最近買了一個達(dá)特的甲醛傳感器,想用51單片機(jī)來顯示,用到的顯示屏是OLED12864,通過串口通信讀取到甲醛傳感器的數(shù)據(jù),然后顯示在OLED12864上面。
主程序代碼如下;- #include "reg52.h"
- #include "intrins.h"
- #include "stdio.h"
- #include "codetab.h"
- #include "LQ12864.h"
- #include "USRT.h"
- #define uchar unsigned char
- unsigned char RevBuf[Data_SIZE];
- unsigned int Formaldehyde;
- int data_count;
- bit flished_flag;
- void main(void)
- UartInit();
- OLED_Init();
- while(1)
- OLED_P16x16Ch(0,0,1);
- OLED_P16x16Ch(16,0,2);
- OLED_P8x16Str(32,0,":");
- OLED_ShowChar(8*5,0,'0'+Formaldehyde/10000,16);
- OLED_P8x16Str(50,0,".");
- OLED_ShowChar(8*7,0,'0'+Formaldehyde/1000%10,16);
- OLED_ShowChar(8*8,0,'0'+Formaldehyde/100%10,16);
- OLED_P8x16Str(75,0,"mg/m3");
- if(flished_flag)
- flished_flag=0;
- Formaldehyde=RevBuf[4]*256+RevBuf[5];
- ES=1;
復(fù)制代碼 然后是OLED12864的驅(qū)動代碼- #include "reg52.h"
- // IO口模擬I2C通信
- // SCL接P1^3
- // SDA接P1^2
- sbit SCL=P1^3; //串行時鐘
- sbit SDA=P1^2; //串行數(shù)據(jù)
- #define high 1
- #define low 0
- #define Brightness 0xCF
- #define X_WIDTH 128
- #define Y_WIDTH 64
- /*********************OLED驅(qū)動程序用的延時程序************************************/
- void delay(unsigned int z)
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- //IIC Start
- void IIC_Start()
- SCL = high;
- SDA = high;
- SDA = low;
- SCL = low;
- //IIC Stop
- void IIC_Stop()
- SCL = low;
- SDA = low;
- SCL = high;
- SDA = high;
- // 通過I2C總線寫一個字節(jié)
- void Write_IIC_Byte(unsigned char IIC_Byte)
- unsigned char i;
- for(i=0;i<8;i++)
- if(IIC_Byte & 0x80)
- SDA=high;
- else
- SDA=low;
- SCL=high;
- SCL=low;
- IIC_Byte<<=1;
- SDA=1;
- SCL=1;
- SCL=0;
- /*********************OLED寫數(shù)據(jù)************************************/
- void OLED_WrDat(unsigned char IIC_Data)
- IIC_Start();
- Write_IIC_Byte(0x78);
- Write_IIC_Byte(0x40); //write data
- Write_IIC_Byte(IIC_Data);
- IIC_Stop();
- /*********************OLED寫命令************************************/
- void OLED_WrCmd(unsigned char IIC_Command)
- IIC_Start();
- Write_IIC_Byte(0x78); //Slave address,SA0=0
- Write_IIC_Byte(0x00); //write command
- Write_IIC_Byte(IIC_Command);
- IIC_Stop();
- /*********************OLED 設(shè)置坐標(biāo)************************************/
- void OLED_Set_Pos(unsigned char x, unsigned char y)
- OLED_WrCmd(0xb0+y);
- OLED_WrCmd(((x&0xf0)>>4)|0x10);
- OLED_WrCmd((x&0x0f)|0x01);
- /*********************OLED全屏************************************/
- void OLED_Fill(unsigned char bmp_dat)
- unsigned char y,x;
- for(y=0;y<8;y++)
- OLED_WrCmd(0x01);
- OLED_WrCmd(0x10);
- for(x=0;x<X_WIDTH;x++)
- OLED_WrDat(bmp_dat);
- /*********************OLED復(fù)位************************************/
- void OLED_CLS(void)
- for(y=0;y<8;y++)
- OLED_WrCmd(0x01);
- OLED_WrCmd(0x10);
- OLED_WrDat(0);
- /*********************OLED初始化************************************/
- void OLED_Init(void)
- delay(500);//初始化之前的延時很重要!
