利用stm32做控制芯片,實現(xiàn)流水燈效果,左側燈每閃一下,右側流動變換一下,附仿真及程序
單片機源程序如下:
- #include "stm32f10x.h"
- u16 tmp,k=0,leds=1;
- void Delay(u32 count)
- u32 i=0;
- for(;i<count;i++);
- int main(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOC, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA.8 端口配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO 口速度為 50MHz
- GPIO_Init(GPIOA, &GPIO_InitStructure); //根據(jù)設定參數(shù)初始化 GPIOA.8
- GPIO_SetBits(GPIOA,GPIO_Pin_8); //PA.8 輸出高
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PD.2 端口配置, 推挽輸出
- GPIO_Init(GPIOD, &GPIO_InitStructure); //推挽輸出 ,IO 口速度為 50MHz
- GPIO_SetBits(GPIOD,GPIO_Pin_2); //PD.2 輸出高
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1| GPIO_Pin_2| GPIO_Pin_3| GPIO_Pin_4| GPIO_Pin_5| GPIO_Pin_6| GPIO_Pin_7 ; //端口低8位配置
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD; //開漏輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz; //IO 口速度為 50MHz
- GPIO_Init(GPIOC, &GPIO_InitStructure); //根據(jù)設定參數(shù)初始化 GPIOC.0~8 ,低8位輸出
- while(1)
- if( GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_8) == 0 )
- GPIO_SetBits(GPIOA,GPIO_Pin_8) ; //PA.8輸出高
- else
- GPIO_ResetBits(GPIOA,GPIO_Pin_8); //PA.8輸出低
- tmp = GPIOC->ODR & 0xFF00;
- leds = leds+leds;
- k++;
- if(k==4){
- k=0;
- leds += 1;
- GPIOC->ODR = tmp + ~leds;
- Delay(300000);
復制代碼
所有資料51hei附件下載:
流水燈.rar
(337.9 KB, 下載次數(shù): 166)
2021-12-6 14:29 上傳
點擊文件名下載附件
