查看: 2488|回復(fù): 0
單片機(jī)按鍵控制8x8點(diǎn)陣Proteus仿真程序
簡(jiǎn)易的8X8點(diǎn)陣,拿去
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. void delayms(unsigned int n);
  6. sbit KEY=P2^0;
  7. sbit KEY1=P2^1;
  8. sbit KEY2=P2^2;
  9. //添加取模記得定義數(shù)組數(shù)量
  10. uchar code M[11][8]=
  11. {
  12.         {0x00,0x3e,0x41,0x41,0x41,0x3e,0x00,0x00},
  13.         {0x00,0x00,0x00,0x21,0x7f,0x01,0x00,0x00},
  14.         {0x00,0x27,0x45,0x45,0x45,0x39,0x00,0x00},
  15.         {0x00,0x22,0x49,0x49,0x49,0x36,0x00,0x00},
  16.         {0x00,0x0c,0x14,0x24,0x7f,0x04,0x00,0x00},
  17.         {0x00,0x72,0x51,0x51,0x51,0x4e,0x00,0x00},
  18.         {0x00,0x3e,0x49,0x49,0x49,0x26,0x00,0x00},
  19.         {0x00,0x40,0x40,0x40,0x4f,0x70,0x00,0x00},
  20.         {0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00},
  21.         {0x00,0x32,0x49,0x49,0x49,0x3e,0x00,0x00},
  22.         {0x00,0x20,0x30,0x38,0x3c,0x3e,0x00,0x00}
  23. };
  24. uchar i,j;
  25. void main()
  26. {
  27.         P0 = 0xff;
  28.         P1 = 0xff;
  29.         P2 = 0xff;
  30.
  31.         TMOD = 0x01;
  32.         TH0  = (65535-2000)/256;
  33.         TL0  = (65535-2000)%256;
  34.         IT0 = 1;
  35.         IE  = 0x83;
  36.         i   = 0xfc;        //開(kāi)頭修改這即可
  37.         while(1)
  38.         {
  39.                 if(!KEY)
  40.                 {
  41.                         delayms(100);
  42.                         while(!KEY)
  43.                         {
  44.                                          P0 = 0xff;
  45.                                         P1 = 0x80;
  46.                                         j = 0;
  47.                                         i = (i+1)%11;
  48.                         }
  49.                 }
  50.                 if(!KEY1)
  51.                 {
  52.                         delayms(100);
  53.                         while(!KEY1)
  54.                         {
  55.                                          P0 = 0xff;
  56.                                         P1 = 0x80;
  57.                                         j = 0;
  58.                                         i = (i+1)%11;
  59.                         }
  60.                 }
  61.                 if(!KEY2)
  62.                 {
  63.                         delayms(100);
  64.                         while(!KEY2)
  65.                         {
  66.                                          P0 = 0xff;
  67.                                         P1 = 0x80;
  68.                                         j = 0;
  69.                                         i = (i+1)%11;
  70.                         }
  71.                 }
  72.         }
  73. }
  74. void Key_Down() interrupt 0                //中斷
  75. {
  76.         P0 = 0xff;
  77.         P1 = 0x80;
  78.         j = 0;
  79.         i = (i+1)%11;
  80.         TR0 = 1;
  81. }
  82. void Show_Dot_Matrix() interrupt 1
  83. {
  84.         TH0  = (65535-2000)/256;
  85.         TL0  = (65535-2000)%256;
  86.         P1 = _crol_(P1,1);                                //循環(huán)左移
  87.         P0 = ~M[i][j];
  88.         j=(j+1)%8;
  89. }
  90. void delayms(unsigned int n)
  91. {
  92.         unsigned int i,j;
  93.         for(j=n;j>0;j--)
  94.         for(i=112;i>0;i--);
  95. }
仿真代碼51hei附件下載:
8X8點(diǎn)陣.zip (56.46 KB, 下載次數(shù): 38)
收藏收藏2 分享淘帖 頂 踩
