#include <reg52.h>
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x84};
uchar code table0[]={0xf7,0xfe,0xfd,0xfb};
unsigned char code table2[]={0xef,0xdf,0xbf,0x7f};
uchar display[]={0,0,0,0};
void sw1();
void sw2();
void sw3();
void sw4();
void xianshi();
void init();
uchar temp,num2,x,x1,x2,a,count;
int num,num1;
uchar key;
uchar i,j;
sbit k1=P1^0;
sbit k2=P1^1;
sbit k3=P1^2;
sbit k4=P1^3;
sbit sp=P1^4;
sbit l1=P1^5;
sbit l2=P1^6;
sbit P3_4=P3^4;
sbit P3_5=P3^5;
sbit P3_6=P3^6;
sbit P3_7=P3^7;
void delay(uchar z)
uchar x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void init()
a=0;
TMOD=0x01;
TH0=(65536-10000)/256;
TL0=(65536-10000)%256;
EA=1;
ET0=1;
if(k1==0)
delay(5);
if(k1==0)
num++;
if(num==99)
num=0;
num2=num;
while(k1==0);
if(k2==0)
delay(5);
if(k2==0)
num--;
if(num==-1)
num=99;
num2=num;
while(k2==0);
if(k3==0)
l1=0;
delay(5);
if(k3==0)
x++;
if(x==2)
x=0;
while(k3==0);
void keyboad()
P3=0xff;
P3_4=0;
temp=P3;
temp=temp & 0x0f; //取高四位
if (temp!=0x0f)
delay(5);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
{delay(5);num1=4;l2=0;xianshi();} break;
case 0x0d:
{delay(5);num1=3;l2=0;xianshi();}break;
case 0x0b:
{delay(5);num1=2;l2=0;xianshi();}break;
case 0x07:
{delay(5);num1=1;l2=0;xianshi();} break;
l1=1;
P3=0xff;
P3_5=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
delay(5);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
{delay(5);num1=8;l2=0;xianshi();} break;
case 0x0d:
{delay(5);num1=7;l2=0;xianshi();} break;
case 0x0b:
{delay(5);num1=6;l2=0;xianshi();} break;
case 0x07:
{delay(5);num1=5;l2=0;xianshi();} break;
l1=1;
P3=0xff;
P3_6=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
delay(5);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
{delay(5);num1=12;l2=0;xianshi();} break;
case 0x0d:
{delay(5);num1=11;l2=0;xianshi();} break;
case 0x0b:
{delay(5);num1=10;l2=0;xianshi();} break;
case 0x07:
{delay(5);num1=9;l2=0;xianshi();} break;
l1=1;
P3=0xff;
P3_7=0;
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
delay(5);
temp=P3;
temp=temp & 0x0f;
if (temp!=0x0f)
temp=P3;
temp=temp & 0x0f;
switch(temp)
case 0x0e:
{delay(5);num1=16;l2=0;xianshi();} break;
case 0x0d:
{delay(5);num1=15;l2=0;xianshi();} break;
case 0x0b:
{delay(5);num1=14;l2=0;xianshi();} break;
case 0x07:
{delay(5);num1=13;l2=0;xianshi();} break;
l1=1;
temp=P3;
P0=table[key];
void xianshi()
TR0=0;
num=0;
sp=1;
delay(100);
sp=0;
for(a=0;a<4;a++)
delay(5);
P2=table0[a];
P0=table[display[a]];
display[0]=num/10;
display[1]=num%10;
display[2]=num1/10;
display[3]=num1%10;
if(k4==0) //
num=num2;
num1=0;
TR0=1;
l1=1;
l2=1;
return;
l1=1;
l2=1;
sp=0;
x=0;
num=num2=30;
if(x==1)
delay(5);
TR0=1;
keyboad();
if(k4==0)
l1=1;
l2=1;
delay(5);
num=num2;
TR0=1;
for(a=0;a<4;a++)
delay(5);
P2=table0[a];
display[0]=num/10;
display[1]=num%10;
display[2]=num1/10;
display[3]=num1%10;
init();
void time0() interrupt 1
count++;
if(k4==0)
num=num2;
TR0=1;
num1=0;
return;
for(a=0;a<4;a++)
delay(10);
P2=table0[a];
display[0]=num/10;
display[1]=num%10;
display[2]=num1/10;
display[3]=num1%10;
if(count==100)
count=0;
num--;
if(num<5)
l1=~l1;
