ODR1
#define KZ10 PD_ODR_ODR2
#define KZ100 PD_ODR_ODR3
#define KZX PC_ODR_ODR4
#define KZY PC_ODR_ODR5
#define KZZ PC_ODR_ODR6
#define KZA PC_ODR_ODR7
typedef unsigned char uint8_t;
typedef unsigned short uint16_t;
typedef unsigned long uint32_t;
u8 XYZA=0;
void Delayms(unsigned int ms)
u8 i,y;
while(ms != 0)
for(y=0;y<100;y++)
for(i=0;i<200;i++)
ms--;
//****************io口初始化****************/
void GPIO_INIT()
PA_DDR = 0xFF;//
PA_CR1 = 0xFF;
PA_CR2 = 0xFF;
PA_ODR = 0xFF;
PB_DDR = 0x00;//按鈕
PB_CR1 = 0x00;
PB_CR2 = 0xFF;
EXTI_CR1=0xAA;
PC_DDR = 0xFF;//
PC_CR1 = 0xFF;
PC_CR2 = 0xFF;
PC_ODR = 0xFF;
PD_DDR = 0xFF;//
PD_CR1 = 0xFF;
PD_CR2 = 0xFF;
PD_ODR = 0xFF;
//*********************************主函數(shù)************************************/
main()
//Delayms(50);//穩(wěn)定
CLK_CKDIVR=0x00; //時鐘不分頻 16M
Delayms(100);//穩(wěn)定
GPIO_INIT();
KZX=0;
LEDX=0;
asm("rim");
while (1)
//PB中斷服務函數(shù)
#pragma vector=0x06 //PB 中斷響應
__interrupt void EXTI_PORTB_IRQHandler(void) //PB 服務函數(shù)
if((PB_IDR&0x20)==0)
Delayms(100);// 消按鈕抖動
if(LED10==1&&LED100==1) //10倍
LED10=0;
KZ10=0;
KZ100=1;
if(LED10==0&&LED100==1)//100倍
LED10=0;
LED100=0;
KZ10=1;
KZ100=0;
if(LED10==0&&LED100==0)//1倍
LED10=1;
LED100=1;
KZ10=1;
KZ100=1;
while((PB_IDR&0x20)==0x20);//釋放按鈕
if((PB_IDR&0x10)==0)//4選1
if(XYZA==0)
LEDX=0;
LEDY=1;
LEDZ=1;
LEDA=1;
KZX=0;
KZY=1;
KZZ=1;
KZA=1;
if(XYZA==1)
LEDX=1;
LEDY=0;
LEDZ=1;
LEDA=1;
KZX=1;
KZY=0;
KZZ=1;
KZA=1;
if(XYZA==2)
LEDX=1;
LEDY=1;
LEDZ=0;
LEDA=1;
KZX=1;
KZY=1;
KZZ=0;
KZA=1;
if(XYZA==3)
LEDX=1;
LEDY=1;
LEDZ=1;
LEDA=0;
KZX=1;
KZY=1;
KZZ=1;
KZA=0;
XYZA=0;
else XYZA++;
while((PB_IDR&0x10)==0x10);//釋放按鈕
