- #include "STC15F2K60S2.H"
- #include "stdio.h"
- #include "board_init.h"
- #include "Led.h"
- #include "keyboard.h"
- #include "Timer.h"
- #include "seg.h"
- #include "Delay.h"
- #include "string.h"
- #include "iic.h"
- //函數(shù)聲明區(qū)
- void Key_Proc(void);
- void Seg_Proc(void);
- void Led_Proc(void);
- unsigned char trans_function(unsigned char);
- unsigned char PWM_control();
- void BUZZ_control(void);
- void Delay(unsigned int num);
- long ms_Tick = 0;
- //定時(shí)器減速區(qū)變量
- unsigned int Key_Slow_Down;
- unsigned int Seg_Slow_Down;
- unsigned int Led_Slow_Down;
- //按鍵專用變量
- unsigned char Key_Value;
- unsigned char Key_Old;
- unsigned char Key_Down;
- //數(shù)碼管專用變量
- unsigned char seg_string[10];
- unsigned char seg_string1[5];
- unsigned char seg_buf[8];
- unsigned char pos=0;
- //LED專用變量
- unsigned char ucLed;
- //其他變量定義
- bit State_flag = 0;
- unsigned char state = 1;
- unsigned char light_Lv[10]={0,1,1,1,1,1,1,1,1,1};
- unsigned char timer_count; //pwm控制一個(gè)周期 20ms,放在計(jì)時(shí)器1中累加,20置零。
- unsigned char interface_state = 1; //頁面狀態(tài)。
- unsigned int interface_timer = 0;
- bit BUZZ = 0; //用于限制蜂鳴器只關(guān)閉一次的變量。
- bit BUZZ1;
- unsigned char BUZZ_LV ;
- unsigned char timer_count1;
- unsigned char timer_count_2;
- sbit delay = P0^4;
- sbit Buzz = P0^6;
- bit sparkle;
- bit Error_waning;
- bit Led_control_state;
- unsigned int A;
- long ms_Tick_sparkle;
- unsigned char V;
- void main(void)
- Cls_Periheral();
- Timer1Init();
- Timer0Init();
- EA = 1;
- ucLed = 0xff;
- IP = 0X01; //0000 1000
- while(1)
- Key_Proc();
- Led_Proc();
- BUZZ_control();
- V = Pfc_8591_Adc(0x43)/2.55/4;
- /* Timer1_interrupt routine */
- void tm1_isr() interrupt 3
- ms_Tick++;
- if (++timer_count == 23) timer_count = 0;//pwm 50HZ;
- if (++timer_count_2 == 25) timer_count_2 = 0;
- if (interface_timer == 10000)
- interface_state = 1;
- interface_timer = 0;
- if(Led_control_state == 0)
- interface_timer ++;
- if (++Key_Slow_Down == 10) Key_Slow_Down = 0; //減速變量區(qū),控制子函數(shù)的刷新頻率
- if (++Led_Slow_Down == 100) Led_Slow_Down = 0;
- if (++Seg_Slow_Down == 500) Seg_Slow_Down = 0;
- Seg_Disp(seg_buf,pos); //用于數(shù)碼管顯示
- if(++pos == 8) pos=0;
- Seg_Proc();
- ucLed = PWM_control();
- Led_Disp(ucLed); //用于LED顯示
- /* Timer0_interrupt routine */
- void tm0_isr() interrupt 1
- if (++timer_count1 == A) timer_count1 = 0;
- void Key_Proc()
- if (Key_Slow_Down) return;
- Key_Slow_Down=1;
- Key_Value = Key_Read();
- Key_Down = Key_Value & (Key_Old ^ Key_Value);
- Key_Old = Key_Value;
- if(interface_state == 3) //PWM控制蜂鳴器聲音大小
- switch(Key_Down)
- case 4:
- BUZZ_LV = 0; break;
- case 8:
- BUZZ_LV = 1; break;
- case 12:
- BUZZ_LV = 2; break;
- case 16:
- BUZZ_LV = 3; break;
