查看: 2774|回復(fù): 2
STM32 HAL庫 PWM DMA問題
ID:498757 發(fā)表于 2021-12-2 17:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
1黑幣
今天想用stmf103c8t6 做一個PWM DMA實驗  用一個數(shù)組輸出占空比的波形,但是怎么也沒有輸出,所以就發(fā)的論壇里,有沒有哪位大神能找出問題,多謝!
#include "main.h"
#include "dma.h"
#include "tim.h"
#include "gpio.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
#define NUM 10
uint16_t  send_Buf[NUM] = {0};
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
void HAL_TIM_PWM_PulseFinishedCallback(TIM_HandleTypeDef *htim)
    HAL_TIM_PWM_Stop_DMA(&htim2, TIM_CHANNEL_1);
void WS2812()
      for (i = 0; i < NUM; i++)
          send_Buf[i] = 20 * (i + 5);
    HAL_TIM_PWM_Start_DMA(&htim2, TIM_CHANNEL_1,(uint32_t*)send_Buf,NUM);
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_TIM2_Init();
  MX_DMA_Init();
  MX_TIM1_Init();
  /* USER CODE BEGIN 2 */
WS2812();
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
ID:498757 發(fā)表于 2021-12-6 16:48 | 只看該作者
問題已找到
ID:990403 發(fā)表于 2021-12-10 09:41 | 只看該作者
樓主我寫的和你的也差不多,請問是什么問題呢,我還沒有解決
