本帖最后由 qwettyuio 于 2021-11-22 14:25 編輯
想學(xué)習(xí)使用T1定時(shí)器控制T0定時(shí)器
通過(guò)按鍵控制定時(shí)器的,想修改,沒(méi)有按鍵控制的情況下,每次通過(guò)按鍵設(shè)時(shí)間結(jié)束等待5后啟動(dòng)倒計(jì)時(shí),
#include<reg51.h>
uchar min,sec,count,sec1,sec2,min0,min1,min2,keystopc,temp,mun;
sbit keystop=P3^0;
sbit keyh=P3^1;
sbit keym=P3^2;
sbit led1=P1^0;
sbit beep=P2^3;
sbit lcden=P3^4;
sbit lcdrw=P3^6;
sbit lcdrs=P3^5;
uchar code table[]={'0','1','2','3','4','5','6','7','8','9',':'};
void delay(uint z) //延時(shí)程序
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void beep_Init()
beep=0;
delay(500);
beep=1;
------LCD1602顯示函數(shù)------
void write_com(uchar com)
lcdrs=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_data(uchar date)
lcdrs=1;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init_1602() //初始化1602
lcden=0;
lcdrw=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
void write_Char(unsigned char x,unsigned char y,unsigned char date)
if (y == 0)
write_com(0x80 + x);
write_com(0xC0 + x);
write_data(date);
void display(uchar min0,uchar min1,uchar min2,uchar sec1,uchar sec2) //顯示程序
write_Char(3,0,table[min0]);
write_Char(4,0,table[min1]);
write_Char(5,0,table[min2]);
write_Char(6,0,table[0x0a]);
write_Char(7,0,table[sec1]);
write_Char(8,0,table[sec2]);
------計(jì)時(shí)器/定時(shí)器0-----
void init() //定時(shí)器初始化
count=0;
min=0;
sec=0;
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=0;
ET0=1;
EA=1;
void count0() interrupt 1 //工作方式
TH0=(65536-50000)/256; //50ms
count++;
if(count==20) //20*50ms=1000ms=1s
count=0;
if(sec==0)
if (min!=0)
sec=59;
min--;
beep_Init();
TR0 =0;
else sec--;
------主函數(shù)------
init();
init_1602();
if(keystop==0) //檢測(cè)是否停止鍵按下
delay(10);
if(keystop==0)
if(keystopc!=1) keystopc++; //按停止鍵的次數(shù)
else keystopc=0;
while(keystop==0); //松手檢測(cè)
delay(5);
while(keystop==0);
switch(keystopc)
case 0:TR0=0;break; // 按鍵一次就停止計(jì)數(shù)
case 1:TR0=1;break;
default:break;
if(keyh==0) //實(shí)現(xiàn)分鐘加一
delay(100);
if(keyh==0)
if(min!=110)
min++;
while(!keym); //松手檢測(cè)
delay(5);
while(!keym);
if(keym==0) //實(shí)現(xiàn)分鐘減一
delay(100);
if(keym==0)
if(min!=0)
min--;
while(!keyh); //松手檢測(cè)
delay(5);
while(!keyh);
min0=min/100;
min1=min%100/10;
min2=min%10;
sec1=sec/10;
sec2=sec%10;
display(min0,min1,min2,sec1,sec2); //一直顯示時(shí)鐘
