可以三個擋位,輸出不同的轉(zhuǎn)速,同時采集轉(zhuǎn)速,進(jìn)行PID運算
2021-11-17 20:39 上傳
2021-11-17 20:34 上傳
- #include <reg52.h>
- #include <stdio.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define THC0 0xf9
- #define TLC0 0x0f //2ms
- //#define THC0 0xec
- //#define TLC0 0x78 //5ms
- #define SEG_DATA_PORT P0
- unsigned char code Duan[]={0x3F, 0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x40};//共陰極數(shù)碼管,0-9段碼表
- unsigned char Data_Buffer[8]={1,0,0,0,0,0,0,0}; // 顯示緩沖
- unsigned int displaytime=0,timing=90;
- uchar i=0;
- sbit LS138_A=P2^2;
- sbit LS138_B=P2^3;
- sbit LS138_C=P2^4;
- sbit AddSpeed=P3^1; //一檔按鍵端口
- sbit SubSpeed=P3^0; //二擋按鍵端口
- sbit TurnForward=P3^3; //三擋按鍵端口
- sbit TurnBackward=P3^4; //啟動或關(guān)閉按鍵端口
- //sbit Stop=P1^5;
- sbit buzzer = P1^3;
- sbit IN1=P1^1;
- sbit IN2=P1^2;
- sbit PWM_FC=P1^0;
- int e ,e1 ,e2 ;
- float uk ,uk1 ,duk ;//pid輸出值
- float Kp=15,Ki=12,Kd=1.6;
- int out=0;
- uint SpeedSet=100;
- uint cnt=0;
- uint Inpluse=0,num=0;//脈沖計數(shù)
- uint PWMTime=100;//脈沖寬度
- unsigned char arry[];
- void SendString(uint ch);
- void PIDControl();
- void SystemInit();
- void delay(uchar x);
- void PWMOUT();
- void SetSpeed();
- void SegRefre();
- /**************主函數(shù)************/
- void main()
- SystemInit();
- while(1)
- SetSpeed(); //按鍵設(shè)定速度
- SegRefre(); //數(shù)碼管顯示刷新
- PWMOUT(); //輸出PWM
- void PIDControl() //pid偏差計算
- e=SpeedSet-num;
- duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2))/50;
- uk=uk1+duk;
- out=(int)uk; //輸出為占空比
- if(out>1000)
- out=1000;
- else if(out<0)
- out=0;
- uk1=uk; //變量值移位
- e2=e1;
- e1=e;
- PWMTime=out;
- uint i,j;
- for(i=x;i>0;i--)
- for(j=50;j>0;j--);
- void PWMOUT()
- if(cnt<PWMTime)
- PWM_FC=1;
- else
- PWM_FC=0;
- if(cnt>1000) cnt=0;
- void SystemInit()
- TMOD=0X21;
- TH0=THC0;
- TL0=TLC0;
- TH1=0xC0;
- TL1=0XC0;
- ET1=1;
- ET0=1;
- TR0=1;
- TR1=1;
- EX0=1;
- IT0=1;
- EA=1;
- e =0;
- e1=0;
- e2=0;
- IN1 = 0;
- IN2 = 0;
- void SetSpeed()
- if(AddSpeed==0&&IN2==1)
- delay(200); //消抖處理
- if(AddSpeed==0)
- Data_Buffer[0]=1;//一檔
- SpeedSet=100;
- timing = 90;
- if(SpeedSet>1500)
- SpeedSet=1500;
- if(SubSpeed==0&&IN2==1)
- delay(200);
- if(SubSpeed==0)
- Data_Buffer[0]=2;//二檔
- SpeedSet=230;
- timing = 70;
- if(SpeedSet<0) SpeedSet=0;
- if(TurnForward==0&&IN2==1)
- delay(200);
- if(TurnForward==0)
- Data_Buffer[0]=3;//三檔
- SpeedSet=380;
- timing = 50;
- if(TurnBackward==0)
- delay(200);
- IN1 = 0;
- IN2 = ~IN2;
- SpeedSet=100;
- timing = 90;
- while(TurnBackward==0);
- if(Stop==0)
- delay(200);
- if(Stop==0)
- IN1 = 1;
- IN2 = 1;
- while(Stop==0);
- void SegRefre() //顯示刷新
- //Data_Buffer[0]=timing/1000; //分離設(shè)定值各位
- if(IN2==1){
- Data_Buffer[1]=10;
- Data_Buffer[2]=timing/10;
- Data_Buffer[3]=timing%10;
- else{
- Data_Buffer[0]=0;
- Data_Buffer[2]=0;
- Data_Buffer[3]=0;
- Data_Buffer[4]=num/1000;
- Data_Buffer[5]=num%1000/100;
- Data_Buffer[6]=num%100/10;
- Data_Buffer[7]=num%10;
- void int0() interrupt 0
- Inpluse++; //采集外部脈沖
- void t0() interrupt 1
- static unsigned char Bit=0;
- static unsigned int time=0;
- TH0=THC0;
- TL0=TLC0;
- Bit++;
- time++; //轉(zhuǎn)速測量周期
仿真代碼51hei附件下載:
直流電機(jī)PID控制.rar
(102.48 KB, 下載次數(shù): 117)
2021-11-17 20:34 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
