- #include "reg52.h"
- typedef unsigned int u16;
- typedef unsigned char u8;
- #define GPIO_DIG P0
- #define GPIO_KEY P1
- sbit LSA=P2^2;
- sbit LSB=P2^3;
- sbit LSC=P2^4;
- u8 KeyValue; //用來存放讀取到的鍵值
- u8 keyflag; //用來回復(fù)是否有按鍵按下
- u8 code smgduan[18]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
- 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x08};//顯示0~F的值,且顯示橫杠
- u16 wei[8]={16,16,16,16,16,16,16,16}; //用來存放每一位數(shù)碼管數(shù)字的數(shù)組,且初始化為橫杠
- void delay(u16 i)
- while(i--);
- void KeyDown(void)
- char a=0;
- GPIO_KEY=0x0f;
- if(GPIO_KEY!=0x0f)//讀取按鍵是否按下
- keyflag=1; //有按鍵按下,數(shù)值為1;
- delay(1000);//延時(shí)10ms進(jìn)行消抖
- if(GPIO_KEY!=0x0f)//再次檢測鍵盤是否按下
- //測試列
- GPIO_KEY=0X0F;
- switch(GPIO_KEY)
- case(0X07): KeyValue=0;break;
- case(0X0b): KeyValue=1;break;
- case(0X0d): KeyValue=2;break;
- case(0X0e): KeyValue=3;break;
- //測試行
- GPIO_KEY=0XF0;
- switch(GPIO_KEY)
- case(0X70): KeyValue=KeyValue;break;
- case(0Xb0): KeyValue=KeyValue+4;break;
- case(0Xd0): KeyValue=KeyValue+8;break;
- case(0Xe0): KeyValue=KeyValue+12;break;
- while((a<50)&&(GPIO_KEY!=0xf0)) //檢測按鍵松手檢測
- delay(1000);
- a++;
- void display()
- LSA=0; LSB=0; LSC=0; P0=smgduan[wei[0]];delay(50); P0=0x00;
- LSA=1; LSB=0; LSC=0; P0=smgduan[wei[1]];delay(50); P0=0x00;
- LSA=0; LSB=1; LSC=0; P0=smgduan[wei[2]];delay(50); P0=0x00;
- LSA=1; LSB=1; LSC=0; P0=smgduan[wei[3]];delay(50); P0=0x00;
- LSA=0; LSB=0; LSC=1; P0=smgduan[wei[4]];delay(50); P0=0x00;
- LSA=1; LSB=0; LSC=1; P0=smgduan[wei[5]];delay(50); P0=0x00;
- LSA=0; LSB=1; LSC=1; P0=smgduan[wei[6]];delay(50); P0=0x00;
- LSA=1; LSB=1; LSC=1; P0=smgduan[wei[7]];delay(50); P0=0x00;
- void main()
- u8 i;
- while(1)
- display(); //數(shù)碼管顯示
- KeyDown(); //判斷按鍵是否按下
- if(keyflag==1) //若按鍵按下,數(shù)組中每一位數(shù)字向前移動(dòng)一位
- for(i=7;i>0;i--)
- {wei[i]=wei[i-1];}
- wei[0]=KeyValue;
- keyflag=0;
復(fù)制代碼 說明:
測試中電路突然無法正常顯示,經(jīng)排查是一個(gè)按鍵卡住一直短路,
更換元器件后,故障得以解決。
仿真程序下載:
任務(wù)十.zip
(157.51 KB, 下載次數(shù): 28)
2021-12-13 15:23 上傳
點(diǎn)擊文件名下載附件
源代碼和仿真圖
