查看: 1304|回復(fù): 0
stm32f103r6+Proteus仿真 AD轉(zhuǎn)換+捕獲周期程序相關(guān)問題
ID:893765 發(fā)表于 2021-11-15 21:11 | 顯示全部樓層 |閱讀模式
仿真顯示錯(cuò)誤數(shù)值且數(shù)值不隨著調(diào)整而改變
附工程文件&代碼&仿真 麻煩各位大佬了
警告:
../Core/Src/main.c:124:4: warning: implicit declaration of function 'Show_Led' [-Wimplicit-function-declaration]
../Core/Src/main.c:134:12: warning: implicit declaration of function 'KEY_Scan' [-Wimplicit-function-declaration]
../Core/Src/main.c:139:7: warning: assignment to 'uint16_t' {aka 'short unsigned int'} from 'uint16_t (*)(void)' {aka 'short unsigned int (*)(void)'} makes integer from pointer without a cast [-Wint-conversion]
../Core/Src/main.c:160:7: warning: assignment to 'uint16_t' {aka 'short unsigned int'} from 'uint16_t (*)(void)' {aka 'short unsigned int (*)(void)'} makes integer from pointer without a cast [-Wint-conversion]
../Core/Src/bsp.c:107:1: warning: control reaches end of non-void function [-Wreturn-type]
2mode.7z
518.24 KB, 下載次數(shù): 11