- OLED_WrCmd(0xae);//--turn off oled panel
- OLED_WrCmd(0x00);//---set low column address
- OLED_WrCmd(0x10);//---set high column address
- OLED_WrCmd(0x40);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
- OLED_WrCmd(0x81);//--set contrast control register
- OLED_WrCmd(Brightness); // Set SEG Output Current Brightness
- OLED_WrCmd(0xa1);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
- OLED_WrCmd(0xc8);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
- OLED_WrCmd(0xa6);//--set normal display
- OLED_WrCmd(0xa8);//--set multiplex ratio(1 to 64)
- OLED_WrCmd(0x3f);//--1/64 duty
- OLED_WrCmd(0xd3);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)
- OLED_WrCmd(0x00);//-not offset
- OLED_WrCmd(0xd5);//--set display clock divide ratio/oscillator frequency
- OLED_WrCmd(0x80);//--set divide ratio, Set Clock as 100 Frames/Sec
- OLED_WrCmd(0xd9);//--set pre-charge period
- OLED_WrCmd(0xf1);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
- OLED_WrCmd(0xda);//--set com pins hardware configuration
- OLED_WrCmd(0x12);
- OLED_WrCmd(0xdb);//--set vcomh
- OLED_WrCmd(0x40);//Set VCOM Deselect Level
- OLED_WrCmd(0x20);//-Set Page Addressing Mode (0x00/0x01/0x02)
- OLED_WrCmd(0x02);//
- OLED_WrCmd(0x8d);//--set Charge Pump enable/disable
- OLED_WrCmd(0x14);//--set(0x10) disable
- OLED_WrCmd(0xa4);// Disable Entire Display On (0xa4/0xa5)
- OLED_WrCmd(0xa6);// Disable Inverse Display On (0xa6/a7)
- OLED_WrCmd(0xaf);//--turn on oled panel
- OLED_Fill(0x00); //初始清屏
- OLED_Set_Pos(0,0);
- /***************功能描述:顯示6*8一組標(biāo)準(zhǔn)ASCII字符串 顯示的坐標(biāo)(x,y),y為頁范圍0~7****************/
- void OLED_P6x8Str(unsigned char x, y,unsigned char ch[])
- unsigned char c=0,i=0,j=0;
- while (ch[j]!='\0')
- c =ch[j]-32;
- if(x>126){x=0;y++;}
- OLED_Set_Pos(x,y);
- for(i=0;i<6;i++)
- OLED_WrDat(F6x8[c][i]);
- x+=6;
- j++;
- /*******************功能描述:顯示8*16一組標(biāo)準(zhǔn)ASCII字符串 顯示的坐標(biāo)(x,y),y為頁范圍0~7****************/
- void OLED_P8x16Str(unsigned char x, y,unsigned char ch[])
- c =ch[j]-32;
- if(x>120){x=0;y++;}
- for(i=0;i<8;i++)
- OLED_WrDat(F8X16[c*16+i]);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WrDat(F8X16[c*16+i+8]);
- x+=8;
- j++;
- /*****************功能描述:顯示16*16點(diǎn)陣 顯示的坐標(biāo)(x,y),y為頁范圍0~7****************************/
- void OLED_P16x16Ch(unsigned char x, y, N)
- unsigned char wm=0;
- unsigned int adder=32*N;
- OLED_Set_Pos(x , y);
- for(wm = 0;wm < 16;wm++)
- OLED_WrDat(F16x16[adder]);
- adder += 1;
- OLED_Set_Pos(x,y + 1);
- adder += 1;
- /***********功能描述:顯示顯示BMP圖片128×64起始點(diǎn)坐標(biāo)(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
- void Draw_BMP(unsigned char x0, y0,x1, y1,unsigned char BMP[])
- unsigned int j=0;
- unsigned char x,y;
- if(y1%8==0) y=y1/8;
- else y=y1/8+1;
- for(y=y0;y<y1;y++)
- OLED_Set_Pos(x0,y);
- for(x=x0;x<x1;x++)
- OLED_WrDat(BMP[j++]);
- void OLED_ShowChar(unsigned char x,unsigned char y,unsigned char chr,unsigned char Char_Size)
- unsigned char c=0,i=0;
- c=chr-' ';//得到偏移后的值
- if(x>X_WIDTH-1){x=0;y=y+2;}
- if(Char_Size ==16)
- for(i=0;i<8;i++)
- for(i=0;i<8;i++)
- else {
- for(i=0;i<6;i++)
復(fù)制代碼 制作出來的實(shí)物圖如下:
這是我買的達(dá)特甲醛傳感器
這是顯示效果
Keil5代碼.7z
2021-12-7 15:40 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
35.1 KB, 下載次數(shù): 86, 下載積分: 黑幣 -5