- case 9:
- BUZZ_LV = 4; break;
- case 13:
- BUZZ_LV = 5; break;
- case 17:
- BUZZ_LV = 6; break;
- case 10:
- BUZZ_LV = 7; break;
- case 14:
- BUZZ_LV = 8; break;
- case 18:
- BUZZ_LV = 9; break;
- if(interface_state == 2)
- switch(Key_Down)
- case 5 ://向右調(diào)節(jié)
- if(state == 8) state = 0;
- state ++;
- break;
- case 6 ://向左調(diào)節(jié)
- if(state == 1) state = 9;
- state --;
- break;
- case 4:
- light_Lv[state] = 0; break;
- case 8:
- light_Lv[state] = 1; break;
- case 12:
- light_Lv[state] = 2; break;
- case 16:
- light_Lv[state] = 3; break;
- case 9:
- light_Lv[state] = 4; break;
- case 13:
- light_Lv[state] = 5; break;
- case 17:
- light_Lv[state] = 6; break;
- case 10:
- light_Lv[state] = 7; break;
- case 14:
- light_Lv[state] = 8; break;
- case 18:
- light_Lv[state] = 9; break;
- case 11:
- Led_control_state = ~Led_control_state;
- break;
- case 15: //報(bào)警。
- case 19:
- Error_waning = 1;
- break;
- if(Key_Down == 7) //界面狀態(tài)調(diào)節(jié)
- if(interface_state == 3) interface_state = 0;
- interface_state ++;
- if(Key_Down) interface_timer = 0; //若有鍵盤按下,則重新計(jì)時(shí)返回主頁面的時(shí)間。
- if (Led_Slow_Down) return;
- Led_Slow_Down = 1;
- void Seg_Proc()
- if (Seg_Slow_Down) return;
- Seg_Slow_Down = 1;
- switch(interface_state)
- case 1: //主界面 亮度表格
- //因?yàn)閟printf打印%d超過4個(gè)會(huì)出現(xiàn)溢出,而keil5沒有提供改進(jìn)版,故分成兩次打印。
- sprintf(seg_string,"%d%d%d%d",(unsigned int)light_Lv[1],(unsigned int)light_Lv[2],(unsigned int)light_Lv[3],(unsigned int)light_Lv[4]);
- sprintf(seg_string1,"%d%d%d%d",(unsigned int)light_Lv[5],(unsigned int)light_Lv[6],(unsigned int)light_Lv[7],(unsigned int)light_Lv[8]);
- strcat(seg_string,seg_string1);
- break;
- case 2://當(dāng)前選中閃爍
- if((ms_Tick - ms_Tick_sparkle)>=200)
- ms_Tick_sparkle = ms_Tick;
- sparkle ^= 1;
- if(sparkle ==1)
- switch(state)
- case 1:
- seg_string[0] = ' ';
- break;
- case 2:
- seg_string[1] = ' ';
- break;
- case 3:
- seg_string[2] = ' ';
- break;
- case 4:
- seg_string[3] = ' ';
- break;
- case 5:
- seg_string[4] = ' ';
- break;
- case 6:
- seg_string[5] = ' ';
- break;
- case 7:
- seg_string[6] = ' ';
- break;
- case 8:
- seg_string[7] = ' ';
- break;
- else
- sprintf(seg_string,"%03.0f ",(float)(4*V));
- break;
- case 3:
- sprintf(seg_string,"-------%d",(unsigned int)BUZZ_LV);
- break;
- Seg_Tran(seg_string,seg_buf);
- /*****pwm亮度控制*****/
- unsigned char i = 0;
- unsigned char j = 0;
- unsigned char k = 5;
- if(Error_waning == 0 && Led_control_state == 0)
- if(light_Lv[1] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[1]*2.3 ) ucLed = ucLed | 0x01; //0000 0001
- else ucLed = ucLed & ~0x01;
- else
- ucLed = ucLed & ~0x01;
