查看: 1741|回復(fù): 0
單片機(jī)交通燈代碼
ID:986065 發(fā)表于 2021-11-29 18:49 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define uint  unsigned int
uchar a=0;  //東西顯示時(shí)間的緩存變量
uchar b=0;        //南北顯示時(shí)間的緩存變量
uchar time=0;        //記錄循環(huán)單位的位置
uchar int_time=0;//記錄中斷的次數(shù)
uchar clock_a_red=30;        //東西定時(shí)器初值
uchar clock_a_green=25;
uchar clock_a_yellow=5;
uchar clock_b_red=30;        //南北南北計(jì)時(shí)器初值
uchar clock_b_green=25;
uchar clock_b_yellow=5;
uchar code table[]={             //數(shù)碼管顯示編碼
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f};
//延時(shí)模塊
void delayms(uint xms)
        uint i,j;
        for(i=xms;i>0;i--)
                for(j=110;j>0;j--);
//主函數(shù)模塊
         TMOD=0X01;
        TH1=(65535-50000)/256;
        TH0=(65535-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        P2=0xff;
        P1=0x00;
          /*數(shù)碼管顯示模塊*/
          P2=0xfe;
          P1=table[a/10];
          delayms(1);
          P2=0xfd;
          P1=table[a%10];
          delayms(1);
          P2=0xfb;
          P1=table[b/10];
          delayms(1);
          P2=0xf7;
          P1=table[b%10];
          delayms(1);
//中斷服務(wù)模塊
void T0_tme() interrupt 1
        if(20==int_time++)
                time++;
                if(time>=0&&time<25)
                        P0=0xde;
                        a=clock_a_red--;
                        b=clock_b_green--;
                else if(time>=25&&time<30)
                        P0=0xee;
                        clock_b_green=25;
                        a=clock_a_red--;
                        b=clock_b_yellow--;
                else if(time>=30&&time<55)
                        P0=0xf3;
                        clock_a_red=30;
                        clock_b_yellow=5;
                        a=clock_a_green--;
                        b=clock_b_red--;
                else if(time>=55&&time<60)
                        P0=0xf5;
                        clock_a_green=25;
                        a=clock_a_yellow--;
                        b=clock_b_red--;
                        time=0;
                        clock_a_yellow=5;
                        clock_b_red=30;
                int_time=0;