- if(light_Lv[2] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[2]*2.3 ) ucLed = ucLed | 0x02; //0000 0010
- else ucLed = ucLed & ~0x02;
- else
- ucLed = ucLed & ~0x02;
- if(light_Lv[3] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[3]*2.3 ) ucLed = ucLed | 0x04; //0000 0100
- else ucLed = ucLed & ~0x04;
- else
- ucLed = ucLed & ~0x04;
- if(light_Lv[4] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[4]*2.3 ) ucLed = ucLed | 0x08; //0000 1000
- else ucLed = ucLed & ~0x08;
- else
- ucLed = ucLed & ~0x08;
- if(light_Lv[5] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[5]*2.3 ) ucLed = ucLed | 0x10; //0001 0000
- else ucLed = ucLed & ~0x10;
- else
- ucLed = ucLed & ~0x10;
- if(light_Lv[6] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[6]*2.3 ) ucLed = ucLed | 0x20; //0010 0000
- else ucLed = ucLed & ~0x20;
- else
- ucLed = ucLed & ~0x20;
- if(light_Lv[7] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[7]*2.3 ) ucLed = ucLed | 0x40; //0100 0000
- else ucLed = ucLed & ~0x40;
- else
- ucLed = ucLed & ~0x40;
- if(light_Lv[8] != 0) //不區(qū)分0亮度的話,燈熄滅不了。
- if( timer_count <= light_Lv[8]*2.3 ) ucLed = ucLed | 0x80; //1000 0100
- else ucLed = ucLed & ~0x80;
- else
- ucLed = ucLed & ~0x80;
- else if(Error_waning == 1 && Led_control_state == 0) //LED閃爍報(bào)警
- while (k)
- for(i=0;i<9;i++) //控制亮度等級(jí)
- for(j=0;j<4;j++) //控制當(dāng)前亮度等級(jí)的循環(huán)次數(shù)
- Led_Disp(0Xff); //全亮
- Delay(i+1); //亮的時(shí)間
- Led_Disp(0x00);// 全滅
- Delay(9-i); //滅的時(shí)間
- k--;
- Error_waning = 0;
- else if (Led_control_state)
- if(timer_count_2 <= V) ucLed = 0xFF; //
- else ucLed = 0x00;
- if(interface_state == 3) //PWM調(diào)頻控制蜂鳴器
- switch(BUZZ_LV)
- case 0:
- BUZZ1 = 0;
- break;
- case 1 :
- A = 200;
- if(timer_count1<=A/2) BUZZ1 = 1;
- else BUZZ1 = 0; break;
- case 2:
- A = 100;
- break;
- case 3:
- A = 50;
- break;
- case 4:
- // A = 30;
- A = 300;
- break;
- case 5:
- //A = 20;
- A = 400;
- break;
- case 6:
- A = 14;
- break;
- case 7:
- A = 10;
- break;
- case 8:
- A = 4;
- break;
- case 9:
- A = 2;
- break;
- return ucLed;
- /*****蜂鳴器控制函數(shù)*****/
- if(interface_state == 3 && BUZZ1 ==1 && BUZZ == 0)
- BUZZ = 1;
- Buzz = 1; //打開蜂鳴器
- delay = 0;
- P2=P2 & 0X1F | 0Xa0; //Y5 開蜂鳴器
- P2 &= 0X1F;
- if(interface_state == 3 && BUZZ1 == 0 && BUZZ == 1)
- BUZZ = 0;
- Buzz = 0; //
- delay = 0;
- P2=P2 & 0X1F | 0Xa0; //Y5 關(guān)蜂鳴器
- P2 &= 0X1F;
- if(interface_state <3 && BUZZ == 1)
- BUZZ = 0;
- Buzz = 0;
- delay = 0;
- P2 &= 0X1F;
- /*****延時(shí)函數(shù)*****/
- unsigned int i;
- while(num--)
- for(i=0;i<628;i++); //晶振頻率為12MHZ則震動(dòng)一次周期為(1/12M)S\ 數(shù)量級(jí)為 um 執(zhí)行628次,需要時(shí)間≈1ms
Keil代碼下載:
程序源碼.zip
(151.44 KB, 下載次數(shù): 13)
2021-12-2 22:09 上傳
點(diǎn)擊文件名下載附件
